Since then, it works without problems even when the battery is discharged and charged.
Super les petites images sur Blynk mais comment les obtenir?Merci dâavance
Soit tu les dĂ©poses sur un site de stockage dâimages genre noelshack et tu copies le lien dans image URL .
Soit sur ton serveur local si tu utilises blynk local serveur.
Dans ce dernier cas , il te faudra installer un serveur python, câest trĂšs simple Ă mettre en place.
I think theyâre actually emojis.
So, itâs quite easy.
Hi Guys,
Did anyone here include UV radiation sensor in their WXR Station? Iâm using (attempting to use) a Sparkfun VEML6075 - using the example sketches in the Sparkfun library i consistently get very, VERY low (1-3) UV Index readings, even in full, Australian summer sun - I would expect readings 9-12 in these conditions. I have also asked this Q on the Sparkfun forum, buth though you guys may have come across this issue also?
thnx
billd
I found this directory, and beware that the polycarbonate front boxes shield the uv.
Thnx, Iâve tried that library/examples also, I get the same result . . .
cul
billd
The Blynk RTC widget is maybe a nicer solution than using NTP.
I wrote both (scissors together) for some reason ntp is more sympathetic to me.
Why ?
Itâs simply a case of adding the RTC widget to the app project and a few lines of code to the sketch to get the time from the Blynk server. No need to make external calls to NPT servers or do anything else.
Ah ok, I use both method .
One of my project use France NPT servers.
Are you using a computer keyboard or phone to input code?
Edit: If computer tap your top left button three times. (Or if different keyboard google âback tickâ)
Also for phone google âback tickâ for your OS.
For apple hold character shown.
And slide all left.
Phone
please edit your code
``` instead of ``
#include <Time.h>
#ifndef ESP32
#error This code is intended to run on the ESP32 platform! Please check your Tools->Board setting.
#endif
#define USE_BLYNK_WM false
#define USE_SSL false
#define USE_LOCAL_SERVER false
#if USE_SSL
#include <WiFiClientSecure.h>
#else
#include <WiFiClient.h>
#endif
#if USE_BLYNK_WM
// Not use #define USE_SPIFFS => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS false => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS true => using SPIFFS for configuration data in WiFiManager
// Be sure to define USE_SPIFFS before #include <BlynkSimpleEsp8266_WM.h>
//#define USE_SPIFFS true
#if (!USE_SPIFFS)
// EEPROM_SIZE must be <= 4096 and >= CONFIG_DATA_SIZE (currently 172 bytes)
#define EEPROM_SIZE (4 * 1024)
// EEPROM_START + CONFIG_DATA_SIZE must be <= EEPROM_SIZE
#define EEPROM_START 2048
#endif
// Force some params in Blynk, only valid for library version 1.0.1 and later
#define TIMEOUT_RECONNECT_WIFI 10000L
#define RESET_IF_CONFIG_TIMEOUT true
#define CONFIG_TIMEOUT_RETRYTIMES_BEFORE_RESET 5
// Those above #define's must be placed before #include <BlynkSimpleEsp8266_WM.h>
#if USE_SSL
#include <BlynkSimpleEsp32_SSL_WM.h> // https://github.com/khoih-prog/Blynk_WM
#else
#include <BlynkSimpleEsp32_WM.h> // https://github.com/khoih-prog/Blynk_WM
#endif
#else
#if USE_SSL
#include <BlynkSimpleEsp32_SSL.h>
#define BLYNK_SERVER_HARDWARE_PORT 9443 // blynk server SSL port
#else
#include <BlynkSimpleEsp32.h>
#define BLYNK_SERVER_HARDWARE_PORT 8080 // blynk server port
#endif
char ssid[] = ""; // wifi SSID
char pass[] = ""; // wifi password
#if USE_LOCAL_SERVER
char auth[] = ""; // Local Blynk server token
char server[] = "accout.duckdns.org"; // blynk server
#else
char auth[] = ""; //Cloud Blynk server token
char server[] = "blynk-cloud.com"; // Cloud Blynk server
#endif
#endif
#define DEBUG_ON
