Hello guys,
Is anyway to get Blynk OTA working for MKR1010 + MKR Ethernet Shield?
Thanks,
Max
Hello guys,
Thanks,
Max
Currently, OTA can only work over WiFi.
Is anyway to make it working through Ethernet?
Is it just Embedded source code to be changed Or bootloader and cloud as well?
Regards,
Max
I’ve never tried it but I guess you can use ArduinoOTA library to update the firmware over ethernet.
Check the examples.
you could adapt this for Ethernet with my ArduinoOTA library
Hello John93, Juraj,
Thank you for help.
I will take a look.
Regards,
Max
Hello guys,
Have got Blynk OTA working fine for MKR1010 with both WiFi and Ethernet.
Thank you.
Regards,
Max
