Hi
I have an issue with the below code as if I program it and then check it on serial monitor I see that it keeps restarting.
It also says ISR not in IRAM!
User exception (panic/abort/assert)
Abort called
Any solution as I just cant seemed to get it working.
Widgets Pins
V0-Display
V1-Display
V3-Button(clear)
V4-Button(pump)
V5-Menu
V6-RTC
V7-LCD
V10-Table
#define BLYNK_DEBUG // Comment this out to disable debug and save space
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h> // For OTA with ESP8266
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Ticker.h> //for LED status
Ticker ticker;
char auth[] = "xxx";
char ssid[] ="xxx";
char pass[] ="xxx";
WidgetRTC rtc;
//BLYNK_ATTACH_WIDGET(rtc, V6)
WidgetTerminal terminal(V2);
WidgetLCD lcd(V7);
bool simulation = false;
byte sensorInterrupt = 4; // WeMos & NodeMCU D2
byte sensorPin = 4; // WeMos & NodeMCU D2
byte pumpInterrupt = 5; //2; //5; // WeMos D1 ModeMCU D3
byte pumpPin = 5; //2; //5; // WeMos D1 ModeMCU D3
// The hall-effect flow sensor outputs approximately 0.066 pulses per second per litre/minute of flow.
float calibrationFactor = 0.066;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
#define averageperiod 5 // currently set to average the flow every 5 seconds
int countseconds = 0; // count up to averageperiod
int averageflow = 0; // used for averaging flow over averageperiod
bool notificationsent = false; // to ensure just one message for each flow start
bool pumpState = false; // pump is OFF on start up
bool masterState = false; //
bool flowoffprintonce = false; // to ensure just one serial and terminal print for each flow stop
int rowIndex = 0; //Saurabh
String currentDate ;
String daybefore;
int rtctimer = 1; //check if RTC is OK and then disable / delete this #1 timer
int currentDatesi = 0; //Saurabh simulation
int daybeforesi=currentDatesi;
int menu=0;
int s;
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, SERVER, PORT);
ArduinoOTA.begin(); // For OTA
Serial.println();
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pinMode(pumpPin, OUTPUT);
digitalWrite(pumpPin, LOW); // ACTIVE HIGH, pump relay set to OFF on restart
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
flowRate = 0.0;
if(simulation == true){
pulseCount = 47;
else{
pulseCount = 0;
// Configured to trigger on a FALLING state change (transition from HIGH state to LOW state)
//attachInterrupt(sensorInterrupt, PulseCounter, FALLING);//FALLING
// Configured to trigger on a CHANGE state change LOW to HIGH or HIGH to LOW
attachInterrupt(pumpInterrupt, pumpToggle, CHANGE);
rtc.begin();
terminal.println("Connected to Blynk");
terminal.println(WiFi.localIP());
terminal.flush();
timer.setInterval(1000L, showFlow);
timer.setInterval(100L, pumpControl); // check if pump needs to be switched ON or OFF every 0.1s
rtctimer = timer.setInterval(2000L, checkRTC); // check every 2s if RTC is correct
BLYNK_CONNECTED() {
Blynk.syncVirtual(V5);
Blynk.syncVirtual(V4);
void showFlow() // average the flow over averageperiod
detachInterrupt(sensorInterrupt); // Disable the interrupt while calculating flow rate and sending the value to the host
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the ml passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.print("mL");
Serial.print(totalMilliLitres/1000);
Serial.println("L");
if(simulation != true){
pulseCount = 0; // Reset the pulse counter so we can start incrementing again
countseconds++;
if(countseconds > 0){ // used to skip the first rogue data flow reading
averageflow = averageflow + flowRate; // used to calculate the average flow over averageperiod cycles
if(countseconds == averageperiod){
Serial.print("Average water flow in litres / M is ");
Serial.println(averageflow / averageperiod);
Blynk.virtualWrite(V0, int(averageflow) / averageperiod);
