this is my alphanumeric keyboard
retro style
like in the 3210 eraā¦
nice coding exercise, by the way!
Iām amazed, that actually your every touch sends a message to
and gets it delivered back. And you donāt even see a lag.
Isnāt it pure magic?
Next comes predictive text insertion and all the resulting hilarity
there is no lag
no flood
no disconnection
and itās not used to write a text no more to play angry bird with Gunner.
itās only an alarm keyboard , like all alarm keyboard.
but thank you so much for your support, indeed.
Iām amazed to read such comments !
Indeed Very good!
Is it possible to share your code with us?
the only guy interested in my job
thanks you !
I will share my code soon
I will make others laugh, for sure !
I hope it is not a simple terminal to IDE Serial monitor redirect, with a trained monkey on the PC keyboard at the other end doing all the ālogicā ![]()
no terminal, no keyboard, no predictive text
just Blynk , timers , flags and a lot of hard work !
Hi there @Blynk_Coeur I feel cheeky asking but I canāt see where if you posted the code for the magic keyboard?
And yes I realise I have resurrected a 2yr old post
Hey Pete, I did see that and am looking at it. I wondered what the different approaches were. Maybe itās still a trade secret
I donāt know where I posted my code too
but regarding @Gunner version, his code is very similar and better than mine.
as Iām using Nextion display to emulate keycode alarm , I donāt use Blynk interface ,and it was so ugly
I just found it !!
BLYNK_WRITE(V48) // alarm ENTER
timer.enable (T1);
Serial.println("*******************************************");
Serial.println(currentTime);
Serial.println("Alarm");
Serial.println("");
if (param.asInt()) {
// button pressed
Blynk.setProperty(V47, "color", BLYNK_GREEN);
lcd2.clear();
raw = 1;
col = 0;
keypress = 1;
if (code != "") {
if (code == PASS) {
lcd2.print(0, 0, "Alarm ON");
else {
Blynk.setProperty(V47, "color", BLYNK_RED);
lcd2.print(0, 0, "ERREUR CODE");
lcd2.print(0, 1, "APPUYEZ SUR CLR");
else {
lcd2.clear();
lcd2.print(0, 0, "Entrez le code");
code = "";
raw = 1;
col = 0;
keypress = 1;
BLYNK_WRITE(V49) // alarm code CE/CLR
// button 0 pressed
switch (keypress) {
case 1://CE
timer.deleteTimer(AlarmTimer);
//AlarmTimer = timer.setTimeout(AlarmTimeout, nextDetect);
keypress = 1;
lastkeypress = 10;
col = col - 1;
if (col < 0) {
col = 1;
key = "";
lcd2.print(col, raw, "_ ");
break;
case 2://CLR
keypress++;
lastkeypress = 10;
lcd2.clear();
code = "";
raw = 1;
col = 0;
keypress = 1;
break;
BLYNK_WRITE(V51) // alarm code 1
// button 1 pressed
switch (keypress) {
case 1:
//timer.deleteTimer(AlarmTimer);
keypress++;
lastkeypress = 1;
key = "1";
Code[col] = {'1'};
break;
case 2:
keypress++;
lastkeypress = 1;
key = " ";
Code[col] = {' '};
break;
lcdprint();
BLYNK_WRITE(V52) // alarm code 2
// button 2 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 2;
key = "2";
Code[col] = {'2'};
break;
case 2:
keypress++;
lastkeypress = 2;
key = "A";
Code[col] = {'A'};
break;
case 3:
keypress++;
lastkeypress = 2;
key = "B";
Code[col] = {'B'};
break;
case 4:
keypress = 1;
lastkeypress = 2;
key = "C";
Code[col] = {'C'};
break;
lcdprint();
BLYNK_WRITE(V53) // alarm code 3
