Just adding my phone details as requested by Blynk.
Tested on S3 and S5 with Android 4.3 and 5.0.
In the app version the problem is more acute than the project version of Blynk. In the project if you stop and start it then the bug is removed, not so with the app. Not tested it but removing the app and reinstalling might fix the bug but that’s not very practical in our case.
The issue was that they were working too well i.e. shared users receiving notifications when they didn’t want to etc. If you are not receiving any notifications that is probably a separate issue.
Live seems to change ever time I look… no scrolling required, but now it is an hour back but 8 minutes ahead…
Real time 01:38 - Chart displayed time on far right 00:46:49)
Super Chart is always showing Y axis values, although set to ‘off’ in datasteam settings. First device or app reset and here it is again, no chance to get rid of it. Did I miss some info regarding this issue?
There are already multiple data streams available in SuperChart. Just have to click on ‘Add DataStream’.
Edit: just have noticed that you asked the same question in multiple threads, please don’t do that. There are no more than 4 data streams available, most probably because it makes no sense to have more than four per chart - it would be unreadable and unusable. You can always add new SuperChart widget and attach as many streams as you want, in groups four by four.
Since the last update I can’t control two of my lights. They are controlled with an esp8266 on gpio2. This works fine with the last version that is running on my tablet.
