New Android Release 2.14.0
I should point out that im using local server… if that matters?
@Jamin Check the logs, maybe you’ll find server error response there. (Or send me the logs, but I won’t be near desktop untill tomorrow)
Probably. @Dmytro could know better
Looks like I have DB turned off… ill turn it on now… never had to worry about that before.
20:00:12.588 ERROR- Error sending dynamic email from application. For user b**@cu******bs.co.nz. Error:
java.lang.Exception: App Publishing Preview requires enabled DB.
	at cc.blynk.server.application.handlers.main.logic.MailQRsLogic.makeQRs(MailQRsLogic.java:144) ~[server.jar:?]
	at cc.blynk.server.application.handlers.main.logic.MailQRsLogic.lambda$mailDynamic$0(MailQRsLogic.java:90) ~[server.jar:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_111]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_111]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_111]
20:00:34.536 INFO - Updating face 1698398824 for user b**@cu******bs.co.nz.
EDIT: This same error after enabling DB in server.properties
20:17:02.378 ERROR- Error sending dynamic email from application. For user b*n@c*.nz. Error:
On Local server you need to enable DB in order to use app export.
You need now to create new app, as data for previous app had not been created due to unavailable db.
It’s been working fine without Blynk.Faces.
I tried creating a new app with the same project and got the same error.
Do I need to recreate the entire project too?
