Your project looks awesome, but I don’t have hardware to build it.
So I just like to contribute somehow, hopefully I’ll build it later, by modifying your code, posted by @magnum1795, as follows.
It’s compiled OK. Hopefully it’ll run OK as well.
Note
It’s currently written for ESP32, to use Blynk_WM library, SSL as well as local Blynk Server.
Please change the following #define’s (to true or false) to suit your application
#define USE_BLYNK_WM true
#define USE_SSL false
#define USE_LOCAL_SERVER true
The code
#ifndef ESP32
#error This code is intended to run on the ESP32 platform! Please check your Tools->Board setting.
#endif
#if USE_SSL
#include <WiFiClientSecure.h>
#else
#include <WiFiClient.h>
#endif
#if USE_BLYNK_WM
// Not use #define USE_SPIFFS => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS false => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS true => using SPIFFS for configuration data in WiFiManager
// Be sure to define USE_SPIFFS before #include <BlynkSimpleEsp8266_WM.h>
//#define USE_SPIFFS true
#if (!USE_SPIFFS)
// EEPROM_SIZE must be <= 4096 and >= CONFIG_DATA_SIZE (currently 172 bytes)
#define EEPROM_SIZE (4 * 1024)
// EEPROM_START + CONFIG_DATA_SIZE must be <= EEPROM_SIZE
#define EEPROM_START 2048
#endif
// Force some params in Blynk, only valid for library version 1.0.1 and later
#define TIMEOUT_RECONNECT_WIFI 10000L
#define RESET_IF_CONFIG_TIMEOUT true
#define CONFIG_TIMEOUT_RETRYTIMES_BEFORE_RESET 5
// Those above #define's must be placed before #include <BlynkSimpleEsp8266_WM.h>
#if USE_SSL
#include <BlynkSimpleEsp32_SSL_WM.h> // https://github.com/khoih-prog/Blynk_WM
#else
#include <BlynkSimpleEsp32_WM.h> // https://github.com/khoih-prog/Blynk_WM
#endif
#else
#if USE_SSL
#include <BlynkSimpleEsp32_SSL.h>
#define BLYNK_SERVER_HARDWARE_PORT 9443 // blynk server SSL port
#else
#include <BlynkSimpleEsp32.h>
#define BLYNK_SERVER_HARDWARE_PORT 8080 // blynk server port
#endif
char ssid[] = ""; // wifi SSID
char pass[] = ""; // wifi password
#if USE_LOCAL_SERVER
char auth[] = ""; // Local Blynk server token
char server[] = "accout.duckdns.org"; // blynk server
#else
char auth[] = ""; //Cloud Blynk server token
char server[] = "blynk-cloud.com"; // Cloud Blynk server
#endif
#endif
#include <WidgetRTC.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <BME280I2C.h> //https://github.com/finitespace/BME280/tree/master/src
#include <Wire.h>
BME280I2C bme;
#define uS_TO_S_FACTOR 1000000
#define TIME_TO_SLEEP 600 //set deep sleep time (in seconds)
#define COUNT_PERIOD 5000 // measure interval (ms)
#define RAIN_COUNT_PERIOD ( 24L * 3600L * 1000L ) // One day
// 50ms debouncing time
#define DEBOUNCE_TIME 50
#define RADIUS (90.0f) // in mm
#define PIxRADIUS (PI * 90.0)
#define RAIN_AMOUNT (0.3f) // Precipitation
#define VOLT_DETECTION_PIN 34 // voltage detection pin number
#define RAIN_GAUGE_PIN 14 // Rain pin number
#define WIND_SPEED_PIN 35 // wind speed pin number
#define UV_INDEX_PIN 36 // UV Index detection pin number
#define WIND_DIRECTION_PIN 39 // Wind direction pin number
#define BLYNK_VPIN_WIND_DIRECTION V1
#define BLYNK_VPIN_TEMP V2
#define BLYNK_VPIN_WIND_SPEED V3
#define BLYNK_VPIN_HUMID V4
#define BLYNK_VPIN_RAIN_AMOUNT V5
#define BLYNK_VPIN_PRESSURE V6
#define BLYNK_VPIN_HALL_SENSOR V7
#define BLYNK_VPIN_WIND_DIRECTION_BIN V8
#define BLYNK_VPIN_CPU_TEMP1 V9
#define BLYNK_VPIN_CPU_TEMP2 V10
#define BLYNK_VPIN_BATT_VOLT V11
#define BLYNK_VPIN_UV_INDEX V12
#define BLYNK_VPIN_DEW_POINT1 V13
