Details :
• Maduino Zero 4G LTE with GPS Module
• Android 9
• Blynk server = SGP1
• Blynk 2.0
I have similar problem to this post below. But, in my case I have set the data stream to Location type pin V9 and I am still not getting any GPS data from my board. Using AT commands I confirmed that the GPS and GSM works.
https://community.blynk.cc/t/need-help-with-blynk-2-0-and-sim7600e-device-offline/64625
#define DEBUG true
#define MODE_1A
#define DTR_PIN 9
#define RI_PIN 8
#define LTE_PWRKEY_PIN 5
#define LTE_RESET_PIN 6
#define LTE_FLIGHT_PIN 7
String token = "fc6__T-vO15pOh83HDs3gZ6MphVXw0r9";
String from_usb = "";
String loc = "";
String longitude = "";
String lattitude = "";
//FUNCTION TO PASS AT COMMAND
String sendData(String command, const int timeout, boolean debug)
String response = "";
Serial1.println(command);
long int time = millis();
while ( (time + timeout) > millis())
while (Serial1.available())
char c = Serial1.read();
response += c;
if (debug)
SerialUSB.print(response);
return response;
//FUNCTION TO CHECK SIGNAL STRENGTH
int check_signal(void)
while(1)
String sig = sendData("AT+CSQ",3000,DEBUG);
int i=0;
String strength;
while(sig[i]!=':')i++;
String loc_2 = sig.substring(i+2);
i=0;
while(loc_2[i]!=',')i++;
strength = loc_2.substring(0,i);
int strength_1 = strength.toInt();
SerialUSB.println(strength_1);
return strength_1;
//FUNCTION TO GET LATITUDE AND LONGITUDE STRING
void gpsLocation(String local)
// char* loc_2 = local;
// int p=0;
while(1)
int i=0;
while(local[i]!=':')i++;
String loc_2 = local.substring(i+2);
i=0;
lattitude = loc_2.substring(0,i);
SerialUSB.println(lattitude);
int j = i+3;
int k = j;
while(loc_2[k]!=',')k++;
longitude = loc_2.substring(j,k);
SerialUSB.println(longitude);
return;
//CONVERSION OF GIVEN LATTITUDE FORMAT FROM NMEA TO PARSER
String conversion(String local)
if(local[0]=='0'){
String str_end = local.substring(3);
String str_init = local.substring(1,3);
int val = str_init.toInt();
double deci_val = str_end.toDouble() ;
double new_value = val+(deci_val / 60);
SerialUSB.println(new_value);
String final_val = String(new_value,5);
return final_val;
else if(local[0]!='0')
String str_end = local.substring(2);
String str_init = local.substring(0,2);
return final_val;
//FUNCTION TO PASS LOCATION IN BLYNK API
void map_loc(String lat1,String lon1)
String lat = conversion(lat1);
String lon = conversion(lon1);
SerialUSB.print("lattitude = ");SerialUSB.println(lat);
SerialUSB.print("longitude = ");SerialUSB.println(lon);
String http_str = "AT+HTTPPARA=\"URL\",\"https://sgp1.blynk.cloud/external/api/batch/update?token=" + token + "&V9=" + lon + "&V9=" + lat + "\"\r\n";
SerialUSB.println(http_str);
sendData("AT+HTTPINIT\r\n", 3000, DEBUG);
sendData(http_str, 3000, DEBUG);
sendData("AT+HTTPACTION=0\r\n", 3000, DEBUG);
sendData("AT+HTTPTERM\r\n", 3000, DEBUG);
void setup(){
SerialUSB.begin(115200);
//while (!SerialUSB)
; // wait for Arduino serial Monitor port to connect
delay(100);
Serial1.begin(115200);
//INITIALIZING GSM MODULE
pinMode(LTE_RESET_PIN, OUTPUT);
digitalWrite(LTE_RESET_PIN, LOW);
pinMode(LTE_PWRKEY_PIN, OUTPUT);
delay(100);
digitalWrite(LTE_PWRKEY_PIN, HIGH);
delay(2000);
digitalWrite(LTE_PWRKEY_PIN, LOW);
pinMode(LTE_FLIGHT_PIN, OUTPUT);
digitalWrite(LTE_FLIGHT_PIN, LOW); //Normal Mode
// digitalWrite(LTE_FLIGHT_PIN, HIGH);//Flight Mode
SerialUSB.println("Maduino Zero 4G Test Start!");
SerialUSB.println(sendData("AT+CGMM\r\n", 3000, DEBUG));
sendData("AT+CPIN?\r\n",3000,DEBUG);
sendData("AT+COPS?\r\n",3000,DEBUG);
sendData("AT+CNUM\r\n",3000,DEBUG);
//INITIALIZING GPS MODULE
sendData("AT+CGPS=1",3000,DEBUG);
delay(60000);
void loop(){
//CHECKING SIGNAL STRENGTH
if(check_signal()>=10)
loc = sendData("AT+CGPSINFO\r\n",3000,DEBUG);
gpsLocation(loc);
if(lattitude!=""&& longitude!="")
map_loc(lattitude,longitude);
delay(5000);
