I just built an 8 head peristaltic dosing pump Project. In the code, a value is passed to the hardware from some Step widgets and a button, and math is performed with preset values, the output of which determines the duration of time that each motor spins for. That said, I would like the ability to adjust the preset values in the code so I can recalibrate each motor.
For my project, I only need to generate a string of 3 numbers, but perhaps other projects will become more workable if certain values can be manipulated ‘on the fly’. What I have in mind is like the bicycle chain locks from the 1980s where the lock was built right onto the chain. This was a combination lock that consisted of a series of barrels or wheels with the numbers 0-9 embossed on each barrel. The number string between the lines on the lock was the combination to unlock the chain. A widget (of a defined string length) could be used to quickly dial in an exact value, then a button widget could be used in conjunction to pass the value on to hardware.
Just an idea. If anyone knows a work around, please let me know.
