I never liked typing on these… so why did i make one? Well, I saw this project here and was curious how it was done.
It took a while… mainly due to a long break in-between tries, but finally I got this to work fairly well.
It basically gives you 1/2 second to make your multi-key choice (actually 1/2 second after each button press, so possible to take a up to 2 seconds to press the 4 times to get to last character of most buttons), before adding the character to a string variable… and displays that growing string along the upper display.
The code was done on a spare UNO I had plugged into USB. I figure if anyone really wants to use this code, they can figure out how to make the ESP adjustments
char auth[] = "6502d3d6xxxxxxxxxxb91539529a";
int cntr = 0;
String valInput;
String stringValue = "";
int cntrTmr;
int upTime;
The timer.deleteTimer command always seems to stop the first
assigned timer, along with whatever actual timer you are deleting.
So this initial "do nothing" timer is needed in order to prevent
the following UpTime timer from being canceled.
int DoNothingTmr = timer.setTimeout(10L, []() {
}); // END Timer Function
// Timed Lambda Function - UpTime
upTime = timer.setInterval(500L, []() {
Blynk.virtualWrite(V12, millis() / 1000);
pinMode(13, OUTPUT);
Serial.begin(19200);
Blynk.begin(Serial, auth);
Blynk.virtualWrite(V11, "START"); // press Counter Display
Blynk.virtualWrite(V13, " "); // Clear String Value Display
BLYNK_WRITE(V2) { // Button 2 ABC
if (param.asInt()) {
timer.deleteTimer(cntrTmr);
cntrTmr = timer.setTimeout(500L, []() {
cntr = 0;
Blynk.virtualWrite(V11, "Ready");
stringValue = stringValue + valInput;
Blynk.virtualWrite(V13, stringValue);
cntr++;
switch (cntr) {
case 1:
valInput = "2";
break;
case 2:
valInput = "A";
break;
case 3:
valInput = "B";
break;
case 4:
valInput = "C";
break;
default:
valInput = "";
cntr = 0;
break;
Blynk.virtualWrite(V10, valInput);
Blynk.virtualWrite(V11, cntr);
BLYNK_WRITE(V3) { // Button 3 DEF
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "3";
break;
case 2:
valInput = "D";
break;
case 3:
valInput = "E";
break;
case 4:
valInput = "F";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V4) { // Button 4 GHI
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "4";
break;
case 2:
valInput = "G";
break;
case 3:
valInput = "H";
break;
case 4:
valInput = "I";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V5) { // Button 5 JKL
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "5";
break;
case 2:
valInput = "J";
break;
case 3:
valInput = "K";
break;
case 4:
valInput = "L";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V6) { // Button 6 MNO
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "6";
break;
case 2:
valInput = "M";
break;
case 3:
valInput = "N";
break;
case 4:
valInput = "O";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V7) { // Button 7 PGRS
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "7";
break;
case 2:
valInput = "P";
break;
case 3:
valInput = "Q";
break;
case 4:
valInput = "R";
break;
case 5:
valInput = "S";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V8) { // Button 8 TUV
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "8";
break;
case 2:
valInput = "T";
break;
case 3:
valInput = "U";
break;
case 4:
valInput = "V";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V9) { // Button 9 XXYZ
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "9";
break;
case 2:
valInput = "W";
break;
case 3:
valInput = "X";
break;
case 4:
valInput = "Y";
break;
case 5:
valInput = "Z";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V1) { // Button 1
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "1";
break;
default:
valInput = "";
cntr = 0;
break;
BLYNK_WRITE(V0) { // Button 0 Space
cntr = 0;
cntr++;
switch (cntr) {
case 1:
valInput = "0";
break;
case 2:
valInput = " ";
break;
default:
valInput = "";
cntr = 0;
break;
Blynk.virtualWrite(V10, "SPACE");
BLYNK_WRITE(V14) { // Button Clear
cntr = 0;
stringValue = "";
Blynk.virtualWrite(V10, "Clear");
BLYNK_WRITE(V15) { // Button Backspace
cntr = 0;
if (stringValue.length() > 0) {
int lastIndex = stringValue.length() - 1;
stringValue.remove(lastIndex);
if (stringValue.length() == 0) {
Blynk.virtualWrite(V10, "BKSPC");
This was done on my Local Server… so I am unsure if this QR will work or not… let me know.
about how it used to work, but now is an almost useless UI for new 16:9 ratio HD phones… Ironically isn’t current phones your target market??
