Hi blynkers,
I am trying to make an smart alcohol sensor which will send an email to police with the link of my app when high amount of alcohol is detected in drivers body in my app their will be a map,a display value for no of satellite,latitude,longitude,direction,speed and a gauge which which will show alcohol level.
The pins that I have used are
A0-for alcohol sensor
V0-for map
V1-for latitude
V2-for longitude
V3-for speed
V4-for direction
The things that I am using is
1)Arduino uno
2)neo-6m GPS module
3)ma-3 alcohol sensor
4)esp8266 12e one for gps module and one for push button
The problems is that I am not able to combine this esp8266 template code
This is a DEMO. You can use it only for development and testing.
You should open Setting.h and modify General options.
If you would like to add these features to your product,
please contact Blynk for Businesses:
http://www.blynk.io/
//#define USE_SPARKFUN_BLYNK_BOARD // Uncomment the board you are using
#define USE_NODE_MCU_BOARD // Comment out the boards you are not using
//#define USE_WITTY_CLOUD_BOARD
//#define USE_CUSTOM_BOARD // For all other ESP8266-based boards -
// see "Custom board configuration" in Settings.h
#define APP_DEBUG // Comment this out to disable debug prints
#include "BlynkProvisioning.h"
delay(500);
BlynkProvisioning.begin();
// This handles the network and cloud connection
BlynkProvisioning.run();
* This is a DEMO. You can use it only for development and testing.
* If you would like to add these features to your product,
* please contact Blynk for Business:
* http://www.blynk.io/
extern "C" {
#include "user_interface.h"
#include "Settings.h"
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
inline
void BlynkState::set(State m) {
if (state != m) {
DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
state = m;
class Provisioning {
public:
void begin()
DEBUG_PRINT("");
DEBUG_PRINT("Hardware v" + String(BOARD_HARDWARE_VERSION));
DEBUG_PRINT("Firmware v" + String(BOARD_FIRMWARE_VERSION));
indicator_init();
button_init();
config_init();
if (configStore.flagConfig) {
BlynkState::set(MODE_CONNECTING_NET);
BlynkState::set(MODE_WAIT_CONFIG);
void run() {
switch (BlynkState::get()) {
case MODE_WAIT_CONFIG:
case MODE_CONFIGURING: enterConfigMode(); break;
case MODE_CONNECTING_NET: enterConnectNet(); break;
case MODE_CONNECTING_CLOUD: enterConnectCloud(); break;
case MODE_RUNNING: Blynk.run(); break;
case MODE_OTA_UPGRADE: enterOTA(); break;
case MODE_SWITCH_TO_STA: enterSwitchToSTA(); break;
case MODE_RESET_CONFIG: enterResetConfig(); break;
default: enterError(); break;
Provisioning BlynkProvisioning;
enum State {
MODE_WAIT_CONFIG,
MODE_CONFIGURING,
MODE_CONNECTING_NET,
MODE_CONNECTING_CLOUD,
MODE_RUNNING,
MODE_OTA_UPGRADE,
MODE_SWITCH_TO_STA,
MODE_RESET_CONFIG,
MODE_ERROR,
MODE_MAX_VALUE
#if defined(APP_DEBUG)
const char* StateStr[MODE_MAX_VALUE] = {
"WAIT_CONFIG",
"CONFIGURING",
"CONNECTING_NET",
"CONNECTING_CLOUD",
"RUNNING",
"OTA_UPGRADE",
"SWITCH_TO_STA",
"RESET_CONFIG",
"ERROR"
#endif
namespace BlynkState
volatile State state;
State get() { return state; }
bool is (State m) { return (state == m); }
void set(State m);
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <DNSServer.h>
