ebda3
October 3, 2021, 5:47pm
1
Hello, I have a cold room gland for medicines. I want to use the ds18b20 temperature sensor. Is it recommended to use it to measure the temperature from 2 degrees to 8 degrees, and what is the error percentage? I did the experiment, but I felt happier with the result. The temperature in the room was 4 degrees, but the temperature sensor ds18b20 gives me 8 degrees
#include <OneWire.h>
#define ONE_WIRE_BUS 5
int relay=7;
void setup() {Serial.begin(9600);
sensors.begin();
pinMode(relay,1);
digitalWrite(relay,1);
long tem;
Serial.println("DONE");
Serial.print("Temperature is: ");
Serial.print(sensors.getTempCByIndex(0));
tem=sensors.getTempCByIndex(0) ;
if(tem>69){digitalWrite(relay,0);}
else{digitalWrite(relay,1);}
ebda3
October 3, 2021, 5:53pm
3
I tried arduino and nodemcu
I dont see any Blynk stuff in your code!! Is this all your code ?
John93
October 3, 2021, 5:54pm
5
This is not blynk sketch.
ebda3
October 3, 2021, 5:55pm
6
I know it’s not a blynk drawing, but I use the same code with blynk
ebda3
October 3, 2021, 5:57pm
7
#define BLYNK_TEMPLATE_ID "TMPLx76oHv"
#define BLYNK_DEVICE_NAME "Temprator Freez 1"
#include <WiFiManager.h>
#include "uptime.h"
#include <TridentTD_LineNotify.h>
char auth[] = "qxOrvYVf-DRiZfSku02F8GcsZZXuxb";
char ssid[] = "ULTRA TECH1";
char pass[] = "qwerty123";
int lastConnectionAttempt = millis();
int connectionDelay = 5000; // اعادة اتصال كل 5 ثواني
#define LINE_TOKEN "oMPewQHyJ1D2inWdkh9uKMHEhgO6jwnZT7xj75Ew"
#define ONE_WIRE_BUS D5
#define vPIN_UPTIME V0
#define vPIN_Temp V1 // درجة الحرارة
#define vPIN_HighTemp V2 // الحد الاعلى للحرارة
#define vPIN_LogTerminal V3 // مسجل الاحداث
#define vPIN_LowTemp V4 // الحد الادنى للحرارة
#define vPIN_State V5 // الوضع التلقائي
#define vPIN_LedState V6 // ليد الوضع التلقائي
#define vPIN_LedAmper V7 // ليد حالة الكهرباء
const int Relay = D7; // رجل الريلي
const int Switsh1 = D0; // رجل تفعيل الوضع التلقائي يدويا
const int Switsh2 = D6; // رجل حالة الكهرباء
bool buttonStatus1 = 0;
bool buttonTemp1 = 0;
bool buttonStatus2 = 0;
bool buttonTemp2 = 0;
float HighTemp=0; // متغير الحد الاعلى للحرارة
float LowTemp=0; // متغير الحد الادنى للحرارة
int NotifyAmper=0;
int NotifyHighTemp=0; // متغير ايقاف الاشعار عند ارتفاع الفولت
int NotifyLowTemp=0; // متغير ايقاف الاشعار عند انخفاض الفولت
int CuntHigh=0; // عداد قبل ارسال اشعار عند ارتفاع الحرارة
int CuntLow=0; // عداد قبل ارسال اشعار عند عودة الحرارة للحد الطبيعي
int CuntUnplogedSensor=0; // عداد قبل ارسال اشعار عند توقف الحساس
int StateSensor=0; // لارسال الاشعار مرة واحدة عند توقف الحساس
bool IsFirstRun = 1;
bool State = 1; // متغير للوضع التلقائي
float tem = 0; // متغير تحويل قيمة الحرارة الى فلوت
BlynkTimer UltraTimer;
WidgetLED LedState(vPIN_LedState);
WidgetLED LedAmper(vPIN_LedAmper);
BLYNK_CONNECTED()
if (IsFirstRun==1)
Blynk.syncVirtual(vPIN_HighTemp,vPIN_LowTemp,vPIN_State);
LedAmper.off();
IsFirstRun=0;
BLYNK_WRITE(vPIN_HighTemp){
HighTemp=param.asFloat();
Blynk.virtualWrite(vPIN_LogTerminal,"تم تغيير الحد الأعلى لدرجة الحرارة"+String(HighTemp));
//LINE.notify("تم تغيير الحد الأعلى لدرجة الحرارة"+String(HighTemp));
BLYNK_WRITE(vPIN_LowTemp){
LowTemp=param.asFloat();
Blynk.virtualWrite(vPIN_LogTerminal,"تم تغيير الحد الطبيعي لدرجة الحرارة"+String(LowTemp));
