Hi there,
i have my pretty simple bathroomdoor project setup and it is working pretty well:
Basically there is a swich that is closed when the door is locked. The NodeMCU then changes a Blynk Led Widget to red and back to green once the door is unlocked.
Doorswitch -> NodeMCU -> Blynk app
Now i wanted to add a notification when the door is unlocked and a notify switch is set to “On” in the app. This is also working fine.
void checkBathroomDoor()
// Invert state, since button is "Active LOW"
int d2state = !digitalRead(D2);
// Debounce mechanism
long t = millis();
if (d2state != prevState) {
lastChangeTime = t;
if (t - d2lastChangeTime > 50) {
if (d2state != d2currState) {
d2currState = d2state;
Blynk.virtualWrite(V0, state);
if (state == 1){
Blynk.setProperty(V5, "color", "#ff0000");
else {
Blynk.setProperty(V5, "color", "#00ff04");
if(v2State == 1){
Blynk.notify("The Bathroom is now free!");
Blynk.virtualWrite(V2, 0);
prevState = d2state;
But since the app will be shared with my flatmates if i enable the notification switch in any of the App instances in use the notification is sent to all instances of this App. Is there any way to:
1.: Identify which App/User has the notification button enabled? (I could do that with one switch for each User)
2: Send the notification to a specific app instance?
Anyone has any ideas on this? Otherwise it might work with some ifttt tinkering.
With kind regards
Sebastian
