i use WiFI Manager for config and connect wifi and some token.
when i use Edgent i think have issuse abot wifi connect.
I need only Air.OTA, Can i do it?
You should be careful with WiFi manager and Blynk IoT, however the answer to your question is here…
Dear Pete,
could you please share a full code? thanks a lot!
i means the basic full code. i am using esp32
Take a look at any of the Sketch Builder examples (link at the top of the page) then drop the OTA code into them.
