Could someone please help me with this code, I got it from here but I don’t remember where honestly, it works, in the sense that it allows me to choose the network through the wifimanager interface, on the mobile I made four buttons and also on the web dashboard , they all work, that is, if I turn the mobile on or off, the same thing happens on the dashboard and vice versa, but I see that I’m offline on the dashboard, and if I try to turn an LED on or off, for example in a GPIO of ESP, nothing happens , what I intend is to have an interface to connect from any network where I am, and be able to trigger an LED, if anyone knows a better idea I would appreciate it.
Thanks.
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <DNSServer.h>
#define BLYNK_TEMPLATE_ID "T"
#define BLYNK_DEVICE_NAME "4 reles"
#define BLYNK_AUTH_TOKEN "X"
char auth[] = "XphuvSVTS5ymcH7Sbs8BPrEybxxrakDR";
char ssid[] = "NET"; // username or ssid of your WI-FI
char pass[] = "xxxxxx"; // password of your Wi-Fi
// Set your LED and physical button pins here
const int ledPin1 = 12;
const int ledPin2 = 13;
const int ledPin3 = 14;
const int ledPin4 = 2;
const int btnPin1 = 5;
const int btnPin2 = 4;
const int btnPin3 = 0;
const int btnPin4 = 1;
void checkPhysicalButton();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V12);
Blynk.syncVirtual(V13);
Blynk.syncVirtual(V14);
Blynk.syncVirtual(V15);
// Alternatively, you could override server state using:
Blynk.virtualWrite(V12, led1State);
Blynk.virtualWrite(V13, led2State);
Blynk.virtualWrite(V14, led3State);
Blynk.virtualWrite(V15, led4State);
// When App button is pushed - switch the state
BLYNK_WRITE(V12) {
led1State = param.asInt();
digitalWrite(ledPin1, led1State);
BLYNK_WRITE(V13) {
led2State = param.asInt();
digitalWrite(ledPin2, led2State);
BLYNK_WRITE(V14) {
led3State = param.asInt();
digitalWrite(ledPin3, led3State);
BLYNK_WRITE(V15) {
led4State = param.asInt();
digitalWrite(ledPin4, led4State);
if (digitalRead(btnPin1) == LOW) {
// btn1State is used to avoid sequential toggles
if (btn1State != LOW) {
// Toggle LED state
led1State = !led1State;
// Update Button Widget
btn1State = LOW;
btn1State = HIGH;
if (digitalRead(btnPin2) == LOW) {
if (btn2State != LOW) {
// Toggle LED state
led2State = !led2State;
btn2State = LOW;
btn2State = HIGH;
if (digitalRead(btnPin3) == LOW) {
if (btn3State != LOW) {
// Toggle LED state
led3State = !led3State;
btn3State = LOW;
btn3State = HIGH;
if (digitalRead(btnPin4) == LOW) {
if (btn4State != LOW) {
// Toggle LED state
led4State = !led4State;
btn4State = LOW;
btn4State = HIGH;
WiFiManager wifiManager;
wifiManager.autoConnect("AutoConnectAP");
Serial.println("");
Serial.println("wifi connected...yeey :");
Serial.println("IP address:");
Blynk.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str());
pinMode(ledPin1, OUTPUT);
pinMode(btnPin1, INPUT_PULLUP);
pinMode(ledPin2, OUTPUT);
pinMode(btnPin2, INPUT_PULLUP);
pinMode(ledPin3, OUTPUT);
pinMode(btnPin3, INPUT_PULLUP);
pinMode(ledPin4, OUTPUT);
pinMode(btnPin4, INPUT_PULLUP);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
