Tengo un proyecto que me funciona en Arduino Mega con varios dispositivos
Mi problema es que tengo varios WidgetLED y todos me funcionan dentro de
cada BLYNK_WRITE() , pero no consigo que me ejecute mas vod o una rutina dentro…
que pueda utilizar para seguir programando cuando se activa un botton
It’s difficult to answer without seeing your code, but my guess is that it is a problem with the scope of your variables.
Try reading this and see if it answers your question:
If it doesn’t answer your question then please post your code (correctly formatted with triple backticks) and explain in detail wha is and what is not working.
And explain in detail what is and isn’t working. We aren’t going to spend time un-picking your code if you don’t take the time to explain the issue you are experiencing clearly.
Todos mis WidgetLED , Mis void, y los Blink_White … funcionan individual ok, pero cuando intento ampliar mas cosas dentro de un BLYNK_WHITE … no consigo controlar o parar los dispositivos dentro de ese codigo dentro de Blynk_White…Graciass
I never look at code that is not correctly formatted with triple backticks at the beginning and end, as explained in the text when you created this topic, and later by @daveblynk
Also, references to “devices” didn’t explain what your problems are and what problems you are experiencing. You will need to be more specific.
Okay, as you’re refusing to edit your unformatted code it has been removed.
If you wish to post code in the forum it must have triple backticks at the beginning and end so that it displays correctly.
