Dear Blynkers, Greetings. I have an issue with one of my project. I am integrating three sensors to be read using a Blynk interface. DHT 11, MQ 135 and a PM 2.5 , optical dust sensor. I don’t have any issues with the first two sensors. The dust sensor/ PM 2.5 works fine, using the serial window. It records the dust density, like 0.0… 0.04… 0.09…0.05 (ug/m3) like this. I tried importing data to the blynk virtual pins, but it records data of only zero. Kindly provide your inputs in this regard. I have attached the sample code. ( Only for PM 2.5 sensor)
code
// Use Virtual pin 5 for uptime display
// variables and declarations
int measurePin = A5;
int ledPower = 12;
unsigned int samplingTime = 280;
unsigned int deltaTime = 40;
unsigned int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
char auth[] = "------------------------------------";
void sensor_PM25()
digitalWrite(ledPower,LOW);
delayMicroseconds(samplingTime);
voMeasured = analogRead(measurePin);
delayMicroseconds(deltaTime);
digitalWrite(ledPower,HIGH);
delayMicroseconds(sleepTime);
calcVoltage = voMeasured*(5.0/1024);
dustDensity = 0.17*calcVoltage-0.1;
if(dustDensity<0)
dustDensity = 0.00;
Blynk.virtualWrite(V8, dustDensity);
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
timer.setInterval(1000L, sensor_PM25);
