Problem with email widget on Android
Hi there. I’m still having the same problem than posted by “NotAClue” 3 months ago, but on Android. No matter which email address I write into the “TO”-field nor what I’m encoding in sketch, it’s allways using my account’s email address. All was running well until the release which changed the behaviour of this “TO”-field in the Blynk.email widget. I learned this problem should have been fixed, but obviously there is still something wrong. I’m using the latest Blynk version on Android. Any help is very apreciated.
Best regards
Carlo
I’ve moved this to a new topic, as it’s clearly not the same issue as the iOS thread that you posted in originally.
What version exactly?
Hello Pete,
It’s 2.27.8
Carlo
@Carlo1 It looks like the problem has been identified and a fix will be deployed soon. See Send email to wrong address for details.
@Cemtes & @Pete Knight Thank you very much for your help!
The issue should be fixed now.
@Dmytro
Now it’s working perfectly (again) !
Thank you very much !
Carlo
