I worked out how the Blynk LED works by trial an error. Initially I thought an output of LOW\HIGH or 0\1 would make the LED light up but I was mistaken.
It appears the the LED in the Blynk app has brightness control. It’s not just an on/off LED!
The value range is 0 to 1023.
If you configure an LED to be connected to Virtual Pin 2 the Arduino code is:
Blynk.virtualWrite(2, 0); //turn off
Blynk.virtualWrite(2, 1023); //turn on - 100% brightness
Blynk.virtualWrite(2, 511); //50% brightness
A complete Arduino script to alternatively flash two LED’s on the Blynk App looks like this:
#include <Ethernet.h>
int ledState = LOW; // ledState used to set the LED
int VirtualPinA = 0;
int VirtualPinB = 1;
const long interval = 1000; // interval at which to blink (milliseconds)
unsigned long previousMillis = 0; // will store last time LED was updated
char auth[] = "xxxx";
Blynk.begin(auth);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
if (ledState == LOW) {
ledState = HIGH;
Blynk.virtualWrite(VirtualPinA, 0);
Blynk.virtualWrite(VirtualPinB, 1023);
ledState = LOW;
Blynk.virtualWrite(VirtualPinA, 1023);
Blynk.virtualWrite(VirtualPinB, 0);
