This is my first project which I put in here and I do not know if it does not happen again but it probably will not hurt
I made thanks to BLYNK and esp8266 remotely controlled Power Socket via wifi and it looks like this
I used:
1x esp8266-01
1x 1-way 250V/10A relay switch
1x voltage stabilizer module ams1117 3.3v for esp8266
1x converter from 250V AC to 5V DC
1x PowerSupply case
and some wires
This is a schematic
Itâs nice to make your own stuff sometimes, rather than buying the off the shelf options.
Can I suggest a few minor modificationsâŚ
remove those unused plastic stand-offs to allow you to position the relay and the other stuff further apart, and fix everything down so that it canât move.
think about adding an LED to indicate things, like connecting to Wi-Fi/ Blynk, and the on/off status of the relay.
think about adding a physical push button to allow control without the app. Youâd need to synchronise the app button of course. You might also want to add a non-blocking routine so that the physical button can be used if the Wi-Fi or Blynk server are down.
adding an OTA update routine would be handy if you want to update your code without disassembling the socket.
The LED, physical switch and OTA (but not non-blocking code) are included in the example code for these switchesâŚ
Thanks Pete
Thanks for advice. I thought about solutions like LED or button, but for that I would need a âlarger labâ and a bigger contribution
and for now, Iâve probably done it the easiest way to give others room to show off and give it as an example.
The OTA updates is something that I have to learn
If it has 1MB or 4MB then yes. There are some 512kB boards out there I think, and you wouldnât manage OTA with them.
I think the Expressif Flash Download Tool will tell you for your board. It may list the memory size in Mbits. 512kB is 4Mbits, 1MB is 8Mbits and 4MB is 16Mbits.
If you have a 1MB board then flash itwith the option of 1MB (no SPIFFS).
I also forgot to mention that my preference is to have a Wi-Fi switch power-up in the Off mode, rather than syncing with the Blynk server on start-up. This is just for safety/economy in case you forget that an appliance is on in the app, but appears off because there has been a power interruption.