// button 3 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 3;
key = "3";
Code[col] = {'3'};
break;
case 2:
keypress++;
lastkeypress = 3;
key = "D";
Code[col] = {'D'};
break;
case 3:
keypress++;
lastkeypress = 3;
key = "E";
Code[col] = {'E'};
break;
case 4:
keypress = 1;
lastkeypress = 3;
key = "F";
Code[col] = {'F'};
break;
lcdprint();
BLYNK_WRITE(V54) // alarm code 4
// button 4 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 4;
key = "4";
Code[col] = {'4'};
break;
case 2:
keypress++;
lastkeypress = 4;
key = "G";
Code[col] = {'D'};
break;
case 3:
keypress++;
lastkeypress = 4;
key = "H";
Code[col] = {'H'};
break;
case 4:
keypress = 1;
lastkeypress = 4;
key = "I";
Code[col] = {'I'};
break;
lcdprint();
BLYNK_WRITE(V55) // alarm code 5
// button 5 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 5;
key = "5";
Code[col] = {'5'};
break;
case 2:
keypress++;
lastkeypress = 5;
key = "J";
Code[col] = {'J'};
break;
case 3:
keypress++;
lastkeypress = 5;
key = "K";
Code[col] = {'K'};
break;
case 4:
keypress = 1;
lastkeypress = 5;
key = "L";
Code[col] = {'L'};
break;
lcdprint();
BLYNK_WRITE(V56) // alarm code 6
// button 6 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 6;
key = "6";
Code[col] = {'6'};
break;
case 2:
keypress++;
lastkeypress = 6;
key = "M";
Code[col] = {'M'};
break;
case 3:
keypress++;
lastkeypress = 6;
key = "N";
Code[col] = {'N'};
break;
case 4:
keypress = 1;
lastkeypress = 6;
key = "O";
Code[col] = {'O'};
break;
lcdprint();
BLYNK_WRITE(V57) // alarm code 7
// button 7 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 7;
key = "7";
Code[col] = {'7'};
break;
case 2:
keypress++;
lastkeypress = 7;
key = "P";
Code[col] = {'P'};
break;
case 3:
keypress++;
lastkeypress = 7;
key = "Q";
Code[col] = {'Q'};
break;
case 4:
keypress = 1;
lastkeypress = 7;
key = "R";
Code[col] = {'R'};
break;
lcdprint();
BLYNK_WRITE(V58) // alarm code 8
// button 8 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 8;
key = "8";
Code[col] = {'8'};
break;
case 2:
keypress++;
lastkeypress = 8;
key = "T";
Code[col] = {'T'};
break;
case 3:
keypress++;
lastkeypress = 8;
key = "U";
Code[col] = {'U'};
break;
case 4:
keypress = 1;
lastkeypress = 8;
key = "V";
Code[col] = {'V'};
break;
lcdprint();
BLYNK_WRITE(V59) // alarm code 9
// button 9 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 9;
key = "9";
Code[col] = {'9'};
break;
case 2:
keypress++;
lastkeypress = 9;
key = "W";
Code[col] = {'W'};
break;
case 3:
keypress++;
lastkeypress = 9;
key = "X";
Code[col] = {'X'};
break;
case 4:
keypress = 1;
lastkeypress = 9;
key = "Y";
Code[col] = {'Y'};
break;
lcdprint();
BLYNK_WRITE(V50) // alarm code 0
// button 0 pressed
switch (keypress) {
case 1:
keypress++;
lastkeypress = 0;
key = "0";
Code[col] = {'0'};
break;
case 2:
keypress++;
lastkeypress = 2;
key = "OPEN";
Code[col] = {'OPEN'};
break;
lcdprint();
void lcdprint() {
lcd2.print(col, raw, key);
Serial.println("keypress " + String(keypress) + " lastkeypress " + String(lastkeypress) + " Col " + String(col) + " key " + key + " Code[col] " + String(Code[col]));
Serial.println("");
void nextDetect() { //col +1
Serial.println("next");
keypress = 1;
col++;
lcd2.print(col, raw, "_");
You are welcome !
