With love from Ukraine
In this release
- New Features
- Added universal
ArduinoClientexamples - a convenient way to use
ANY Arduino connectivity or shield (even if it’s not directly supported by Blynk). - You can configure multiple connection types, i.e. WiFi + Ethernet + Cellular
- Command grouping
- Improved network compatibility when using an insecure
TCPconnection -
BlynkParamargument support forBlynkConsole
- Added universal
- Updated examples (finally!
- Added
TimeInput,TimeAndLocationexamples - Simplified the
Stroboscopeexample, also to show-off theBlynkTimer::Handleusage - Replaced
UIPEthernetexamples withEthernetENC - Updated HTTP examples to use Blynk 2.0 HTTP API
- Added
Blynk.Edgent improvements:
BLYNK_DEVICE_NAMEsetting is changed toBLYNK_TEMPLATE_NAMEto eliminate confusion - Fix ESP32 losing the configuration after OTA in rare cases
- Improved compatibility with the latest ESP32 and ESP8266 Arduino Core
- Cleanup
- Removed old and outdated APIs, widgets that don’t exist anymore
- Switched to using
blynk.cloudserver by default (theblynk-cloud.comfallback is removed)
- AVR improvements
- Reduce the amount of timers in
BlynkTimerto 8 for AVR devices (to save RAM) - Fix 64-bit integers handling on 8-bit platforms
Remember to regularly update your IDE, Libraries and Boards!
Check out the full list of supported hardware
BTW, if you like Blynk, don’t forget to give us a github star!
Arduino Library Manager, PlatformIO, Particle and OpenWRT packages will be updated soon.
Grab the update here: https://github.com/blynkkk/blynk-library/releases/latest
