pabou
February 3, 2024, 8:34am
1
Hello …
Is there a way to create a multi line text widget that is “persistent”, ie displayed each time the smartphone application is started
terminal does not seen to retain “previous” line written, before the smartphone app is closed
labeled value allows text and is persistent, but it does not seem to handle \n
Or is this somehow the responsability of the device’s application to make the widget persistent ?
Hello @pabou . You use Android or iOS Blynk IoT app?
It retains data for Android app. I confirm the same
Dmytro
February 3, 2024, 7:12pm
4
Hello. It does for Plus (10 lines limit) / Pro (25 lines limit) plans.
So just to clarify - for a Free Plan, a retained display (after the app closes then reopens) doesn’t apply to IOS or Android terminal widgets? I’m asking due to the reference about Plus & Pro Plans above…
pabou
February 5, 2024, 11:32am
6
Hello …
yes it does. My mistake. It works fine on Android.
pabou
February 5, 2024, 11:33am
7
hello
My appologies. It does work (I’m on android).
Hello @pabou . What app version?
Also issue after what method update value in terminal widget? Manually, via HTTP API or hardware?
@pabou I checked in Maker acc, not reproduced for me in Android Blynk IoT app 1.15.1 (179) 30.01.2024
If it’s still reproducing for you, please read Recommendations for creating a new topic in Forum
Need additional information for this issue:
Blynk IoT app version.
What settings in your datastream and in terminal widget?
How do you update the values?
Exact steps to reproduce.
Preferably a video of the bug being reproduced.
And another possible information.
Regards
