Building the UI for a tiles template. The assignment of the pin keeps disappearing. after assigning the pin. See screen shots below.
Select “all zones on/off time to edit pin assignment” - not showing any pin assignment on the label widget although I have previously assigned it to V20.
This is happening on all pin assignments on this UI for this template and other templates on the tile widget. Assignments stick OK on widgets on the main project - see below for the timer widget placed below the tile widget.
Are you running Local Server? If so make sure you have latest update (v0.36.3)… Keeping updated is an absolute requirement to allow any changes or refinements with new App updates. This has bitten me a few times for forgetting to update my server before the App
Some further possible info. Not sure if this was a coincidence. All was going ok. Widgets were retaining the visual assignment. Then I upgraded the android blynk app. Then the visual assignment started to disappear. I’ve not connected the device yet so I’m not sure if the actual assignment is lost or just the visual assignment. My guess is just the visual assignment.
