Hi I was hoping someone could explain to me why my project keeps going offline, ive added a re-connection sketch to my program but it doesnt seem to be working anymore. It was running well for about 2 weeks and now it seems to go offline every second day sometimes twice a day. Im running a arduino mega with ethernet shield Im not a fan of the ethernet shield but its all I got at the moment and it shouldnt be causing the program to go offline so often. please look at my sketch and tell me if theres anyway to improve its functionality
#include <Ethernet.h>
#define W5100_CS 10
#define SDCARD_CS 4
char auth[] = " ";
#define waterLevel_trigger 3 // Water level sensor
#define waterLevel_echo 9
#define hydroTrig 5 // Water level sensor
#define hydroEcho 6
#define MAX_DISTANCE 450
#define PI 3.1415926535897932384626433832795
#define TdsSensorPin A15
#define VREF 5.0 // analog reference voltage(Volt) of the ADC
#define SCOUNT 30 // sum of sample point
#include "DFRobot_PH.h"
#include <EEPROM.h>
#define PH_PIN A14
float voltage,phValue,temperature = 25;
DFRobot_PH ph;
#include <OneWire.h>
#define waterTemp 7
OneWire oneWire(waterTemp);
float Celcius=0;
float Fahrenheit=0;
#include <DHT.h>
#define DHT1 2 // What digital pin we're connected to
#define DHT2 8
#define DHTTYPE2 DHT11 // DHT 11
DHT dht1(DHT1, DHTTYPE);
DHT dht2(DHT2, DHTTYPE2);
const int Diameter1 = 40;
const int Depth1 = 56;
const int Diameter2 = 28;
const int Depth2 = 26;
const int Area1 = PI * ((Diameter1 / 2) * (Diameter1 / 2));
const int Area2 = PI * ((Diameter2 / 2) * (Diameter2 / 2));
int Litres1, Litres2, distance1, distance2, WaterDepth1, WaterDepth2;
void sendWaterlevel()
long duration, distance1;
digitalWrite(waterLevel_trigger, LOW);
delayMicroseconds(2);
digitalWrite(waterLevel_trigger, HIGH);
delayMicroseconds(10);
duration = pulseIn(waterLevel_echo, HIGH);
distance1 = (duration/2) / 29.1;
if (distance1 >= Depth1 || distance1 == 0 ) distance1 = Depth1;
WaterDepth1 = Depth1 - distance1;
Litres1 = (Area1 * WaterDepth1) / 1000;
Serial.print(distance1);
Serial.println("Centimeter");
Serial.println("Tank 1 water depth: " + String(WaterDepth1)); //print depth
Blynk.virtualWrite(V1, WaterDepth1);
Serial.println("Tank 1 Litres: " + String(Litres1)); //print litres
Blynk.virtualWrite(V8, Litres1);
delay(200);
void sendHydroLevel()
long duration, distance2;
digitalWrite(hydroTrig, LOW);
digitalWrite(hydroTrig, HIGH);
duration = pulseIn(hydroEcho, HIGH);
distance2 = (duration/2) / 29.1;
if (distance2 >= Depth2 || distance2 == 0 ) distance2 = Depth2;
WaterDepth2 = Depth2 - distance2;
Litres2 = (Area2 * WaterDepth2) / 1000;
Serial.print(distance2);
Serial.println("Hydro tank water depth: " + String(WaterDepth2)); //print depth
Blynk.virtualWrite(V12, WaterDepth2);
Serial.println("Hydro tank Litres: " + String(Litres2)); //print litres
Blynk.virtualWrite(V13, Litres2);
delay(200);
void sendDHT1Sensor()
float h = dht1.readHumidity();
float t = dht1.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT1 sensor!");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
void sendDHT2Sensor()
float h = dht2.readHumidity();
float t = dht2.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
Serial.println("Failed to read from DHT2 sensor!");
return;
Blynk.virtualWrite(V14, h);
Blynk.virtualWrite(V15, t);
const int dry = 589; // Moisture sensor reading while dry
const int wet = 295; // Moisture sensor reading while wet
void sendMoisture1()
int sensorVal0 = analogRead(A0);
int percentageHumidity0 = map(sensorVal0, wet, dry, 100, 0);
Blynk.virtualWrite(V4, percentageHumidity0);
Serial.print(percentageHumidity0);
Serial.println("%");
delay(100);
void sendMoisture2()
int sensorVal1 = analogRead(A1);
int percentageHumidity1 = map(sensorVal1, wet, dry, 100, 0);
Blynk.virtualWrite(V3, percentageHumidity1);
Serial.print(percentageHumidity1);
delay(100);
void sendMoisture3()
int sensorVal2 = analogRead(A2);
int percentageHumidity2 = map(sensorVal2, wet, dry, 100, 0);
Blynk.virtualWrite(V10, percentageHumidity2);
Serial.print(percentageHumidity2);
delay(100);
void sendMoisture4()
int sensorVal3 = analogRead(A3);
int percentageHumidity3 = map(sensorVal3, wet, dry, 100, 0);
Blynk.virtualWrite(V11, percentageHumidity3);
Serial.print(percentageHumidity3);
delay(100);
float corrective = 20.55; // calculate and change this value to calibrate
float averageValue = 0.00; // transit area, used in the calculations
int tabval[50]; // memorization table of 10 consecutive readings.