ESP8266WebServer server(WIFI_AP_CONFIG_PORT);
ESP8266HTTPUpdateServer httpUpdater;
DNSServer dnsServer;
const byte DNS_PORT = 53;
const char* config_form = R"html(
<!DOCTYPE HTML>
<html>
<head>
<title>WiFi setup</title>
<style>
body {
background-color: #fcfcfc;
box-sizing: border-box;
body, input {
font-family: Roboto, sans-serif;
font-weight: 400;
font-size: 16px;
.centered {
position: fixed;
top: 50%;
left: 50%;
transform: translate(-50%, -50%);
padding: 20px;
background-color: #ccc;
border-radius: 4px;
td { padding:0 0 0 5px; }
label { white-space:nowrap; }
input { width: 20em; }
input[name="port"] { width: 5em; }
input[type="submit"], img { margin: auto; display: block; width: 30%; }
</style>
</head>
<body>
<div class="centered">
<form method="get" action="config">
<table>
<tr><td><label for="ssid">WiFi SSID:</label></td> <td><input type="text" name="ssid" length=64 required="required"></td></tr>
<tr><td><label for="pass">Password:</label></td> <td><input type="text" name="pass" length=64></td></tr>
<tr><td><label for="blynk">Auth token:</label></td><td><input type="text" name="blynk" placeholder="a0b1c2d..." pattern="[a-zA-Z0-9]{32}" maxlength="32" required="required"></td></tr>
<tr><td><label for="host">Host:</label></td> <td><input type="text" name="host" length=64></td></tr>
<tr><td><label for="port">Port:</label></td> <td><input type="number" name="port" value="80" min="1" max="65535"></td></tr>
</table><br/>
<input type="submit" value="Apply">
</form>
</div>
</body>
</html>
)html";
void restartMCU() {
ESP.restart();
void enterConfigMode()
randomSeed(ESP.getChipId());
const uint32_t unique = random(0xFFFFF);
char ssidBuff[64];
snprintf(ssidBuff, sizeof(ssidBuff), "%s-%05X", PRODUCT_WIFI_SSID, unique);
WiFi.mode(WIFI_OFF);
delay(100);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(WIFI_AP_IP, WIFI_AP_IP, WIFI_AP_Subnet);
WiFi.softAP(ssidBuff);
delay(500);
IPAddress myIP = WiFi.softAPIP();
DEBUG_PRINT(String("AP SSID: ") + ssidBuff);
DEBUG_PRINT(String("AP IP: ") + myIP[0] + "." + myIP[1] + "." + myIP[2] + "." + myIP[3]);
if (myIP == (uint32_t)0)
BlynkState::set(MODE_ERROR);
return;
// Set up DNS Server
dnsServer.setTTL(300); // Time-to-live 300s
dnsServer.setErrorReplyCode(DNSReplyCode::ServerFailure); // Return code for non-accessible domains
#ifdef WIFI_CAPTIVE_PORTAL_ENABLE
dnsServer.start(DNS_PORT, "*", WiFi.softAPIP()); // Point all to our IP
server.onNotFound(handleRoot);
#else
dnsServer.start(DNS_PORT, BOARD_CONFIG_AP_URL, WiFi.softAPIP());
DEBUG_PRINT(String("AP URL: ") + BOARD_CONFIG_AP_URL);
#endif
httpUpdater.setup(&server);
server.on("/", []() {
server.send(200, "text/html", config_form);
server.on("/config", []() {
String ssid = server.arg("ssid");
String ssidManual = server.arg("ssidManual");
String pass = server.arg("pass");
if (ssidManual != "") {
ssid = ssidManual;
String token = server.arg("blynk");
String host = server.arg("host");
String port = server.arg("port");
String content;
unsigned statusCode;
DEBUG_PRINT(String("WiFi SSID: ") + ssid + " Pass: " + pass);
DEBUG_PRINT(String("Blynk cloud: ") + token + " @ " + host + ":" + port);
if (token.length() == 32 && ssid.length() > 0) {
configStore.flagConfig = false;
CopyString(ssid, configStore.wifiSSID);