#include <NTPClient.h>
#include <WidgetRTC.h>
#include <TimeLib.h>
#include <WiFi.h>
#include <ESPmDNS.h>
#include <WiFiUdp.h>
WiFiUDP udp;
#include <ArduinoOTA.h>
#include <BME280I2C.h> //https://github.com/finitespace/BME280/tree/master/src
#include <Wire.h>
#include <NTPtimeESP.h>
BME280I2C bme;
#define uS_TO_S_FACTOR 1000000
#define TIME_TO_SLEEP 600 //set deep sleep time (in seconds)
#define COUNT_PERIOD 5000 // measure interval (ms)
#define DEBOUNCE_TIME 40
#define RADIUS (90.0f) // in mm
#define PIxRADIUS (PI * RADIUS)
#define RAIN_AMOUNT (0.274f) // Precipitation
#define VOLT_DETECTION_PIN 34 // voltage detection pin number
#define RAIN_GAUGE_PIN 14 // Rain pin number
#define WIND_SPEED_PIN 35 // wind speed pin number
#define UV_INDEX_PIN 36 // UV Index detection pin number
#define WIND_DIRECTION_PIN 39 // Wind direction pin number
#define BLYNK_VPIN_WIND_DIRECTION V1
#define BLYNK_VPIN_TEMP V2
#define BLYNK_VPIN_WIND_SPEED V3
#define BLYNK_VPIN_HUMID V4
#define BLYNK_VPIN_RAIN_AMOUNT V5
#define BLYNK_VPIN_PRESSURE V6
#define BLYNK_VPIN_HALL_SENSOR V7
#define BLYNK_VPIN_WIND_DIRECTION_BIN V8
#define BLYNK_VPIN_NTP_TIME V9
#define BLYNK_VPIN_CPU_TEMP2 V10
#define BLYNK_VPIN_BATT_VOLT V11
#define BLYNK_VPIN_UV_INDEX V12
#define BLYNK_VPIN_NTP_DATE V13
#define BLYNK_VPIN_DEW_POINT2 V14
#define BLYNK_VPIN_RSSI1 V15
#define BLYNK_VPIN_NTPLED V16
#define BLYNK_VPIN_LAST_DAY_RAIN V17
int Wdir = 0;
int measurement = 0;
unsigned int Sample = 0; // Sample number
unsigned int RPM = 0; // Revolutions per minute
float windSpeedMetrePerSec = 0; // Wind speed (m/s)
float windSpeedKmPerHr = 0; // Wind speed (km/h)
float voltage = (((float)analogRead(VOLT_DETECTION_PIN) * (3.3 / 4095)) * 2) + 0.24; // battery voltage
float UVIndex = ((((float)analogRead(UV_INDEX_PIN) * (3.3 / 4095)) - 0.99)*8.333); // UV Index ML8511
float windDirection = ((float)analogRead(WIND_DIRECTION_PIN)); // Wind direction
volatile unsigned int counter = 0; // magnet counter for sensor
volatile unsigned int currentCount;
volatile float totalAmount = 3;
volatile float lastRainAmount;
volatile float lastday;
volatile long startTime;
volatile long RainstartTime;
volatile bool windDataReady = false;
volatile bool rainDataReady = false;
volatile int last_windspeed_interrupt = 0;
volatile int currMillis;
static long RainlastMillis = 0;
static long RaincurrMillis;
String currentTime;
String currentDate;
const String MyDayOfWeek[7] = {"VasĂĄrnap", "HĂ©tfĆ", "Kedd", "Szerda", "CsĂŒtörtök", "PĂ©ntek", "Szombat"};
String printDigits(int digits)
String new_digits = ":";
if (digits < 10) {
new_digits += "0";
new_digits += String(digits);
return new_digits;
#ifdef __cplusplus
extern "C" {
#endif
uint8_t temprature_sens_read();
#ifdef __cplusplus
#endif
WidgetRTC rtc;
WidgetLED ledntp(BLYNK_VPIN_NTPLED);
NTPClient timeClient(udp, "europe.pool.ntp.org", 3600, 60000);
NTPtime NTPch("ch.pool.ntp.org"); // Choose server pool as required
* The structure contains following fields:
* struct strDateTime
byte hour;
byte minute;
byte second;
int year;
byte month;
byte day;
byte dayofWeek;
boolean valid;
strDateTime dateTime;
BLYNK_CONNECTED()
rtc.begin();
Blynk.syncAll();
void IRAM_ATTR RainSensor();
void IRAM_ATTR WindSpeedSensor();
pinMode(RAIN_GAUGE_PIN, INPUT);
pinMode(WIND_SPEED_PIN, INPUT);
pinMode(WIND_DIRECTION_PIN, INPUT);
pinMode(UV_INDEX_PIN, INPUT);
pinMode(VOLT_DETECTION_PIN, INPUT);
#if USE_BLYNK_WM
Blynk.begin("ESP32-Weather-Station");
#else
WiFi.mode(WIFI_STA);
Blynk.connectWiFi(ssid, pass);
Blynk.config(auth, server, BLYNK_SERVER_HARDWARE_PORT);
Blynk.connect();
#endif
ArduinoOTA.setHostname("Weather-Station");
ArduinoOTA.begin();
