Hey,
when I want to send the hexadecimal code from the IR-Led to my LED-Strip, the only thing that happens is that the IR-Led just turns on when I press the Button in the app but does not send the code to the LED-Strip. My LED is working just fine. Tested it and the code several times and had no issues when I was not using the app. The IR-Led is hooked to D2 and the other pin to GND. My guess is that somehow the app just send the command for the digital pin to go High, so it will just turn on but not send a signal. Here is my code:
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <Arduino.h>
char auth[] = "";
const uint16_t kIrLed = 4;
IRsend irsend(kIrLed);
char ssid[] = "";
char pass[] = "";
// This function sends Arduino’s up time every second to Virtual Pin (5).
// In the app, Widget’s reading frequency should be set to PUSH. This means
void myTimerEvent()
// Please don’t send more that 10 values per second.
Blynk.virtualWrite(V1, millis() / 1000);
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
irsend.begin();
BLYNK_WRITE(V1){
int onoff = param.asInt();
if(onoff == 1){
irsend.sendNEC(0xF7C03F, 32);
void loop(){
I hope someone has an idea of what I have made wrong. Thanks for your help in advance
