Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
#include <ESP8266_Lib.h>
char auth[] = "9855d902dbef4926a71e25b5e0ff610a";
char ssid[] = "LenovoA850+";
char pass[] = "88ec0b32b7ac";
int offset =20;// set the correction offset value
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
BLYNK_WRITE(V0)
if (param.asInt()) {
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
BLYNK_WRITE(V1)
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
BLYNK_WRITE(V2)
digitalWrite(6, HIGH);
digitalWrite(6, LOW);
BLYNK_WRITE(V3)
digitalWrite(7, HIGH);
digitalWrite(7, LOW);
int volt = analogRead(A0);// read the input
double voltage = map(volt,0,1023, 0, 2500) + offset;// map 0-1023 to 0-2500 and add correction offset
voltage /=100;// divide by 100 to get the decimal values
Serial.print("Voltage: ");
Serial.print(voltage);//print the voltge
Serial.println("V");
Blynk.virtualWrite(V4, voltage);
delay(500);