CopyString(pass, configStore.wifiPass);
CopyString(token, configStore.cloudToken);
if (host.length()) {
CopyString(host, configStore.cloudHost);
if (port.length()) {
configStore.cloudPort = port.toInt();
content = R"json({"status":"ok","msg":"Configuration saved"})json";
statusCode = 200;
server.send(statusCode, "application/json", content);
BlynkState::set(MODE_SWITCH_TO_STA);
DEBUG_PRINT("Configuration invalid");
content = R"json({"status":"error","msg":"Configuration invalid"})json";
statusCode = 404;
server.on("/board_info.json", []() {
char buff[256];
snprintf(buff, sizeof(buff),
R"json({"board":"%s","vendor":"%s","tmpl_id":"%s","fw_ver":"%s","hw_ver":"%s"})json",
BOARD_NAME,
BOARD_VENDOR,
BOARD_TEMPLATE_ID,
BOARD_FIRMWARE_VERSION,
server.send(200, "application/json", buff);
server.on("/reset", []() {
BlynkState::set(MODE_RESET_CONFIG);
server.send(200, "application/json", R"json({"status":"ok","msg":"Configuration reset"})json");
server.on("/reboot", []() {
restartMCU();
server.begin();
while (BlynkState::is(MODE_WAIT_CONFIG) || BlynkState::is(MODE_CONFIGURING)) {
dnsServer.processNextRequest();
server.handleClient();
if (BlynkState::is(MODE_WAIT_CONFIG) && WiFi.softAPgetStationNum() > 0) {
BlynkState::set(MODE_CONFIGURING);
} else if (BlynkState::is(MODE_CONFIGURING) && WiFi.softAPgetStationNum() == 0) {
server.stop();
void enterConnectNet() {
DEBUG_PRINT(String("Connecting to WiFi: ") + configStore.wifiSSID);
WiFi.mode(WIFI_STA);
if (!WiFi.begin(configStore.wifiSSID, configStore.wifiPass)) {
return;
unsigned long timeoutMs = millis() + WIFI_NET_CONNECT_TIMEOUT;
while ((timeoutMs > millis()) && (WiFi.status() != WL_CONNECTED))
delay(100);
if (!BlynkState::is(MODE_CONNECTING_NET)) {
WiFi.disconnect();
return;
if (WiFi.status() == WL_CONNECTED) {
BlynkState::set(MODE_CONNECTING_CLOUD);
void enterConnectCloud() {
Blynk.disconnect();
Blynk.config(configStore.cloudToken, configStore.cloudHost, configStore.cloudPort);
Blynk.connect(0);
unsigned long timeoutMs = millis() + WIFI_CLOUD_CONNECT_TIMEOUT;
(Blynk.connected() == false))
if (!BlynkState::is(MODE_CONNECTING_CLOUD)) {
Blynk.disconnect();
return;
if (Blynk.connected()) {
BlynkState::set(MODE_RUNNING);
if (!configStore.flagConfig) {
configStore.flagConfig = true;
config_save();
DEBUG_PRINT("Configuration stored to flash");
void enterSwitchToSTA() {
DEBUG_PRINT("Switching to STA...");
void enterError() {
unsigned long timeoutMs = millis() + 10000;
while (timeoutMs > millis() || g_buttonPressed)
if (!BlynkState::is(MODE_ERROR)) {
return;
DEBUG_PRINT("Restarting after error.");
restartMCU();
struct ConfigStore {
uint32_t magic;
char version[9];
uint8_t flagConfig:1;
uint8_t flagApFail:1;
uint8_t flagSelfTest:1;
char wifiSSID[34];
char wifiPass[64];
char cloudToken[34];
char cloudHost[34];
uint16_t cloudPort;
uint16_t checksum;
} __attribute__((packed));
ConfigStore configStore;
const ConfigStore configDefault = {
0x626C6E6B,
0, 0, 0,
"invalid token",
"blynk-cloud.com", 80,
0
#include <EEPROM.h>
#define EEPROM_CONFIG_START 0
void config_load()
memset(&configStore, 0, sizeof(configStore));
EEPROM.get(EEPROM_CONFIG_START, configStore);
if (configStore.magic != configDefault.magic) {
DEBUG_PRINT("Using default config.");