Blynk.virtualWrite(V1, totalMilliLitres/1000);
countseconds = 0; // reset the counter
chkFlow();
averageflow = 0; // reset the average but only after chkFlow() function
//attachInterrupt(sensorInterrupt, PulseCounter, FALLING); // Enable the interrupt again now that we've finished sending output
void chkFlow(){
if((averageflow > 3) && (notificationsent == false)){ // guess of a decent water pressure
Serial.println("Water IS flowing.");
lcd.clear();
lcd.print(0,0,"Water is flowing");
Blynk.email("Water Flow Sensor", "Water IS flowing.");
Blynk.notify("Sensor: Water IS flowing.");
notificationsent = true; // stop getting messages until water stops flowing and starts again
flowoffprintonce = false; // when water stops flowing again we can restart serial and terminal print (once)
if((averageflow <= 3)&& (flowoffprintonce == false)){
Serial.println("Water is NOT flowing.");
lcd.clear();
lcd.print(1,0,"Water is NOT");
lcd.print(4,1,"flowing");
notificationsent = false; // when water starts flowing again we can send another notification
flowoffprintonce = true; // stop serial and terminal prints after first pass of water stopping
s=0;
if(averageflow <= 3){
digitalWrite(pumpPin, LOW); // turn off pump //s*
if(averageflow>3 && menu == 1){
digitalWrite(pumpPin, HIGH); // turn on pump //s*
Blynk.virtualWrite(V8, "ON");
Blynk.virtualWrite(V4, 1); // update app button on V4 COSTAS//s*
void ICACHE_RAM_ATTR pulseCounter()
pulseCount++; // Increment the pulse counter
void pumpToggle(){ // toggle just pumpState OFF and ON from pin interrupt
pumpState = !pumpState; // don't do anything else in this function or the system will crash
//Serial.println(pumpState); // for debugging only TODO comment this out later
void pumpControl() // toggle pump OFF and ON
detachInterrupt(pumpInterrupt); // disable interrupt
if(pumpState == masterState){
// do nothing
else{
masterState = pumpState;
if(pumpState == true){
// Blynk.setProperty(V8, "color","#48E06B");
Serial.println("Pump turned ON");
else{
Blynk.virtualWrite(V4, 0);
Blynk.virtualWrite(V8, "OFF");
// Blynk.setProperty(V8, "color","#04C0F8");
Serial.println("Pump turned OFF");
terminal.flush();
attachInterrupt(pumpInterrupt, pumpToggle, CHANGE); // enable pump pin interrupt
void checkRTC(){
if(year() != 1970){
timer.disable(rtctimer); // disable rtctimer now RTC is ok
//rtcupdated = true; // can be commented out as checkRTC will stop when RTC is ok
currentDate = String(day()) + "/" + month() + "/" + year(); // etc
terminal.println("RTC started");
daybefore=currentDate;
timer.setInterval(60000L, table); //start table() now RTC is OK
void table() //Saurabh
if(currentDate != daybefore)
//currentDate = String(day()) + "/" + month() + "/" + year();
Blynk.virtualWrite(V10, "add", rowIndex,daybefore,totalMilliLitres/1000+String(" litre")); //Saurabh
Blynk.virtualWrite(V1, 0);
Serial.println("working");
BLYNK_WRITE(V3){ // reset with button in PUSH mode on virtual pin 3
int resetdata = param.asInt();
if(resetdata == 1){
Serial.println("Clearing data");
Blynk.virtualWrite(V0, 0);
averageflow = 0;
countseconds = 0;
BLYNK_WRITE(V20){ // reset with button in PUSH mode on virtual pin 20
if(resetdata == 1){
Serial.println("Clearing table data");
Blynk.virtualWrite(V10, "clr");
BLYNK_WRITE(V4){ // Button in SWITCH mode on virtual pin 4 to control relay
int controlRelay = param.asInt();
if(controlRelay == 1){
digitalWrite(pumpPin, HIGH); // turn relay ON
// Blynk.virtualWrite(V8, "ON");
else{
digitalWrite(pumpPin, LOW); // turn relay OFF
//Blynk.virtualWrite(V8, "OFF");
pumpControl();
BLYNK_WRITE(V5)
switch(param.asInt()){
case 1:{
lcd.clear();
lcd.print(1,0,"Automatic Mode");
lcd.print(5,1,"Selected");
menu=1;
break;
case 2:{
lcd.clear();
lcd.print(3,0,"Manual Mode");
menu=0;
break;
void loop(){
