This is probably more a Lounge topic
no need to promote the competition after all… but I did bring it up and @vshymanskyy did ask ![]()
“best” is the wrong discriper… just different. And I most certainly am not changing… however, I am working on combining ![]()
I have successfully ran a script on a single NodeMCU that uses both Blynk and Virtuino… allowing me to mix and match my desired custom static display options using Virtuino’s widgets that seem a bit nicer (to me) than some of Blynk’s (for a cross room visual readability)… but I still have all the overwhelming larger widget quantity and IoT features of Blynk.
The documentation is poor… but the base process is very similar to Blynk with virtuino.run(); and virtuino.vMemoryWrite(12, counter); // write counter to virtual pin V12 type commands.
I admit it… that is one of the drawing features… I really like the rotating knob/slider widget and the nice looking round needle gauge… and the scalably LARGE text option (as long as you like the 7 segment look) but some of the in-widget colour schemes are not customisable (i.e. needle & text).
And it has an image widget!!! (Pro only)
Of course I am only using the free version… I have no idea what all the pro version widgets look like… and even at only $10.99 CanadianTire Buckazoids I will have to wait awhile to justify it.
BT or WiFi with direct network (device as AP or via router) connection and no server (but apparently a virtual device in the App can act as a server in the Pro version).