configStore = configDefault;
return;
bool config_save()
EEPROM.put(EEPROM_CONFIG_START, configStore);
EEPROM.commit();
return true;
bool config_init()
EEPROM.begin(sizeof(ConfigStore));
config_load();
return true;
void enterResetConfig()
DEBUG_PRINT("Resetting configuration!");
config_save();
template<typename T, int size>
void CopyString(const String& s, T(&arr)[size]) {
s.toCharArray(arr, size);
#if defined(BOARD_LED_PIN_WS2812)
#include <Adafruit_NeoPixel.h> // Library: https://github.com/adafruit/Adafruit_NeoPixel
Adafruit_NeoPixel rgb = Adafruit_NeoPixel(1, BOARD_LED_PIN_WS2812, NEO_GRB + NEO_KHZ800);
#endif
void indicator_run();
#if !defined(BOARD_LED_BRIGHTNESS)
#define BOARD_LED_BRIGHTNESS 255
#endif
#if defined(BOARD_LED_PIN_WS2812) || defined(BOARD_LED_PIN_R)
#define BOARD_LED_IS_RGB
#endif
#define DIMM(x) ((x)*(BOARD_LED_BRIGHTNESS)/255)
#define RGB(r,g,b) (DIMM(r) << 16 | DIMM(g) << 8 | DIMM(b) << 0)
class Indicator {
public:
enum Colors {
COLOR_BLACK = RGB(0x00, 0x00, 0x00),
COLOR_WHITE = RGB(0xFF, 0xFF, 0xE7),
COLOR_BLUE = RGB(0x0D, 0x36, 0xFF),
COLOR_BLYNK = RGB(0x2E, 0xFF, 0xB9),
COLOR_RED = RGB(0xFF, 0x10, 0x08),
COLOR_MAGENTA = RGB(0xA7, 0x00, 0xFF),
Indicator() {
m_Counter = 0;
initLED();
uint32_t run() {
State currState = BlynkState::get();
// Reset counter if indicator state changes
if (m_PrevState != currState) {
m_PrevState = currState;
m_Counter = 0;
if (g_buttonPressed) {
if (millis() - g_buttonPressTime > BUTTON_HOLD_TIME_ACTION) { return beatLED(COLOR_WHITE, (int[]){ 100, 100 }); }
if (millis() - g_buttonPressTime > BUTTON_HOLD_TIME_INDICATION) { return waveLED(COLOR_WHITE, 1000); }
switch (currState) {
case MODE_WAIT_CONFIG: return beatLED(COLOR_BLUE, (int[]){ 50, 500 });
case MODE_CONFIGURING: return beatLED(COLOR_BLUE, (int[]){ 200, 200 });
case MODE_CONNECTING_NET: return beatLED(COLOR_BLYNK, (int[]){ 50, 500 });
case MODE_CONNECTING_CLOUD: return beatLED(COLOR_BLYNK, (int[]){ 100, 100 });
case MODE_RUNNING: return waveLED(COLOR_BLYNK, 5000);
case MODE_OTA_UPGRADE: return beatLED(COLOR_MAGENTA, (int[]){ 50, 50 });
default: return beatLED(COLOR_RED, (int[]){ 80, 100, 80, 1000 } );
protected:
* LED drivers
#if defined(BOARD_LED_PIN_WS2812) // Addressable, NeoPixel RGB LED
void initLED() {
rgb.begin();
setRGB(COLOR_BLACK);
void setRGB(uint32_t color) {
rgb.setPixelColor(0, color);
rgb.show();
#elif defined(BOARD_LED_PIN_R) // Normal RGB LED (common anode or common cathode)
void initLED() {
pinMode(BOARD_LED_PIN_R, OUTPUT);
pinMode(BOARD_LED_PIN_G, OUTPUT);
pinMode(BOARD_LED_PIN_B, OUTPUT);
uint8_t r = (color & 0xFF0000) >> 16;
uint8_t g = (color & 0x00FF00) >> 8;
uint8_t b = (color & 0x0000FF);
#if BOARD_LED_INVERSE
analogWrite(BOARD_LED_PIN_R, BOARD_PWM_MAX - r);
analogWrite(BOARD_LED_PIN_G, BOARD_PWM_MAX - g);
analogWrite(BOARD_LED_PIN_B, BOARD_PWM_MAX - b);
#else
analogWrite(BOARD_LED_PIN_R, r);
analogWrite(BOARD_LED_PIN_G, g);
analogWrite(BOARD_LED_PIN_B, b);
#endif
#elif defined(BOARD_LED_PIN) // Single color LED
void initLED() {
pinMode(BOARD_LED_PIN, OUTPUT);
void setLED(uint32_t color) {
analogWrite(BOARD_LED_PIN, BOARD_PWM_MAX - color);
#else
analogWrite(BOARD_LED_PIN, color);
#endif
#else
#warning Invalid LED configuration.
