Have you ever dream to become a master of multiple devices? Now you can. With new Android release you can control multiple devices within 1 project.
This is very big, no - huge update so there may be some issues and problems. We did our best to fix all issues we found. In case you see something strange - please report and we will fix it ASAP.
In case you are using local server you have to update server to latest version.
Also project with multiple devices will not work on iOS. For those who donât need this feature nothing will be changed.
Whatâs new :
Support for multi devices. Basic doc. If something not clear - please ask;
YES, I DO!!! Another great step. You guys are awesome! Will check it next week (along with GSM support), as no time nowâŚ
@Dmytro Now one more thing (but not LAST, I hope): A PIN CODE TO ENTER EDIT MODE, and log out. AND THEN I will âhangâ a 7" tablet on my wall to create a SMART, âBLYNKEDâ HOME!!
There is no need for a such functionality. You could use projectâs sharing - and open that shared project on your tablet on the wall, in such case there would be even no possibility to open projectâs options and edit it, but on the âmasterâ device, on which project has been created, you could edit it and change if smth would need changes.
Seems to be OK (in basic functionality included in prev. version)
Nice map widget! Guess it is for tracking my wife, right? But parameters (index? value?) needs some explanation. Will wait for docs.
Yes, you right, I somehow forgot about it. Probably because it tries to drain my wallet from energy But Itâs OK, will be for sure used, when needed. Thanks!
@saurabh47 Purpose of this widget is to locate your hardware and not other phone⌠However I think some workaround here possible. Need to think about it.
I know
I just thinking of making device which will give notification on my father is at home or not ??
I know there is gps trigger widget .i want know his location to start my studies .
I have looked at the basic document and sketch. I am wondering about how often the location is updated? I am thinking in terms of when using cellular connection on my hardware. I dont need a lot of updates. As a matter of fact, used in conjunction with gps trigger, I only want location data when my device leaves the geofence. It will be nice when this is available for iOS too!
Thanks in advance.
Thanks for the reply. That is what I thought, wanted to verify. But I could use the gps trigger then too to only send gps location for when the device leaves the geofence correct?
