Im using nodemcu v1 and i want to keep the D2 high for certain amount of time ? how could be that possible using blynk ?
any advice will be appreciated thank you
There is no statement im using blynk app my code is somethink look like this
Blynk.begin(auth, "ssid", "pass");
i assign a led to pin d2 and i want it to stay on for 6 sec
delay()'s go against Blynk guidelines as it will cause disruptions to the heartbeat timer and cause disconnects.
NEVER USE DELAY
@Abdullah_Anwar, you need to learn how to use SimpleTimer and Virtual Pins.
You cannot do what you want without using these methods.
yes exactly simple timer and virtual pins is the best way. but @Abdullah_Anwar his asking for only single pin i think as per his statement, so i give delay…
@Jamin @Castle Thank you guys I will read the guideline and try to solve the problem if I counter any problem I let you know
Thanks again
ANY ONE COULD TELL ME HOW TO ELIMINATE THE DELAY IN MY CODE BY USING OTHER FUNCTION OR ANY WAY COULD DO THE WORK ?
@Jamin @Castle
char auth[] = "";
digitalWrite(D7, HIGH); //GPIO13
pinMode(D7, OUTPUT); // Pin connected to the Relay
Blynk.begin(auth, "", "");
BLYNK_WRITE(V7)
if (param.asInt() == 1 )
delay(3000);
{digitalWrite(D7, LOW);
yield();
- List item
format your code correctly.
```cpp
CODE
Do not use delay()… between the ESP connection process and Blynks own heartbeat loop, any delay over a few fractions of a second will cause disconnects and timeouts.
@Abdullah_Anwar Please format your code and read up on Simple Timer or we may be unwilling to continue further assistance…
http://playground.arduino.cc/Code/SimpleTimer
Sorry but I’m new here I’m not sure how to format my code
Well you clearly know how to paste your code in your posts… just add the three backtick characters and the letters ccp in front of it, then three more backticks at the end… just like the picture above.
Watch the GIF here for more info…
COPY THIS EXAMPLE AND PASTE IT IN YOUR POST, THEN REPLACE CODE WITH YOUR SKETCH.
```cpp
CODE
…CPP
char auth[] = "";
BLYNK_WRITE(V7)
delay(3000);
yield();
Correct principle, wrong key for the backtick (it looks like you used periods, a backtick is like a reversed comma)… look at the picture and find the same looking key somewhere on your keyboard. Depending on the language layout of your keyboard, the backtick may be located elsewhere then the upper left.
Or just try copy and pasting these three backticks here like @Jamin suggested —> ```
@Abdullah_Anwar Looks better… and thanks for going back and editing all the previous ones as well
Not many do that.
Now as for your timing issue… @Jamin posted a good example of triggering relays for a set time in this post here [SOLVED] Triggered cycle counter Check it out for ideas on how to work Simple Timer into your code.
Here is my code i did like the example but it does not work am i missing something? @Gunner @Jamin
char auth[] = "";
pinMode(2, OUTPUT);
pinMode(13, OUTPUT);
void actionRelays(){
relay1_ON(); // turn on relay1
timer.setTimeout(2000, relay2_ON); // delay 2sec then turn on relay2
timer.setTimeout(15000, relays_OFF); // delay 15sec from first action and turn off both relays
void relay1_ON(){
digitalWrite(2,HIGH); // turn on relay1
Blynk.virtualWrite(V10, 255); // turn on an LED widget (optional)
void relay2_ON(){
digitalWrite(13,HIGH); // turn on relay2
Blynk.virtualWrite(V20, 255); // turn on an LED widget (optional)
void relays_OFF(){
digitalWrite(2,LOW); // turn off relay1
digitalWrite(13,LOW); // turn off relay2
Blynk.virtualWrite(V10, 0); // turn off an LED widget (optional)
Blynk.virtualWrite(V20, 0); // turn off an LED widget (optional)
BLYNK_WRITE(V7)
actionRelays();
{digitalWrite(13, LOW);
No such GPIO as “D7” …
You need to convert the D pin to a GPIO pin number.
D4 = 2
D7 = 13
Also… this part is too complex… lets slim it down. …
BLYNK_WRITE(V7)
actionRelays();
to this. …
BLYNK_WRITE(V7) {
actionRelays();
Serial.println("V7 triggered"); // to confirm it was pressed in Serial montior
because all you can do it start the sequence… if you want to stop it… you need to add some more code!
@Jamin Thanks for the quick response i changed the pin numbers but still the same nothing changed
is my blink_write function correct ?
