Question about the ds18b20 temperature sensor
Do you trust ds18b20 sensor? Give me advice
I don’t really understand what you’re saying here.
As I said before…
I mean, the refrigeration unit is equipped with a high-precision temperature sensor. The cooling unit is designed to save the corona vaccine. I don’t think there could be a mistake in its temperature sensor. It’s very accurate
Where is the DS18B20 physically, relative to the reefer temperature sensor? In addition, since you are monitoring a temperature that is controlled to be fixed, you could use an offset if nothing else works. Then the issue is what is the variation on the 18B20 with time? Calling it too often will raise its temperature as well.
I wonder the last situation. How did you solved the problem? I have a similar situation here with NodeMCU. I have connected Ds18b20 but, in room temperature i read 73 Celcius. Actually, beside this, i am trying to learn out of range notification settings ā€œin codingā€ with Blynk.
Post your sketch so we can take a look at it.
Read this