#define BLYNK_VPIN_DEW_POINT2 V14
#define BLYNK_VPIN_RSSI1 V15
#define BLYNK_VPIN_RSSI2 V16
//int delaytime = 2000; // Time between samples (miliseconds)
int Wdir = 0;
int measurement = 0;
int pinValue = 1;
unsigned int Sample = 0; // Sample number
unsigned int RPM = 0; // Revolutions per minute
float windSpeedMetrePerSec = 0; // Wind speed (m/s)
float windSpeedKmPerHr = 0; // Wind speed (km/h)
float voltage = (((float)analogRead(VOLT_DETECTION_PIN) * (3.3 / 4095)) * 2) + 0.24; // battery voltage
float UVIndex = ((float)analogRead(UV_INDEX_PIN) * (3.3 / 4095)) * 10; // UV Index GUVA-S12SD
float windDirection = ((float)analogRead(WIND_DIRECTION_PIN)); // Wind direction
volatile unsigned int counter = 0; // magnet counter for sensor
volatile unsigned int currentCount;
volatile float totalAmount = 0;
volatile float currRainAmount;
volatile long startTime;
volatile bool windDataReady = false;
volatile bool rainDataReady = false;
#ifdef __cplusplus
extern "C" {
#endif
uint8_t temprature_sens_read();
#ifdef __cplusplus
#endif
WidgetRTC rtc;
BLYNK_CONNECTED()
rtc.begin();
Blynk.syncAll();
void IRAM_ATTR RainSensor();
void IRAM_ATTR WindSpeedSensor();
pinMode(RAIN_GAUGE_PIN, INPUT);
pinMode(WIND_SPEED_PIN, INPUT);
pinMode(WIND_DIRECTION_PIN, INPUT);
pinMode(UV_INDEX_PIN, INPUT);
pinMode(VOLT_DETECTION_PIN, INPUT);
#if USE_BLYNK_WM
Blynk.begin("ESP32-Weather-Station");
#else
WiFi.mode(WIFI_STA);
Blynk.config(auth, server, BLYNK_SERVER_HARDWARE_PORT);
Blynk.connect();
#endif
ArduinoOTA.setHostname("Weather-Station");
ArduinoOTA.begin();
Blynk.setProperty(BLYNK_VPIN_WIND_DIRECTION, "rotation", Wdir);
Wire.begin();
while (!bme.begin()) //start BME 280
Serial.println("Could not find BMP280 sensor!");
delay(1000);
switch (bme.chipModel())
case BME280::ChipModel_BME280:
Serial.println("Found BMP280 sensor! Success.");
break;
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
break;
default:
Serial.println("Found UNKNOWN sensor! Error!");
timer.setInterval(300000L, sendSensor);
Sample++;
timer.setInterval(500L, measureAll);
attachInterrupt(digitalPinToInterrupt(WIND_SPEED_PIN), WindSpeedSensor, RISING);
attachInterrupt(digitalPinToInterrupt(RAIN_GAUGE_PIN), RainSensor, RISING);
// start timing
startTime = millis();
Blynk.run(); //start the Blynk sketch
timer.run(); //start the timer
ArduinoOTA.handle();
void measureAll()
WindDir();
RainCalc();
WindVelocity();
void sendSensor()
static float temp(NAN), hum(NAN), pres(NAN);
static float voltage; // battery voltage
static float UVIndex; // UV Index
static float windDirection; // Szélirány
static double gamma; // calculate dewpoint
static double dp; // calculate dewpoint
static long rssi; // read signal strength
measurement = hallRead();
BME280::TempUnit tempUnit(BME280::TempUnit_Celsius); // read BME 280
BME280::PresUnit presUnit(BME280::PresUnit_hPa); // read BME 280
bme.read(pres, temp, hum, tempUnit, presUnit); // read BME 280
windDirection = ((float)analogRead(WIND_DIRECTION_PIN)); // Szélirány
gamma = log(hum / 100) + ((17.62 * temp) / (243.5 + temp)); // calculate dewpoint
dp = 243 * gamma / (17.62 - gamma); // calculate dewpoint
rssi = WiFi.RSSI();
Blynk.setProperty(BLYNK_VPIN_WIND_DIRECTION, "rotation", Wdir); // image rotating to wind direction
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION, 1);
Blynk.virtualWrite(BLYNK_VPIN_TEMP, temp); //temperature
Blynk.virtualWrite(BLYNK_VPIN_WIND_SPEED, windSpeedKmPerHr); //Wind speed
Blynk.virtualWrite(BLYNK_VPIN_HUMID, hum); //humidity