int temp = 0; // transit area, used in the sorting loop of read values
byte index = 0; // index table scrolling values
byte index1 = 0; // index used in the sort loop of the read values
float sumValues = 0; // sum of the 6 intermediate values detected on the analog pin 0
float PHaverage = 0; // PH calculated on the average of the voltages detected on pin 0
void sendPhSensor()
for (index = 0; index < 50; index++) // stores 50 readings
tabval[index] = analogRead(A5);
delay(60);
//rather interesting routine sorts values in tabval array, putting them in order, from lowest to
//highest.
for (index = 0; index < 49; index++)
for (index1 = index + 1; index1 < 50; index1++)
if (tabval[index] > tabval[index1])
temp = tabval[index];
tabval[index] = tabval[index1];
tabval[index1] = temp;
sumValues = 0; // resets the sum area of the values in advance
for (int index = 10; index < 39; index++) // when calculating the average, consider only the values
// intermediate, from the tenth to the thirty-ninth position in the tabval table.
sumValues += tabval[index]; // average of the six intermediate values stored in tabval
averageValue = (float)sumValues * 5.0 / 1024 / 30; // average voltage on the analog pin 0
PHaverage = -5.70 * averageValue + corrective; // PH calculation, from a formula found on the net
Serial.print("PH detected = ");
Serial.println(PHaverage);
Blynk.virtualWrite(V0, PHaverage);
int analogBuffer[SCOUNT]; // store the analog value in the array, read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0,copyIndex = 0;
float averageVoltage = 0,tdsValue = 0,temperatureTDS = 25;
void sendTDS()
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U) //every 40 milliseconds,read the analog value from the ADC
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin); //read the analog value and store into the buffer
analogBufferIndex++;
if(analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 800U)
for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)
analogBufferTemp[copyIndex]= analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF/ 1024.0; // read the analog value more stable by the median filtering algorithm, and convert to voltage value
float compensationCoefficient=1.0+0.02*(temperatureTDS-25.0); //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
float compensationVolatge=averageVoltage/compensationCoefficient; //temperature compensation
tdsValue=(133.42*compensationVolatge*compensationVolatge*compensationVolatge - 255.86*compensationVolatge*compensationVolatge + 857.39*compensationVolatge)*0.5; //convert voltage value to tds value
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
Serial.print("TDS Value:");
Serial.print(tdsValue,0);
Serial.println("ppm");
Blynk.virtualWrite(V2, tdsValue);
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
void sendWaterTemp()
Celcius=sensors.getTempCByIndex(0);
Fahrenheit=sensors.toFahrenheit(Celcius);
Serial.print(" C ");
Serial.print(Celcius);
Serial.print(" F ");
Serial.println(Fahrenheit);
Blynk.virtualWrite(V16, Celcius);
Blynk.virtualWrite(V17, Fahrenheit);
void sendGravityPH()
static unsigned long timepoint = millis();
