ebda3
September 29, 2021, 4:25pm
1
Hello, please help. When the power is out, the router turns off when the power is back. I have a problem not to connect again
#define BLYNK_TEMPLATE_ID "**************"
#define BLYNK_DEVICE_NAME "****************"
#define BLYNK_AUTH_TOKEN "****************";
#include <WiFiManager.h>
#include <DNSServer.h>
#include "uptime.h"
#include <Ticker.h>
Ticker ticker;
#define TRIGGER_PIN 0 //Reset wifi
#define LED_PIN 2 // led wifi
#define vPIN_UPTIME V0
bool IsFirstRun = 1;
BlynkTimer UltraTimer;
void tick()
int state = digitalRead(LED_PIN);
digitalWrite(LED_PIN, !state);
void configModeCallback (WiFiManager *myWiFiManager) {
ticker.attach(0.2, tick);
BLYNK_CONNECTED()
if (IsFirstRun==1)
//Blynk.syncVirtual();
IsFirstRun=0;
void UPTIME(){
uptime::calculateUptime();
Serial.println(" "+String(uptime::getDays())+" days "+String(uptime::getHours())+":"+String(uptime::getMinutes())+":"+String(uptime::getSeconds()));
Serial.print("\n");
Blynk.virtualWrite(vPIN_UPTIME," "+String(uptime::getDays())+" days "+String(uptime::getHours())+":"+String(uptime::getMinutes())+":"+String(uptime::getSeconds()));
Blynk.config(auth);
IsFirstRun = 1 ;
UltraTimer.setInterval(1000L, UPTIME);
pinMode(TRIGGER_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
WiFiManager wifiManager;
wifiManager.setConnectTimeout(120);
ticker.attach(0.6, tick);
wifiManager.setAPCallback(configModeCallback);
if (!wifiManager.autoConnect("ULTRA TECH IOT")) { // your ap name
ESP.reset();
ticker.detach();
digitalWrite(LED_PIN, HIGH);
WiFi.mode(WIFI_STA);
while (Blynk.connect() == false) {}
UltraTimer.run();
int count = 0;
while(digitalRead(TRIGGER_PIN) == LOW) {
delay(100);
count++;
if(count > 30) {
WiFi.disconnect();
digitalWrite(LED_PIN, LOW);
count = 0;
delay(100);
ESP.reset();
John93
September 29, 2021, 4:29pm
2
You can’t use delay in the void loop, you should keep your void loop clean as possible. Read this :
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
ebda3
September 29, 2021, 4:38pm
3
Thank you my friend @John93 can you provide a code that supports the wifi manager that is free of errors
John93
September 29, 2021, 4:42pm
4
Try this :
http://twitter.com/blynk_app
This example shows how to keep WiFi connection on ESP8266.
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char pass[] = "YourPassword";
int lastConnectionAttempt = millis();
int connectionDelay = 5000; // try to reconnect every 5 seconds
// check WiFi connection:
if (WiFi.status() != WL_CONNECTED)
// (optional) "offline" part of code
// check delay:
if (millis() - lastConnectionAttempt >= connectionDelay)
// attempt to connect to Wifi network:
if (pass && strlen(pass))
WiFi.begin((char*)ssid, (char*)pass);
WiFi.begin((char*)ssid);
ebda3
September 29, 2021, 4:45pm
5
John93:
جرب هذا
Thank you, I will give it a try
ebda3
September 29, 2021, 4:48pm
6
It seems that it is not available on wifimanager
ebda3
September 29, 2021, 4:53pm
8
John93:
ما هو الخطأ؟
I want to configure network name and password via wifi manager
John93
September 29, 2021, 5:03pm
9
I would recommend you to use blynk.edgent instead.
ebda3
September 29, 2021, 5:08pm
10
blynk edgent causes esp8266 to crash and then reboots again I can’t find a solution to the problem I want to use wifimanager
John93
September 29, 2021, 5:14pm
13
Can I see the sketch ?
The sketch you used with blynk edgent.
