Costas -> 59 - 64…
@Costas, this ancient language was successfully powering my first internet connection at a blazing speed of 33,6 kbps! But the key is: Is it a Blynk library issue? Or ESP AT command implementation issue?? To be honest: I DO NOT KNOW, as I’m not aware of any other system using ESP connecting to MCU by means of AT comm.
Marvin you are old as me, mine was14,4kbps
lol
Then mine was faster… Or… I’m a bit younger
Yes that’s the righ question…maby ESP01 wont connect to blynk server without static settings set…
Can somebody confirm that?
blah, it was pretty much same period…
Wow… My first Vic Modem ran at 1200… and I had used that computer “off line” for years prior to that elevated option Yup, feeling old, but still got some teeth left
No, it works with DHCP (if this is what you are asking). But he question is: Is YOUR DHCP “the same” as mine?? And I believe Blynk has no control (or it does?) over DHCP handling through AT comm.
1200bps… Then you almost could see those bits running through cable
The ESP seems to handle all the connection, the router the DHCP and Blynk (via AT) just supplies the credentials with Blynk.begin(auth, wifi, ssid, pass, server, port);
or varient of such
You could hear them quite well
Yes, that is what I’m thinking…
So Costas here it is…
And please if would be easier consider me as very young newbie who wants fast answer and dirrect point where this issue was solved in forum? Please with link
do not blame my jokes i try to keep good atmosphere
Oh yes, I remember this “music” quite well. And your compared with mine was a smooth jazz… I think
2400 for me.
Reading the posts you referred to suggests you are having DHCP problems and as advised by others you do not need a static IP.
You mentioned the IR library, forget that for now.
I would go back to the basic shield sketch, without static IP, and tell us what happens.
The realmusic was on ZX spectrum on ZX processor but that iswhole another story Lol
What a bunch of youngsters! 1200bps with an acoustic coupler was the norm when I started trying to connect to bulletin boards to find answers on how to make my TRS-80 do what I wanted it to!
Yes smart coding considers small pieces code to bigger, same issues when i make it small as possible…I was trying this method small-bigger and I solved IR problems and many another, thanks for reading… .
So we are all generation Lol
Basic sketch is behaving the same, i must set static to work…also when i put brand new ESP, or I factory reset it.
Stick with the basic sketch and without static IP. You need to fix this issue.
Do you have Serial Monitor access or do you not have a USB2TTL adaptor?
Did you use questions like “help” and “show me” a lot back then
