Ah ah, The answer for the question I hadn’t yet asked.
I noticed that I couldn’t change tabs in edit mode anymore… but after moving 40 widgets in 3 tabs (like an oversized tile puzzle) I managed to move my Tab Bar to the top and now it works as normal
Wonderful guys. You don’t know how happy the extra space makes me. Not only scrollable tabs but scrollable screen. Beautiful unclutters screen now.
I feel like Oliver asking for more - but 2 things:
Am I missing how to delete a tab? I know I’ve asked for more tabs now I want to delete one!
It’s not obvious there are further tabs to left and right. Can there be an indicator?
similar for the scrollable screen. When you start to slide there is a scroll bar but this disappears when you finish scrolling. Minor one this one - indicator for tabs is more demanding.
Forgot to add a forth suggestion. Perhaps option to hide a tab in active mode. This way I could put all my control widgets out of sight i.e. timer, bridge, notify etc. Makes it tidier when sharing with people who do not want to see these widgets.
As of now, you cannot delete a “Tab” at random. You need to start deleting Tabs from the last Tab. Say, if you have 6 Tabs in total. You can remove “Tab 6” by swiping it left, then “Tab 5” and so on…
Will help. Sure there has to be an indicator!
Including indicators for both:
Tabs Widget Scrolling
Screen Vertical Scrolling
will give a suggestion to the user that there’s something hidden there to be explored
Also, with this update it would be cool, if the “Device Selector” widget can stay on top of the “Tabs” widget and also available throughout the app in all screens just like Tabs widget. This will provide a simple understandable functionality & ease of use…
With this current scenario, only Tabs can be the first widget. It is not possible to move it down or add any widget on top of Tabs. And thus stopping from adding the Device Selector on top of it…
There would be an indicator, as well as several other updates to the tabs, like better animations of tabs switch, restoring scroll and etc. To delete a tab - just open it’s settings (click on an already selected tab), and you could change existing tabs and remove the widget.
Is the first tab visible on the dashboard, when you are trying to move widgets to it? We will check this issue. If it is possible - could you send me via PM a screenshot of your dashboard with tabs?
