Hi Guys
Hoping you can help again. Thanks PeterKnight for the previous assistance.
I had my Blynk working well but occasionally WiFi would drop out and I had to restart it by powering down and up again.
That’s fine but the whole idea was to have it working while I was away.
I found this segment of program that would check it if it went down and it would restart.
Well I have inserted it into my program but I keep getting a compilation error of "a function-definition is not allowed here
before token"
The pink bar appears below the line Blynk_Write(V4).
If I delete that entire segement assuming it is faulty, the error appears just after the previous Blynk_Write(V3).
I have looked everywhere to find the problem but to no avail.
Could someone please assist in where I have gone wrong?.
Thanks in advance
Chrisk
// Sketch name - GHA03 8/03/2026 16:30
// Added auto-reconnect after loss of Wifi
// Added STOP to be able to halt current process - open circuits power to timers
// This a new version after boot interference with old outputs
// This program allows the control of four seperate relays via the Mobile Blynk App
// Sketch names must not have spaces in the name
#include <dummy.h>
#define BLYNK_TEMPLATE_ID "XXXXXX" // My Template ID gained from Blynk Template
#define BLYNK_TEMPLATE_NAME "XXXXX" // My Template Name gained also from Blynk Template
#define BLYNK_AUTH_TOKEN "XXXXXi" // My Blynk Authority Token for GHWater gained from Blynk Template
#include <ESP8266WiFi.h> // Use this library
#include <BlynkSimpleEsp8266.h> // Use this library
const char ssid[] = "XX"; // My network name
const char password[] = "XX"; // My network passwordword
pinMode(D8, OUTPUT); //GPIO 15 Water Left
pinMode(D2, OUTPUT); //GPIO 04 Water Right
pinMode(D5, OUTPUT); //GPIO 14 Misting
pinMode(D7, OUTPUT); //GPIO 13 Water Enable
pinMode(D6, OUTPUT); //GPIO 12 ALL STOPPED
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, password);
WiFi.begin(ssid, password);
// Enable auto-reconnect
WiFi.setAutoReconnect(true);
WiFi.persistent(true);
delay(500);
Serial.print(".");
Serial.println("Connected!");
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Disconnected, waiting for reconnection...");
// Program starts below
BLYNK_WRITE(V0) // A write to pin D8 - Water Left
int value = param.asInt(); // Get interger value from V0
Serial.println(value); // Used to display value in Serial Monitor in Tools
if (value == 0)
digitalWrite(D8, LOW); // Setting Digital PIN LOW to turn OFF device if relay module is "active high"
Serial.println("Water Left OFF");
if (value == 1)
digitalWrite(D8, HIGH); //Setting Digital PIN HIGH to turn ON device if relay module is "active high"
Serial.println("Water Left ON");
BLYNK_WRITE(V1) // A write to pin D2 - Water Right
if (value == 0)
digitalWrite(D2, LOW);
Serial.println("Water Right OFF");
if (value == 1)
digitalWrite(D2, HIGH);
Serial.println("Water Right ON");
BLYNK_WRITE(V2) // A write to pin D5 - Mist
if (value == 0)
digitalWrite(D5, LOW);
Serial.println("Mist OFF");
if (value == 1)
digitalWrite(D5, HIGH);
Serial.println("Mist ON");
BLYNK_WRITE(V3) // A write to pin D7 - Water Enable
if (value == 0)
digitalWrite(D7, LOW);
Serial.println("Water Enable OFF");
if (value == 1)
digitalWrite(D7, HIGH);
Serial.println("Water Enable ON");
BLYNK_WRITE(V4) // A write to pin D6 - All STOPPED
if (value == 0)
digitalWrite(D6, LOW);
if (value == 1)
digitalWrite(D6, HIGH);
delay(10000) // Check every 10 seconds for WiFi connection
