What does your serial monitor say?
Update it to my example above.
Whoops!! You’re missing the important bit…
timer.run(); // run the timers!
Thanks for the tip i will try it and let you know
Thank you guys for the great support @Jamin @Gunner the code is working like charm
i will post it here in case somebody need it
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
You need to install this for ESP8266 development:
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SSD1306_LCDHEIGHT 64
#define OLED_RESET LED_BUILTIN //4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
char auth[] = "blynk authu";
display.clearDisplay();
pinMode(13, OUTPUT);
Blynk.begin(auth, "ssid name", "pass");
void actionRelays()
relay1_ON(); // turn on relay1
timer.setTimeout(1000, relay2_ON); // delay 2sec then turn on relay2
sendOLED();
timer.setTimeout(5000, relays_OFF);
timer.setTimeout(5000, relays_OFF);// delay 15sec from first action and turn off both relays
timer.setTimeout(5000, sendOLED);
timer.setTimeout(5000, screen_clear);
void screen_clear()
display.display();
void relay1_ON()
digitalWrite(13, LOW); // turn on relay1
Blynk.virtualWrite(V10, 255); // turn on an LED widget (optional)
void relay2_ON()
digitalWrite(13, HIGH); // turn on relay2
Blynk.virtualWrite(V20, 255); // turn on an LED widget (optional)
void relays_OFF()
digitalWrite(13, LOW); // turn off relay2
Blynk.virtualWrite(V20, 0); // turn off an LED widget (optional)
void sendOLED()
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0, 0);
display.println("Hello from:");
display.print("Door is Open ");
display.display();
display.startscrollright(0x00, 0x0F);
BLYNK_WRITE(V7)
if (param.asInt() == 1 )
actionRelays();
// oled();
// sendOLED();
Thanks for sharing, I’m using the same and would like to know if its possible to add variable for the delay?
I’d like to use the slider widget attached to V0 to take a time input in minutes converted to seconds for user by the timer
BLYNK_WRITE(V0){ // add a slider on V0 range 0 to 30 (minutes)
Countdown = param.asInt(); // set variable as Slider value
Serial.print("V0 Slider value is: ");
Serial.println(Countdown);
CountdownValue=(Countdown*60000);
Serial.print("CountdownValue will be: ");
Serial.println(CountdownValue);
You almost had it right. Try this instead.
long CountdownValue = param.asInt() * 60000; // take slider input and times by 60k to get millisecs
Serial.print("V0 Slider value in mins: ");
Serial.println(param.asInt());
Serial.print("V0 Slider value in seconds: ");
Serial.println(CountdownValue / 1000);
Serial.print("Timer value in millisecs will be: ");
yourCustomTimer = timer.setTimout(CountdownValue, yourFunctionHere); // do you normal simpleTimer setup here using the same ID = yourCustomTimer
