I am in need of some help. I am monitoring the temp and humidity in a greenhouse and I got the deep sleep to work on my ESp8266 D1 mini board but it does not send the sensor data using this code. Can anyone please help me with this ? Any help would be appreciated.
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(true); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,60), 9443);
dht.begin();
timer.setInterval(60000L, sendSensor);
ESP.deepSleep(600 * 1000000,WAKE_RF_DEFAULT); //try the default mode
delay(100);
