hey guys,
I have problems with the push notifications example sketch. I cloned the newest github library and build the library on my raspberry pi. I wrote this simple program to send me a notification when the Blynk program gets started on my raspberry pi.
but after that nothing happens, I donât get any notifications, but my raspberry pi is listed as âonlineâ.
After a few seconds my raspberry pi is listed as âofflineâ.
Could you please help me?
But⌠Whatâs it supposed to do? I donât have an RPi myself, but your code kinda looks like the âsystem defaultâ sketch which does ⌠nothing!
yes it is the default sketch, but I want to first test the push notification command.
I added Blynk.notify in the setup function, but the notification never reaches my smartphone (Android).
Interestingly I get a message whenever I close the Blynk sketch. (Offline warning)
I tried the notification interval sketch but unfortunately the sketch doesnât compile:
main.cpp: In function âvoid notifyUptime()â:
main.cpp:25:37: error: âStringâ was not declared in this scope
Blynk.notify(String("Running for ") + uptime + " minutes.");
Makefile:70: recipe for target 'main.o' failed
make: *** [main.o] Error 1
http://twitter.com/blynk_app
Simple push notification example
App project setup:
Push widget
Connect a button to pin 2 and GND...
Pressing this button will also push a message! ;)
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
void notifyUptime()
long uptime = millis() / 60000L;
// Actually send the message.
// Note:
// We allow 1 notification per 15 seconds for now.
// Notify immediately on startup
Blynk.notify("Device started");
// Setup a function to be called every minute
timer.setInterval(60000L, notifyUptime);
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
```cpp
Have you installed the latest App version? there were some prior (and heavily mentioned in this forum) notification issues that have since been resolved.