ebda3
September 29, 2021, 5:23pm
14
#define BLYNK_TEMPLATE_ID "TMPLad2-LRb9"
#define BLYNK_DEVICE_NAME "timeer"
#define BLYNK_FIRMWARE_VERSION "0.2.0"
#define APP_DEBUG
#include "BlynkEdgent.h"
#include <TimeLib.h>
#include <ModbusMaster.h>
#include "uptime.h"
#define vPIN_Relay1 V1 // فيرجوال ريلي 1
#define vPIN_LedRelay1 V2 // ليد ريلي 1
#define vPIN_Time V3 // الساعة
#define vPIN_Date V4 // التاريخ
#define vPIN_Timer1 V5 // مؤقت 1
#define vPIN_OnOffTimr1 V6 // تفعيل وتعطيل مؤقت 1
#define vPIN_VOLTAGE V7 // فولت الكهرباء
#define vPIN_CURRENT_USAGE V8 // الحمل
#define vPIN_ACTIVE_POWER V9
#define vPIN_ACTIVE_ENERGY V10
#define vPIN_FREQUENCY V11 //الهرتز
#define vPin_HighVoltageAC V12 // الحد الاعلى للفولط
#define vPin_LowVoltAC V13 // القيمة الدنيا للفولت
#define vPin_HighCurrentAC V14 //القيمة العليا للحمل
#define vPin_AutoInterrupter V15 //الوضع التلقائي
#define OTA_HOSTNAME "PZEM-004v3"
WidgetLED LedRelay1(vPIN_LedRelay1);
SoftwareSerial pzem(D5,D6); // (RX,TX) connect to TX,RX of PZEM for NodeMCU
ModbusMaster node;
double voltage_usage, current_usage, active_power, active_energy, frequency, power_factor, over_power_alarm;
uint8_t result; uint16_t data[6];
BLYNK_CONNECTED() // استعادة القيم من السيرفر بعد اعادة اقلاع الجهاز
Blynk.sendInternal("rtc", "sync");
int StartH1;
int StartM1;
int StartS1;
int StopH1;
int StopM1;
int StopS1;
const int Relay1 = D4;
float Voltage = 50;
float LowVolt = 0;
float BlynkVoltage = 25;
bool AlertMsgLowVolt = 0;
float HighVoltAC = 300;
float LowVoltAC = 150;
float HighCurrentAC=100;
bool MsgHighVolt = 1;
bool MsgCurrent = 1;
bool MsgLowVoltAC = 1;
bool AutoInterrupter=HIGH;
///////////////// BLYNK_WRITES ////////////////////////////
BLYNK_WRITE(vPIN_Relay1) // اداة التحكم في الريلي
if (param.asInt() == 1)
digitalWrite(Relay1, HIGH);
LedRelay1.on();
Serial.println("Relay1 on");
digitalWrite(Relay1, LOW);
LedRelay1.off();
Serial.println("Relay1 off");
BLYNK_WRITE(vPIN_Timer1) {
setTime1(param);
BLYNK_WRITE(InternalPinRTC)
const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
unsigned long blynkTime = param.asLong();
if (blynkTime >= DEFAULT_TIME)
setTime(blynkTime);
String Time = String(hour()) + ":" + minute() + ":" + second();
String Date = String(day()) + "-" + month() + "-" + year();
Serial.println(Time);
Serial.println(Date);
Serial.println(String("Day: ") + weekday());
//Blynk.virtualWrite(vPIN_Time,Time);
/////////////////////// VOIDS /////////////////////////
void checkTime() {
Blynk.sendInternal("rtc", "sync"); // Actualiza la hora con el servidor
void setTime1(BlynkParam param) {
TimeInputParam t(param);
if (t.hasStartTime()) {
Serial.println(String("Hora de inicio: ") +
t.getStartHour() + ":" +
t.getStartMinute() + ":" +
t.getStartSecond());
StartH1 = t.getStartHour() ;
StartM1 = t.getStartMinute() ;
StartS1 = t.getStartSecond() ;
Serial.println("StartH1: "+String(StartH1));
Serial.println("StartM1: "+String(StartM1));
Serial.println("StartS1: "+String(StartS1));
if (t.hasStopTime()) {
Serial.println(String("Hora de finalización: ") +
t.getStopHour() + ":" +
t.getStopMinute() + ":" +
t.getStopSecond());
StopH1 = t.getStopHour() ;
StopM1 = t.getStopMinute() ;
StopS1 = t.getStopSecond();
Serial.println("StopH1: "+String(StopH1));
Serial.println("StopM1: "+String(StopM1));
Serial.println("StopS1: "+String(StopS1));
for (int i = 1; i <= 7; i++) {
if (t.isWeekdaySelected(i)) {
Serial.println(String("Day ") + i + " is selected");
void UPTIME(){
Serial.print("\n");
void Timr1() // تابع المؤقت رقم 1
if ((hour() == StartH1) and (minute() == StartM1) and (second() > StartS1))
digitalWrite(Relay1, HIGH );
Serial.println("Relay on");
Blynk.virtualWrite(V1,1);
LedRelay1.on();
if ((hour() == StopH1) and (minute() == StopM1) and (second() > StopS1))
digitalWrite(Relay1, LOW );
Serial.println("Relay off ");
Blynk.virtualWrite(V1,0);
LedRelay1.off();
void pzemdata(){
result = node.readInputRegisters(0x0000, 10);
if (result == node.ku8MBSuccess)
voltage_usage = (node.getResponseBuffer(0x00) / 10.0f);
current_usage = (node.getResponseBuffer(0x01) / 1000.000f);
