• Arduino UNO with Serial USB: Proteus Simulation
• Smartphone OS: Android
• Blynk server
• Blynk Library version: Latest
#define BLYNK_PRINT SwSerial
char auth[] = "XXXXXXXXXXXXXXXz";
const int tempsensor_val = A0;
const int ldr_val = A1;
const int water_val = A2;
const int lamppin = 13;
const int heatpin = 12;
const int fanpin = 7;
const int shadingpin = 5;
const int pumppin = 6;
void myTimerEventa()
int sensorData1 = analogRead(tempsensor_val);
float tempData = (sensorData1/1024.0)*5000/10;
Blynk.virtualWrite(V5, tempData);
void myTimerEventb()
int ldrData = analogRead(ldr_val);
Blynk.virtualWrite(V6, ldrData);
void myTimerEventc()
int waterData = analogRead(water_val);
Blynk.virtualWrite(V7, waterData);
BLYNK_WRITE(V8)
int pinValue = param.asInt();
if(pinValue==1){
digitalWrite(heatpin, HIGH);
digitalWrite(heatpin, LOW);
// process received value
BLYNK_WRITE(V9)
int pinValue1 = param.asInt();
if(pinValue1==1){
digitalWrite(lamppin, HIGH);
digitalWrite(lamppin, LOW);
BLYNK_WRITE(V10)
int pinValue2 = param.asInt();
if(pinValue2==1){
digitalWrite(pumppin, HIGH);
digitalWrite(pumppin, LOW);
BLYNK_WRITE(V11)
if(pinValue==1){
digitalWrite(fanpin, HIGH);
digitalWrite(fanpin, LOW);
BLYNK_WRITE(V12)
if(pinValue==1){
digitalWrite(shadingpin, HIGH);
SwSerial.begin(9600);
pinMode(tempsensor_val, INPUT);
pinMode(ldr_val, INPUT);
pinMode(water_val, INPUT);
pinMode(lamppin, OUTPUT);
pinMode(heatpin, OUTPUT);
pinMode(fanpin, OUTPUT);
pinMode(pumppin, OUTPUT);
pinMode(shadingpin, OUTPUT);
Blynk.begin(Serial, auth);
timer.setInterval(2000L, myTimerEventa);
timer.setInterval(2000L, myTimerEventb);
timer.setInterval(2000L, myTimerEventc);
So what I want to achieve is that when I will create an other button in the blynk app with virtual pin 13 and when the button is off only then will the other 5 blynk buttons , as described in the code, work. When virtual pin 13 is high, I want them to remain unresponsive…
is there any way, I can do this?
Edit: It’s possible push a virtual button and disable other button? - Need Help With My Project - Blynk Community Found this link
