i am trying to control 4 channel module in the new blynk platform:
Hardware Part:
- ESP-32
- 4 Channel Relay Module
- IR Sensor
so here is my coding part
void ir_remote(){
if (irrecv.decode(&results)) {
switch(results.value){
case 0xFFB04F:
digitalWrite(RelayPin1, toggleState_1);
toggleState_1 = !toggleState_1;
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
delay(100);
break;
case 0xFF9867:
digitalWrite(RelayPin2, toggleState_2);
toggleState_2 = !toggleState_2;
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
delay(100);
break;
case 0xFFD827:
digitalWrite(RelayPin3, toggleState_3);
toggleState_3 = !toggleState_3;
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
delay(100);
break;
case 0xFF807F:
digitalWrite(RelayPin4, toggleState_4);
toggleState_4 = !toggleState_4;
Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
delay(100);
break;
case 0xFF906F: all_SwitchOff(); Blynk.virtualWrite(VPIN_BUTTON_9, toggleState_5); break;
case 0xFFC03F: all_SwitchOn(); Blynk.virtualWrite(VPIN_BUTTON_10, toggleState_5); break;
default : break;
//Serial.println(results.value, HEX);
irrecv.resume();
but this part is in blynk edgent header file
and i am getting a error
Arduino: 1.8.12 (Windows 10), Board: âESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Noneâ
In file included from C:\Users\jamsa\OneDrive\Desktop\updated version\tech study cell\Code_ESP32_Blynk2_IR_DHT11_LDR_8Relays_Switch\Code_ESP32_Blynk2_IR_DHT11_LDR_8Relays_Switch\Code_ESP32_Blynk2_IR_DHT11_LDR_8Relays_Switch.ino:85:0:
sketch\BlynkEdgent.h: In function âvoid ir_remote()â:
BlynkEdgent.h:215:43: error: âall_SwitchOffâ was not declared in this scope
case 0xFF906F: all_SwitchOff(); Blynk.virtualWrite(VPIN_BUTTON_9, toggleState_5); dimmer.setState(OFF); break;
BlynkEdgent.h:216:42: error: âall_SwitchOnâ was not declared in this scope
case 0xFFC03F: all_SwitchOn(); Blynk.virtualWrite(VPIN_BUTTON_10, toggleState_5); dimmer.setState(ON); break;
Multiple libraries were found for âIRremote.hâ
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\IRremote
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Arduino-IRremote-master
Multiple libraries were found for âBlynkSimpleEsp32_SSL.hâ
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Blynk
Not used: C:\Program Files (x86)\Arduino\libraries\Blynk
Multiple libraries were found for âWiFi.hâ
Used: C:\Users\jamsa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\WiFiNINA
exit status 1
âShow verbose output during compilationâ
option enabled in File â Preferences.
No need to add anything folks. Lol.
