very new to this, im sure this is a very basic problem
i have a quickstart program loaded to the Arduino UNO board. very basic ethernet code trying to control a relay board.I am online with it…Virtual pins do not seem to be controlling my board through the BLYNK app.
any help would be appreciated.
I’m not sure how you expect members of this community to be able to provide assistance based on the information you’ve provided, especially considering that the Arduino UNO has no bu8t-in internet connectivity.
I’d suggest you read this topic…
Then edit your post to provide the level of information that is required for others to understand your hardware and software setup, and what exactly you are trying to achieve.
i have an ethernet shield attached to the UNO board.
If you’re going to drip-feed tiny pieces of information one comment at a time then I’ll step back from this topic and see if any of our clairvoyant community members can take a look into their crystal ball and help you that way. ![]()
Good luck!
sheesh man…rough on new guys aint ya…
i said i was new to this…asking for some help
what information was you needing? the script that i got from blynk?
I’ve given you a link to a topic that explains what is needed.
yes i have read the documents…again all new to this.
just not understanding how to get a virtual pin in the code to be an actual output (2-7) so i can can control a relay board.
i understand you have no idea what my code looks like…its a simple quickstart BLYNK code…i know that probably means nothing to you since you cant see it…not sure if i can drop my code in here or not…guess im just looking for a “put this here and see what that does”…and then i can learn more from there…im a ladder logic guy…this stuff is pretty cool but confusing
The topic I linked to explains how to post code correctly, using triple backticks to have it display correctly. If you really did read it then I think you would have seen that.
The Blynk documentation has some good virtual pin examples and explanations, but you’re probably not going to understand how to use the code examples.
Asking someone to tell you what to dump into your code isn’t going to work without them having an understanding of your hardware setup and existing code, and knowing whether your device is currently able to get online.
well, your just a pleasure to talk to… i hope other newbies can get advice from some other people that are just a bit more compassionate than you are…
post your code and your setup and we can have a look.
How do you expect people to help you when the only input you provide is “it’s not working”?
Statements such as:
“i understand you have no idea what my code looks like…its a simple quickstart BLYNK code…i know that probably means nothing to you since you cant see it…not sure if i can drop my code in here or not…guess im just looking for a “put this here and see what that does”…and then i can learn more from there…im a ladder logic guy…this stuff is pretty cool but confusing”
are not helping and only suggest your background in this field is (too) limited.
