I am new to Arduino and I am needing some help. I ordered WeMos D1 Mini and a DHT11 for temperature and humidity monitoring. I am also wanting to monitor soil moisture and activate a relay for a 12v pump when the soil moisture is low. Any help with this would be greatly appreciated.
Would you like to have a look at
Thanks for the quick reply ! Did you develop this code ?
Please don’t blame me if something goes wrong
LOL ! I am not going to… Thank you for the code though I appreciate it. Do you have any diagrams on what pins to connect the sensors to ?
All inside the code, but here it is the link
and the code snippet
#if USE_ESP32
//#define PIN_RESET PIN_D0 //16
#define DHTPIN PIN_D22 // pin DATA @ D22 / GPIO22
#define PUMP_RELAY_PIN PIN_D23 // PUMP RELAY @ D21
#define SOIL_MOIST_PIN PIN_D32 // pin GPIO32 for analog input
#else //USE_ESP32
#define DHTPIN PIN_D2 // pin DATA @ D2
#define PUMP_RELAY_PIN PIN_D1 // PUMP RELAY @ D1
#define SOIL_MOIST_PIN A0 // pin A0 with A0
#endif //USE_ESP32
Hope you’ll later send me some vegetables from your greenhouse if it’s working.
So I need to order a esp32 board. I have a esp12 on order right now. I am sorry if these are stupid questions. just learning. Thanks for all the info
No, you just use WeMos D1 Mini. The code is written for both ESP8266 (such as WeMos D1 Mini) and ESP32.
The default config is for ESP8266:
//Ported to ESP32
//#define USE_ESP32 true
#define USE_ESP32 false
So you just compile and use as is.
okay cool… I really appreciate all the help
Khoih I have a question. I am just using the basic sketch for the DHT11 for my greenhouse right now. I am wanting to put this in deep sleep with a 10 minute delay. It is on a ESP8266 D1 Mini board. The sketch I am using is from the blynk sketch browser. Could you please tell me how I could go about doing this ?
You can just use the SmartFarm-DeepSleep code as is, then select DHT11 as the sensor.
If you’d like and have time + energy, you can either
- copy the DeepSleep code portion to your basic sketch
- or delete the unnecessary code
Thats where I was getting confused. New to this and didnt know where the deep sleep code needed to be placed in the sketch. I will also have to place a jumper to the rst pin correct ?
I’m sorry I’m so busy right now and can’t help you with the code. You have to start trying the best you can, then someone will help guide you to finish.
I don’t know if @Madhukesh can help you now.
Its okay… I will search youtube and give it a go. I appreciate all the help you have given me to this point. Thanks !
I am afraid to help you on this, because i have not worked on deep sleep. But i will give it a try.
As @khoih said delete the lines which are not necessary. Each section has been commented with info on what it does, if you give enough time and study the code you can get it working.
Yes connect RST pin to GPIO16
void deep_sleep() {
Blynk.disconnect();
WiFi.mode(WIFI_OFF);
ESP.deepSleep(60000000); \\ 60 Seconds
Call this function once you have got the readings from the sensor.
This is all you need to put the ESP in deep sleep and wake up again at set interval.
I would say better start with a simple deep sleep sketch and once you get it working you can add it to Blynk. Once you have a basic code you can post it here and we can help you.
@khoih correct me if am wrong.
This is the code that I am currently running. It goes into deep sleep but it never send the temp or humidity values to blynk.
You’ve not done the triple backtick thing again, so I’ve removed your code.
Please keep the discussion about this subject to one topic, rather than the two that you have created. I’ll merge the other topic into this one to keep everything together.
I am in need of some help. I am monitoring the temp and humidity in a greenhouse and I got the deep sleep to work on my ESp8266 D1 mini board but it does not send the sensor data using this code. Can anyone please help me with this ? Any help would be appreciated.
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(true); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,60), 9443);
dht.begin();
timer.setInterval(60000L, sendSensor);
ESP.deepSleep(600 * 1000000,WAKE_RF_DEFAULT); //try the default mode
delay(100);
@swtrpeter please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Sorry about that
