Reading Table Entry Values
When working with the Table widget, is there a way to read the value of an entry? I’m trying to get my table to display the most recent entry at the top and then a FIFO set up. So that the entries are ordered from most recent to oldest the further you go down the table. The only way I know how to do this is the update the entry in position 1 and then the entry in position 2 is equal to the old entry 1 and the list gets updated with the previous values of the entries in the position above them. But to do this, I need to be able to read the value of an entry and save it in an ‘oldvalue’ variable.
Any ideas on how to do this?
Thanks.
Hello. No way to read from the table, but you may save last values on hardware (EEPROM) or in any virtual pin in order to perform what you need.
@Dmytro any chance of adding table reading at a future date?
@Costas - no. You may use separate pin as temp storage.