#endif
* Animations
uint32_t skipLED() {
return 20;
#if defined(BOARD_LED_IS_RGB)
template<typename T>
uint32_t beatLED(uint32_t onColor, const T& beat) {
const uint8_t cnt = sizeof(beat)/sizeof(beat[0]);
setRGB((m_Counter % 2 == 0) ? onColor : (uint32_t)COLOR_BLACK);
uint32_t next = beat[m_Counter % cnt];
m_Counter = (m_Counter+1) % cnt;
return next;
uint32_t waveLED(uint32_t colorMax, unsigned breathePeriod) {
uint8_t redMax = (colorMax & 0xFF0000) >> 16;
uint8_t greenMax = (colorMax & 0x00FF00) >> 8;
uint8_t blueMax = (colorMax & 0x0000FF);
// Brightness will rise from 0 to 128, then fall back to 0
uint8_t brightness = (m_Counter < 128) ? m_Counter : 255 - m_Counter;
// Multiply our three colors by the brightness:
redMax *= ((float)brightness / 128.0);
greenMax *= ((float)brightness / 128.0);
blueMax *= ((float)brightness / 128.0);
// And turn the LED to that color:
setRGB((redMax << 16) | (greenMax << 8) | blueMax);
// This function relies on the 8-bit, unsigned m_Counter rolling over.
m_Counter = (m_Counter+1) % 256;
return breathePeriod / 256;
#else
uint32_t beatLED(uint32_t, const T& beat) {
setLED((m_Counter % 2 == 0) ? BOARD_PWM_MAX : 0);
return next;
uint32_t waveLED(uint32_t, unsigned breathePeriod) {
setLED(BOARD_PWM_MAX * ((float)brightness / (BOARD_PWM_MAX/2)));
#endif
private:
uint8_t m_Counter;
State m_PrevState;
Indicator indicator;
* Animation timers
#if defined(USE_TICKER)
#include <Ticker.h>
Ticker blinker;
void indicator_run() {
uint32_t returnTime = indicator.run();
if (returnTime) {
blinker.attach_ms(returnTime, indicator_run);
void indicator_init() {
blinker.attach_ms(100, indicator_run);
#elif defined(USE_TIMER_ONE)
#include <TimerOne.h>
if (returnTime) {
Timer1.initialize(returnTime*1000);
Timer1.initialize(100*1000);
Timer1.attachInterrupt(indicator_run);
#elif defined(USE_TIMER_THREE)
#include <TimerThree.h>
if (returnTime) {
Timer3.initialize(returnTime*1000);
Timer3.initialize(100*1000);
Timer3.attachInterrupt(indicator_run);
#else
#warning LED indicator needs a functional timer!
void indicator_run() {}
void indicator_init() {}
#endif
* How to trigger an OTA update?