Blynk.virtualWrite(BLYNK_VPIN_RAIN_AMOUNT, totalAmount); //Rain amount
Blynk.virtualWrite(BLYNK_VPIN_PRESSURE, pres); //pressure
Blynk.virtualWrite(BLYNK_VPIN_HALL_SENSOR, measurement); //hallsensor
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION_BIN, windDirection); //Wind direction binary (test function)
Blynk.virtualWrite(BLYNK_VPIN_CPU_TEMP1, (temprature_sens_read() - 32) / 1.8); //CPU Temp
Blynk.virtualWrite(BLYNK_VPIN_CPU_TEMP2, (temprature_sens_read() - 32) / 1.8); //CPU Temp
Blynk.virtualWrite(BLYNK_VPIN_BATT_VOLT, voltage); //Battery Voltage
Blynk.virtualWrite(BLYNK_VPIN_UV_INDEX, UVIndex); //UV index
Blynk.virtualWrite(BLYNK_VPIN_DEW_POINT1, dp); //Dew point
Blynk.virtualWrite(BLYNK_VPIN_DEW_POINT2, dp); //Dew point
Blynk.virtualWrite(BLYNK_VPIN_RSSI1, rssi); //rssi
Blynk.virtualWrite(BLYNK_VPIN_RSSI2, rssi); //rssi
// Serial.println("Sleeping now !);
// delay(500);
// esp_sleep_enable_timer_wakeup((uint64_t)TIME_TO_SLEEP * uS_TO_S_FACTOR); //set deepsleep time
// esp_deep_sleep_start(); //deepsleep start
// delay(100);
void WindDir()
if (windDirection < 190)
Wdir = 270; // W
else if (windDirection < 420)
Wdir = 315; // NW
else if (windDirection < 700)
Wdir = 292.5; // W-NW
else if (windDirection < 900)
Wdir = 0; // N
else if (windDirection < 1300)
Wdir = 337.5; // N-NW
else if (windDirection < 1500)
Wdir = 225; // SW
else if (windDirection < 1600)
Wdir = 247.5; // W-SW
else if (windDirection < 2250)
Wdir = 45; // NE
else if (windDirection < 2400)
Wdir = 22.5; // N-NE
else if (windDirection < 2900)
Wdir = 180; // S
else if (windDirection < 3100)
Wdir = 202.5; // S-SW
else if (windDirection < 3400)
Wdir = 135; // SE
else if (windDirection < 3600)
Wdir = 157.5; // S-SE
else if (windDirection < 3840)
Wdir = 90; // E
else if (windDirection < 3950)
Wdir = 67, 5; // E-NE
else if (windDirection < 4095)
Wdir = 112.5; // E-SE
Wdir = 0; // N
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION, 1); // image number
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION_BIN, windDirection); // wind direction binary (test function)
bool dayStart = false;
void RainCalc()
static float totalRainAmount;
// Reset within 10s after boot or at around beginning of every day (12AM), have 60 s to do
if ( !dayStart && ( (millis() < 10000 ) || ( (hour() == 0) && (minute() == 0) ) ) )
dayStart = true;
noInterrupts();
totalAmount = 0;
interrupts();
// Prepare for next day at 1AM
if ( dayStart && (hour() == 1) )
dayStart = false;
noInterrupts();
totalRainAmount = totalAmount;
interrupts();
Blynk.virtualWrite(BLYNK_VPIN_RAIN_AMOUNT, totalRainAmount); // Rain amount
static long lastMillis = 0;
static long currMillis;
currMillis = millis();
if (currMillis >= lastMillis + DEBOUNCE_TIME)
totalAmount += RAIN_AMOUNT;
lastMillis = currMillis;
void WindVelocity()
if (windDataReady)
noInterrupts();
// COUNT_PERIOD = 5000 = 5s
//RPM = ((currentCount) * 60) / (COUNT_PERIOD / 1000); // Calculate revolutions per minute (RPM)
RPM = ( currentCount * 12 );
interrupts();
//windSpeedKmPerHr = ((4 * PIxRADIUS * RPM) / 60) / 1000; // Calculate wind speed on m/s
windSpeedMetrePerSec = (RPM * PIxRADIUS) / 15000;
windSpeedKmPerHr = windSpeedMetrePerSec * 3.6; // Calculate wind speed on km/h
Blynk.virtualWrite(BLYNK_VPIN_WIND_SPEED, windSpeedKmPerHr); // Wind speed sending
counter++;
if (currMillis >= startTime + COUNT_PERIOD )
startTime = currMillis;
currentCount = counter;
counter = 0;
windDataReady = true;
Please let us know if it’s running OK.
Regards,
