Here is a weird one…using numeric input widget on a project and when I go to the settings to increment in 0.5 there is no decimal point option…when I create a new project and repeat the process the option appears??
Any ideas why?
The only difference I see between the two is that on the second screenshot where decimal is possible, you have already selected an output pin but in the first you haven’t.
I have had other widget s in the past behave oddly if you don’t select the pin first.
Thanks that worked.
Don’t forget the search option… ![]()