* 1. In Arduino IDE menu: Sketch -> Export compiled Binary
* 2. Open console, navigate to the sketch directory
* 3.a Trigger update using HTTPS API on local server for specific hardware:
* curl -v -F file=@Template_ESP8266.ino.nodemcu.bin --insecure -u admin@blynk.cc:admin https://localhost:9443/admin/ota/start?token=123
* 3.b Trigger update using HTTPS API on local server for all hardware:
* 3.c Trigger update using HTTPS API on local server for single user:
* curl -v -F file=@Template_ESP8266.ino.nodemcu.bin --insecure -u admin@blynk.cc:admin https://localhost:9443/admin/ota/start?user=pupkin@gmail.com
* 3.d Trigger update using HTTPS API on local server for single user and specific project:
* curl -v -F file=@Template_ESP8266.ino.nodemcu.bin --insecure -u admin@blynk.cc:admin https://localhost:9443/admin/ota/start?user=pupkin@gmail.com&project=123
* More about ESP8266 OTA updates:
* https://github.com/esp8266/Arduino/blob/master/doc/ota_updates/readme.md
#include <ESP8266HTTPClient.h>
#include <ESP8266httpUpdate.h>
String overTheAirURL;
BLYNK_WRITE(InternalPinOTA) {
overTheAirURL = param.asString();
// Disconnect, not to interfere with OTA process
Blynk.disconnect();
// Start OTA
BlynkState::set(MODE_OTA_UPGRADE);
delay(500);
void enterOTA() {
DEBUG_PRINT(String("Firmware update URL: ") + overTheAirURL);
switch (ESPhttpUpdate.update(overTheAirURL, BOARD_FIRMWARE_VERSION)) {
case HTTP_UPDATE_FAILED:
DEBUG_PRINT(String("Firmware update failed (error ") + ESPhttpUpdate.getLastError() + "): " + ESPhttpUpdate.getLastErrorString());
break;
case HTTP_UPDATE_NO_UPDATES:
DEBUG_PRINT("No firmware updates available.");
break;
case HTTP_UPDATE_OK:
DEBUG_PRINT("Firmware update: OK.");
restartMCU();
break;
volatile bool g_buttonPressed = false;
volatile uint32_t g_buttonPressTime = -1;
void button_action(void)
void button_change(void)
#if BOARD_BUTTON_ACTIVE_LOW
bool buttonState = !digitalRead(BOARD_BUTTON_PIN);
#else
bool buttonState = digitalRead(BOARD_BUTTON_PIN);
#endif
if (buttonState && !g_buttonPressed) {
g_buttonPressTime = millis();
g_buttonPressed = true;
DEBUG_PRINT("Hold the button to reset configuration...");
} else if (!buttonState && g_buttonPressed) {
uint32_t buttonHoldTime = millis() - g_buttonPressTime;
if (buttonHoldTime >= BUTTON_HOLD_TIME_ACTION) {
button_action();
void button_init()
pinMode(BOARD_BUTTON_PIN, INPUT_PULLUP);
#else
pinMode(BOARD_BUTTON_PIN, INPUT);
#endif
attachInterrupt(BOARD_BUTTON_PIN, button_change, CHANGE);
* General options
#define BOARD_FIRMWARE_VERSION "1.0.1"
#define BOARD_HARDWARE_VERSION "1.0.0"
#define BOARD_NAME "Product Name" // Name of your product. Should match App Export request info.
#define BOARD_VENDOR "Company Name" // Name of your company. Should match App Export request info.
#define BOARD_TEMPLATE_ID "TMPL0000" // ID of the Tile Template. Can be found in Tile Template Settings
#define PRODUCT_WIFI_SSID "Our Product" // Name of the device, to be displayed during configuration. Should match export request info.
#define BOARD_CONFIG_AP_URL "our-product.cc" // Config page will be available in a browser at 'http://our-product.cc/'
* Board configuration (see examples below).