if(millis()-timepoint>1000U) //time interval: 1s
voltage = analogRead(PH_PIN)/1024.0*5000; // read the voltage
//temperature = readTemperature(); // read your temperature sensor to execute temperature compensation
phValue = ph.readPH(voltage,temperature); // convert voltage to pH with temperature compensation
Serial.print("temperature:");
Serial.print(temperature,1);
Serial.print("^C pH:");
Serial.println(phValue,2);
ph.calibration(voltage,temperature); // calibration process by Serail CMD
float readTemperature()
//add your code here to get the temperature from your temperature sensor
void reconnectBlynk() {
if (!Blynk.connected()) {
Serial.println("Lost connection");
if(Blynk.connect()) {
Serial.println("Reconnected");
else {
Serial.println("Not reconnected");
Blynk.begin(auth); //Reguler server
Blynk.syncAll();
dht1.begin();
dht2.begin();
sensors.begin();
ph.begin();
pinMode(waterLevel_trigger, OUTPUT);
pinMode(waterLevel_echo, INPUT);
pinMode(hydroTrig, OUTPUT);
pinMode(hydroEcho, INPUT);
pinMode(TdsSensorPin,INPUT);
pinMode(SDCARD_CS, OUTPUT);
pinMode(22,OUTPUT); // 240v Output Pins
pinMode(23,OUTPUT);
pinMode(24,OUTPUT);
pinMode(25,OUTPUT);
pinMode(26,OUTPUT);
pinMode(27,OUTPUT);
pinMode(28,OUTPUT);
pinMode(29,OUTPUT);
pinMode(30,OUTPUT);
pinMode(31,OUTPUT);
pinMode(32,OUTPUT);
pinMode(33,OUTPUT);
pinMode(34,OUTPUT);
pinMode(35,OUTPUT);
pinMode(36,OUTPUT);
pinMode(37,OUTPUT);
pinMode(38,OUTPUT); // 12v Output Pins
pinMode(39,OUTPUT);
pinMode(40,OUTPUT);
pinMode(41,OUTPUT);
pinMode(42,OUTPUT);
pinMode(43,OUTPUT);
pinMode(44,OUTPUT);
pinMode(45,OUTPUT);
pinMode(46,OUTPUT);
pinMode(47,OUTPUT);
pinMode(48,OUTPUT);
pinMode(49,OUTPUT);
pinMode(50,OUTPUT);
pinMode(51,OUTPUT);
pinMode(52,OUTPUT);
pinMode(53,OUTPUT);
digitalWrite(22,HIGH); // 240v Relay Board
digitalWrite(23,HIGH);
digitalWrite(24,HIGH);
digitalWrite(25,LOW);
digitalWrite(26,LOW);
digitalWrite(27,HIGH);
digitalWrite(28,HIGH);
digitalWrite(29,HIGH);
digitalWrite(30,HIGH);
digitalWrite(31,HIGH);
digitalWrite(32,HIGH);
digitalWrite(33,HIGH);
digitalWrite(34,HIGH);
digitalWrite(35,HIGH);
digitalWrite(36,HIGH);
digitalWrite(37,HIGH);
digitalWrite(38,HIGH); // 12v Relay Board
digitalWrite(39,HIGH);
digitalWrite(40,HIGH);
digitalWrite(41,HIGH);
digitalWrite(42,HIGH);
digitalWrite(43,HIGH);
digitalWrite(44,HIGH);
digitalWrite(45,HIGH);
digitalWrite(46,HIGH);
digitalWrite(47,HIGH);
digitalWrite(48,HIGH);
digitalWrite(49,HIGH);
digitalWrite(50,HIGH);
digitalWrite(51,HIGH);
digitalWrite(52,HIGH);
digitalWrite(53,HIGH);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
timer.setInterval(30*1000, reconnectBlynk);
timer.setInterval(2500L, sendDHT1Sensor);
timer.setInterval(2000L, sendDHT2Sensor);
timer.setInterval(5000L, sendWaterTemp);
timer.setInterval(7500L, sendMoisture1);
timer.setInterval(6500L, sendMoisture2);
timer.setInterval(7000L, sendMoisture3);
timer.setInterval(6000L, sendMoisture4);
timer.setInterval(10000L, sendPhSensor);
timer.setInterval(1080L, sendGravityPH);
timer.setInterval(3000L, sendWaterlevel);
timer.setInterval(2500L, sendTDS);
if(Blynk.connected()) { Blynk.run(); }
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
