I want the notification setting every 10 minutes
That’s nice
But we are not code monkeys on demand.
And we would like you to re-post your code with proper formatting… as directed in the instructions you needed to delete when posting this.
You can also search this forum for other topics about how others resolved the repeating, but timed, notification issue.
I’d take https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/PushNotification/PushNotification_Interval/PushNotification_Interval.ino as a starting point.
http://twitter.com/blynk_app
Output any data on LCD widget!
App project setup:
LCD widget, switch to ADVANCED mode, select pin V1
#define TRIGGERPIN D3
#define ECHOPIN D4
int A, B ;
#include <TimeLib.h>
#include <WidgetRTC.h>
unsigned int notified = 0;
char auth[] = “b46b9ce7e96949a895de6d5f91c2bf82”;
// Set password to “” for open networks.
char ssid[] = “wifi”;
char pass[] = “28021999”;
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), … at any time
// Please see Time library examples for details
String currentTime = String(hour()) + “:” + minute() + “:” + second();
String currentDate = String(day()) + “/” + month() + “/” + year();
Serial.print("Current time: “);
Serial.print(currentTime);
Serial.print(” ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
pinMode(TRIGGERPIN, OUTPUT);
pinMode(ECHOPIN, INPUT);
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 8442);
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)…
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 10 seconds
timer.setInterval(1000L, clockDisplay);
A = 100;
digitalWrite(TRIGGERPIN, LOW);
delayMicroseconds(3);
digitalWrite(TRIGGERPIN, HIGH);
delayMicroseconds(12);
int distance = pulseIn(ECHOPIN, HIGH);
distance = distance / 58;
B = A - distance;
Blynk.virtualWrite(V3, B);
Serial.print(B);
Serial.println(“Cm”);
if (B <= 49 && notified == 0){//c heck to see if flag is also set
notified = 1;
Blynk.notify(“Blynk - jumlah pakan tidak mencukupi”);
}else if (B >= 50){// set higher than 50 …
notified = 0;
if (B >= 49 && notified == 0){//c heck to see if flag is also set
notified = 1;
Blynk.notify(“Blynk - jumlah pakan sudah mencukupi”);
}else if (B <= 48){// set lower than 48 …
notified = 0;
I want to set when the distance is above 50 cm then notification out and below the distance of 49 cm notification … coding above can be out notification but out continuously without pause when I want to go out one time only