//LINE.notify("تم تغيير الحد الطبيعي لدرجة الحرارة"+String(LowTemp));
BLYNK_WRITE(vPIN_State)
if (param.asInt() == 1)
LedState.on();
Serial.println("تم تفعيل وضع التنبيه");
State=1;
Serial.print("State : ");
Serial.println(State);
digitalWrite(Relay, HIGH);
LedState.off();
Serial.println("تم ايقاف وضع التنبيه");
State=0;
void checkStatusButton1()
buttonStatus1 = digitalRead(Switsh1);
if (buttonStatus1 != buttonTemp1)
if (buttonStatus1 == HIGH) {
Blynk.virtualWrite(V5, 1);
LedState.on();
State=1;
Serial.println("تم تشغيل وضع التنبيه يدويا");
else {
Blynk.virtualWrite(V5, 0);
LedState.off();
State=0;
Serial.println("تم ايقاف وضع التنبيه يدويا");
buttonTemp1 = buttonStatus1;
void checkStatusButton2()
buttonStatus2 = digitalRead(Switsh2);
if (buttonStatus2 != buttonTemp2)
if (buttonStatus2 == HIGH) {
LedAmper.on();
Serial.println("الكهرباء متوفرة");
LINE.notify("الكهرباء متوفرة");
else {
digitalWrite(Relay, LOW);
LedAmper.off();
Serial.println("الكهرباء غير متوفرة");
LINE.notify("الكهرباء غير متوفرة");
buttonTemp2 = buttonStatus2;
void UPTIME(){
uptime::calculateUptime();
Serial.println(" "+String(uptime::getDays())+" days "+String(uptime::getHours())+":"+String(uptime::getMinutes())+":"+String(uptime::getSeconds()));
Serial.print("\n");
Blynk.virtualWrite(vPIN_UPTIME," "+String(uptime::getDays())+" days "+String(uptime::getHours())+":"+String(uptime::getMinutes())+":"+String(uptime::getSeconds()));
void temprator(){
Serial.println(sensors.getTempCByIndex(0));
Blynk.virtualWrite(vPIN_Temp,tem);
Serial.print("NotifyHighTemp: ");
Serial.println(NotifyHighTemp);
Serial.print("NotifyLowTemp: ");
Serial.println(NotifyLowTemp);
void highTemp(){
if ((tem>HighTemp)and(NotifyHighTemp==0)and(State==1)and(CuntHigh<20)){
CuntHigh++;
delay(250);
if ((tem>HighTemp)and(NotifyHighTemp==0)and(State==1)and(CuntHigh==20)){
// Blynk.logEvent("TempRator", "درجة الحرارة أعلى من الحد الطبيعي ");
Blynk.virtualWrite(vPIN_LogTerminal,"درجة الحرارة أعلى من الحد الطبيعي");
Serial.println("تم تشغيل الانذار");
LINE.notify("درجة الحرارة أعلى من الحد الطبيعي "+String(tem));
digitalWrite(Relay,LOW);
NotifyHighTemp=1;
NotifyLowTemp=0;
CuntLow=0;
StateSensor=1;
if ((tem<HighTemp)and(NotifyHighTemp==1)and(State==1))
digitalWrite(Relay,HIGH);
NotifyHighTemp=0;
CuntHigh=0;
StateSensor=1;
void lowTemp(){
if ((tem<LowTemp)and(tem> 0)and(NotifyLowTemp==0)and(State==1)and(CuntLow<20)){
CuntLow++;
delay(250);
if ((tem<LowTemp)and(tem> 0)and(NotifyLowTemp==0)and(State==1)and(CuntLow==20)){
//Blynk.logEvent("TempRator", "درجة الحرارة الآن ضمن الحد الطبيعي");
Blynk.virtualWrite(vPIN_LogTerminal,"درجة الحرارة الآن ضمن الحد الطبيعي");
Serial.println("درجة الحرارة الآن ضمن الحد الطبيعي");
LINE.notify("درجة الحرارة الآن ضمن الحد الطبيعي"+String(tem));
NotifyLowTemp=1;
StateSensor=1;
void UnplogedSensor(){
if ((tem== -127)and(CuntUnplogedSensor<5)and(StateSensor==0)){
CuntUnplogedSensor++;
delay(250);
if ((tem== -127)and(CuntUnplogedSensor==5)and(StateSensor==0)){
Serial.print("يوجد عطل في حساس الحرارة");
LINE.notify("يوجد عطل في حساس الحرارة");
Serial.print(StateSensor);
Serial.print("CuntUnplogedSensor");
Serial.print(CuntUnplogedSensor);
StateSensor=1;
if ((tem>1)and(StateSensor==1)){
StateSensor=0;
pinMode(Relay,OUTPUT);
pinMode(Switsh1, INPUT);
pinMode(Switsh2, INPUT);
LINE.setToken(LINE_TOKEN);