if (AutoInterrupter==HIGH)
if ((voltage_usage > HighVoltAC)and(MsgHighVolt==1))
// Blynk.notify("ارتفع فولت الكهرباء اكثر من القيمة المحددة");
// Blynk.virtualWrite(vPIN_LogTerminal,"ارتفع فولت الكهرباء اكثر من القيمة المحددة الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
MsgHighVolt=0;
if ((voltage_usage < HighVoltAC)and(MsgHighVolt==0))
MsgHighVolt=1;
// Blynk.notify("عودة فولت الكهرباء للحد الطبيعي");
//Blynk.virtualWrite(vPIN_LogTerminal,"عودة فولت الكهرباء للحد الطبيعي الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
if ((current_usage > HighCurrentAC)and(MsgCurrent==1))
// Blynk.notify("تجاوز الحمل القيمة المحددة ");
//Blynk.virtualWrite(vPIN_LogTerminal,"تجاوز الحمل القيمة المحددة الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
MsgCurrent=0;
if ((current_usage < HighCurrentAC)and(MsgCurrent==0))
MsgCurrent=1;
// Blynk.notify("عودة الحمل للحد الطبيعي");
//Blynk.virtualWrite(vPIN_LogTerminal,"عودة الحمل للحد الطبيعي الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
if ((voltage_usage < LowVoltAC)and(MsgLowVoltAC==1))
// Blynk.notify("انخفض فولط المولدة أكثر من القيمة المحددة");
// Blynk.virtualWrite(vPIN_LogTerminal,"انخفض فولط المولدة أكثر من القيمة المحددة الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
MsgLowVoltAC=0;
if ((voltage_usage > LowVoltAC)and(MsgLowVoltAC==0))
MsgLowVoltAC=1;
// Blynk.virtualWrite(vPIN_LogTerminal,"عودة فولت الكهرباء للحد الطبيعي الوقت: " +String(hour()) + ":" + minute() + ":" + second()+" " +String (day()) + "-" + month() + "-" + year() );
//active_power = (node.getResponseBuffer(0x03) / 10.0f);
//active_energy = (node.getResponseBuffer(0x05) / 1000.0f);
frequency = (node.getResponseBuffer(0x07) / 10.0f);
Serial.print("VOLTAGE: "); Serial.println(voltage_usage); // V
Serial.print("CURRENT_USAGE: "); Serial.println(current_usage, 3); // A
//Serial.print("ACTIVE_POWER: "); Serial.println(active_power); // W
//Serial.print("ACTIVE_ENERGY: "); Serial.println(active_energy, 3); // kWh
Serial.print("FREQUENCY: "); Serial.println(frequency); // Hz
Serial.println("====================================================");
Blynk.virtualWrite(vPIN_VOLTAGE, voltage_usage);
Blynk.virtualWrite(vPIN_CURRENT_USAGE, current_usage);
//Blynk.virtualWrite(vPIN_ACTIVE_POWER,active_power);
//Blynk.virtualWrite(vPIN_ACTIVE_ENERGY, active_energy);
Blynk.virtualWrite(vPIN_FREQUENCY, frequency);
BlynkEdgent.begin();
Serial.begin(250000);
pinMode(Relay1,OUTPUT);
UltraTimer.setInterval(1000L, checkTime);
UltraTimer.setInterval(5000L, Timr1);
UltraTimer.setInterval(1000L, pzemdata);
Serial.println("Start serial");
pzem.begin(9600);
Serial.println("Start PZEM serial");
node.begin(1, pzem);
Serial.println("Start PZEM");
BlynkEdgent.run();
UltraTimer.run();
John93
September 29, 2021, 5:28pm
15
I will give it a try as soon as possible, and I will let you know if I figure it out.
Greetings.
Bisri
September 29, 2021, 5:34pm
16
Try It for Algorithm Sistem
ebda3
September 29, 2021, 5:36pm
17
Bisri:
جربه مع الخوارزمية Sistem : ابتسامة طفيفة:BlynkTimer UltraTimer ، UltraTimer1 ، UltraTimer2 ، UltraTimer3 ؛
إعداد باطل ()
UltraTimer.setInterval (1000L، checkTime) ؛
UltraTimer1.setInterval (5000L ، Timr1) ؛ // 5000 يمكن ضبط بمقدار 1000
للتثبيت مع نفس الفاصل الزمني للتأخير UltraTimer2.setInterval (1000L ، UPTIME) ؛
UltraTimer3.setInterval (1000 لتر ، بيانات pzemdata) ؛
حلقة باطلة ()
BlynkEdgent.run () ،
UltraTimer.run () ،
UltraTimer1.run () ،
UltraTimer2.run () ،
UltraTimer3.run () ،
It’s a good idea, thank you, I’ll give it a try
ebda3:
It’s a good idea
No, it’s a bad idea that uses four times more memory than necessary.
@Bisri please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly
Bisri
September 29, 2021, 5:59pm
20
I Think Can Using More Than Sistem Delay Interval(4 Or 5), But With Using Same Delay Interval,
1 Sistem Timing For 1 Function Or Methode Algorithm,
When Using 2 Sistem Timing Interval, But Using Different Delay Or Not Compability(Count Or Value Timing 1 And Timing 2)Can Make Project Crash,
