If I use the examples from the website, there is no part in the program that connects the raspberry pi to the server or a place where I can type my auth key. Does somebody now what I have to change to the examples to let it connect to the server.
Assuming you are using the RPi as a Blynk Client and not hosting a Local Server… then how to program your client sketch depends on the programming language you use for your Blynk Client in the RPi (NodeJS, Python, WiringPi)
You will have to examine examples for each Library type to see how they utilise Blynk, as the primary Blynk Sketch Builder examples are for Arduino/ESP, not RPi
For example NodeJS…
For Python…
And I never use WiringPi anymore… so no idea.
I think that what @User265 was saying is that in the sketch builder examples for RPI, he can’t work-out where to add in the Auth code. (Neither can I)…
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Raspberry Pi board
example.
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
// to avoid delay() function!
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
I guess it’s somewhere here:
uint16_t port;
This seems to be the variable declaration, but I’m not sure of the syntax for assigning a value for the variable once/when it’s declared.
BTW, when you type something in the optional Auth code box, it doesn’t appear within the sketch at the appropriate place.
That is because the Sketch Builder is technically still assuming Arduino/ESP type C++ code via WiringPi
And based on what I have seen… WiringPi is the least supported of the RPi Blynk, client options.
But searching this forum for the key word WiringPi will at least get the OP started on the reading/learning curve… I think.
I do recall some of my early attempts to get WiringPi running on my Local Server are floating around in this forum… but basically gave up as I much prefer the other programming options ![]()