sensors.begin();
IsFirstRun = 1 ;
UltraTimer.setInterval(1000L, UPTIME);
UltraTimer.setInterval(1000L, highTemp);
UltraTimer.setInterval(1000L, lowTemp);
UltraTimer.setInterval(1000L, temprator);
UltraTimer.setInterval(50000L, UnplogedSensor);
UltraTimer.setInterval(1000L, checkStatusButton1);
UltraTimer.setInterval(1000L, checkStatusButton2);
UltraTimer.run();
if (WiFi.status() != WL_CONNECTED)
if (millis() - lastConnectionAttempt >= connectionDelay)
if (pass && strlen(pass))
WiFi.begin((char*)ssid, (char*)pass);
WiFi.begin((char*)ssid);
John93
8
Your sketch should look like this :
char auth[] = "";
/* WiFi credentials */
char ssid[] = "";
char pass[] = "";
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board "D4 pin on the ndoemcu Module"
DallasTemperature DS18B20(&oneWire);
float temp;
float Fahrenheit=0;
void getdata()
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0); // Celcius
Fahrenheit = DS18B20.toFahrenheit(temp); // Fahrenheit
Serial.println(temp);
Serial.println(Fahrenheit);
Blynk.virtualWrite(V3, temp); //virtual pin V3
Blynk.virtualWrite(V4, Fahrenheit); //virtual pin V4
DS18B20.begin();
timer.setInterval(1000L, getdata);
ebda3
October 3, 2021, 6:02pm
9
This is my code it works fine but there is a difference of 4 degrees
John93
October 3, 2021, 6:03pm
10
By the way, there’s some mistakes in your sketch for example there’s 2 blynk.run in your void loop.
ebda3
October 3, 2021, 6:04pm
11
Thank you, I know, but it is not the cause of the temperature difference
John93
October 3, 2021, 6:06pm
12
Can you try the sketch I just sent you please ?
ebda3
October 3, 2021, 6:07pm
13
Well, I will give it a try
How do you know this? What type of device are you using to measure the temperature, and how accurate is it, and when was it last calibrated?
Standard ds18b20 sensors have a ±0.5°C accuracy, but this can be 0.1°C for the clinical version of the sensor.
However, I think you’re confusing accuracy with calibrated accuracy.
If you have a reference thermometer which you know to be accurate then you can introduce a calibration factor into your sketch to ensure that the ds18b20 gives the same results as the reference thermometer. The ds18b20‘s calibrated readings should then be accurate to within half a degree of the reference thermometer.
ebda3
October 3, 2021, 7:13pm
17
Thank you Pete, I knew the temperature difference compared to the air conditioner in the cold room
ebda3
October 3, 2021, 7:16pm
18
Do you mean that I reduce the excess difference by means of a variable? I did that and when the room temperature changed, the match was different. Unfortunately, I tried several ds18b20 sensors, but the same result
Is that a regular domestic AC unit?
If so then they are VERY inaccurate, and have a very wide hysteresis setting (the temperature at when the AC kicks in and out) so that they aren’t constantly switching the compressor on/off.
Yes
Probably because the temperature in the room is varying massively, due to the intentional insensitivity of the AC unit
You’re wasting your time unless you have a calibrated reference thermometer.
ebda3
October 3, 2021, 8:06pm
20
It is a unit manufactured with international standards made in Turkey, not a local manufacture dedicated to preserving the corona vaccine