#if defined(USE_CUSTOM_BOARD)
// Custom board configuration
#define BOARD_BUTTON_PIN 0 // Pin where user button is attached
#define BOARD_BUTTON_ACTIVE_LOW true // true if button is "active-low"
#define BOARD_LED_PIN 2 // Set LED pin - if you have a single-color LED attached
//#define BOARD_LED_PIN_R 15 // Set R,G,B pins - if your LED is PWM RGB
//#define BOARD_LED_PIN_G 12
//#define BOARD_LED_PIN_B 13
//#define BOARD_LED_PIN_WS2812 4 // Set if your LED is WS2812 RGB
#define BOARD_LED_INVERSE false // true if LED is common anode, false if common cathode
#define BOARD_LED_BRIGHTNESS 64 // 0..255 brightness control
#elif defined(USE_NODE_MCU_BOARD)
#warning "NodeMCU board selected"
// Example configuration for NodeMCU v1.0 Board
#define BOARD_LED_PIN_R D8
#define BOARD_LED_PIN_G D7
#define BOARD_LED_PIN_B D6
#elif defined(USE_SPARKFUN_BLYNK_BOARD)
#warning "Sparkfun Blynk board selected"
// Example configuration for SparkFun Blynk Board
#elif defined(USE_WITTY_CLOUD_BOARD)
#warning "Witty Cloud board selected"
// Example configuration for Witty cloud Board
#define BOARD_BUTTON_PIN 4
#else
#error "No board selected"
#endif
* Advanced options
#define BUTTON_HOLD_TIME_INDICATION 3000
#define BUTTON_HOLD_TIME_ACTION 10000
#define BOARD_PWM_MAX 1023
#define WIFI_NET_CONNECT_TIMEOUT 30000
#define WIFI_CLOUD_CONNECT_TIMEOUT 15000
#define WIFI_AP_CONFIG_PORT 80
#define WIFI_AP_IP IPAddress(192, 168, 4, 1)
#define WIFI_AP_Subnet IPAddress(255, 255, 255, 0)
//#define WIFI_CAPTIVE_PORTAL_ENABLE
#define USE_TICKER
//#define USE_TIMER_ONE
//#define USE_TIMER_THREE
#define DEBUG_PRINT(...) BLYNK_LOG1(__VA_ARGS__)
#else
#endif
And this code for gps tracker and alcohol sensor
/* The Code is developed by Alok Shaw (alokom78@gmaail.com) and is free to use and modify. Watch the full explanation for the same on
* Youtube : www.youtube.com/roboshala
#include <TinyGPS++.h>
static const int RXPin =5, TXPin =4; // GPIO 4=D2(conneect Tx of GPS) and GPIO 5=D1(Connect Rx of GPS
static const uint32_t GPSBaud = 9600; //if Baud rate 9600 didn't work in your case then use 4800
TinyGPSPlus gps; // The TinyGPS++ object
WidgetMap myMap(V0); // V0 for virtual pin of Map Widget
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
float spd; //Variable to store the speed
float sats; //Variable to store no. of satellites response
String bearing; //Variable to store orientation or direction of GPS
char auth[] = "Auth token"; //Your Project authentication key
char ssid[] = "wifi ssid"; // Name of your network (HotSpot or Router name)
char pass[] = "password"; // Corresponding Password
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
int gas_value;
int gas_avalue;
Serial.println();
ss.begin(GPSBaud);
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V4, "GPS ERROR"); // Value Display widget on V4 if GPS not detected
gas_avalue = digitalRead(D1);
while (ss.available() > 0)
// sketch displays information every time a new sentence is correctly encoded.
if (gps.encode(ss.read()))
displayInfo();
void displayInfo()
if (gps.location.isValid() )
float latitude = (gps.location.lat()); //Storing the Lat. and Lon.
float longitude = (gps.location.lng());
Serial.print("LAT: ");
Serial.println(latitude, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V1, String(latitude, 6));
Blynk.virtualWrite(V2, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "GPS_Location");
spd = gps.speed.kmph(); //get speed
Blynk.virtualWrite(V3, spd);
sats = gps.satellites.value(); //get number of satellites
Blynk.virtualWrite(V4, sats);
bearing = TinyGPSPlus::cardinal(gps.course.value()); // get the direction
Blynk.virtualWrite(V5, bearing);
Serial.println();
please help me I watched the video on youtube also but I can`t understand how to combine it please help me
please help me