Blynk.setProperty(BLYNK_VPIN_WIND_DIRECTION, "rotation", Wdir);
Wire.begin();
while (!bme.begin()) //start BME 280
Serial.println("Could not find BMP280 sensor!");
switch (bme.chipModel())
case BME280::ChipModel_BME280:
Serial.println("Found BMP280 sensor! Success.");
break;
case BME280::ChipModel_BMP280:
Serial.println("Found BMP280 sensor! No Humidity available.");
break;
default:
Serial.println("Found UNKNOWN sensor! Error!");
CalibrateTimeWithNTP();
sendSensor();
timer.setInterval(500L, measureAll);
timer.setInterval(10000L, CalibrateTimeWithNTP);
timer.setInterval(300000L, sendSensor);
attachInterrupt(digitalPinToInterrupt(WIND_SPEED_PIN), WindSpeedSensor, RISING);
attachInterrupt(digitalPinToInterrupt(RAIN_GAUGE_PIN), RainSensor, FALLING);
// start timing
startTime = millis();
Blynk.run(); //start the Blynk sketch
timer.run(); //start the timer
ArduinoOTA.handle();
void measureAll()
currMillis = millis();
if (currMillis >= startTime + COUNT_PERIOD )
startTime = currMillis;
currentCount = counter;
counter = 0;
windDataReady = true;
WindDir();
RainCalc();
WindVelocity();
void sendSensor()
static float temp(NAN), hum(NAN), pres(NAN);
static float voltage; // battery voltage
static float UVIndex; // UV Index
static float windDirection; // Széliråny
static double gamma; // calculate dewpoint
static double dp; // calculate dewpoint
static long rssi; // read signal strength
measurement = hallRead();
BME280::TempUnit tempUnit(BME280::TempUnit_Celsius); // read BME 280
BME280::PresUnit presUnit(BME280::PresUnit_hPa); // read BME 280
bme.read(pres, temp, hum, tempUnit, presUnit); // read BME 280
if (UVIndex < 0) UVIndex = 0;
windDirection = ((float)analogRead(WIND_DIRECTION_PIN)); // Széliråny
gamma = log(hum / 100) + ((17.62 * temp) / (243.5 + temp)); // calculate dewpoint
dp = 243 * gamma / (17.62 - gamma); // calculate dewpoint
rssi = WiFi.RSSI();
Blynk.setProperty(BLYNK_VPIN_WIND_DIRECTION, "rotation", Wdir); // image rotating to wind direction
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION, 1);
Blynk.virtualWrite(BLYNK_VPIN_TEMP, temp); //temperature
Blynk.virtualWrite(BLYNK_VPIN_WIND_SPEED, windSpeedKmPerHr); //Wind speed
Blynk.virtualWrite(BLYNK_VPIN_HUMID, hum); //humidity
Blynk.virtualWrite(BLYNK_VPIN_RAIN_AMOUNT, totalAmount); //Rain amount
Blynk.virtualWrite(BLYNK_VPIN_PRESSURE, pres); //pressure
Blynk.virtualWrite(BLYNK_VPIN_HALL_SENSOR, measurement); //hallsensor
Blynk.virtualWrite(BLYNK_VPIN_CPU_TEMP2, (temprature_sens_read() - 32) / 1.8); //CPU Temp
Blynk.virtualWrite(BLYNK_VPIN_BATT_VOLT, voltage); //Battery Voltage
Blynk.virtualWrite(BLYNK_VPIN_UV_INDEX, UVIndex); //UV index
Blynk.virtualWrite(BLYNK_VPIN_DEW_POINT2, dp); //Dew point
Blynk.virtualWrite(BLYNK_VPIN_RSSI1, rssi); //rssi
// Serial.println("Sleeping now !);
// delay(500);
// esp_sleep_enable_timer_wakeup((uint64_t)TIME_TO_SLEEP * uS_TO_S_FACTOR); //set deepsleep time
// esp_deep_sleep_start(); //deepsleep start
// delay(100);
void WindDir()
if (windDirection < 190)
Wdir = 270; // W
else if (windDirection < 420)
Wdir = 315; // NW
else if (windDirection < 700)
Wdir = 292.5; // W-NW
else if (windDirection < 900)
Wdir = 0; // N
else if (windDirection < 1300)
Wdir = 337.5; // N-NW
else if (windDirection < 1500)
Wdir = 225; // SW
else if (windDirection < 1600)
Wdir = 247.5; // W-SW
else if (windDirection < 2250)
Wdir = 45; // NE
else if (windDirection < 2400)
Wdir = 22.5; // N-NE
else if (windDirection < 2900)
Wdir = 180; // S
else if (windDirection < 3100)
Wdir = 202.5; // S-SW
else if (windDirection < 3400)
Wdir = 135; // SE
else if (windDirection < 3600)
Wdir = 157.5; // S-SE
else if (windDirection < 3840)
Wdir = 90; // E
else if (windDirection < 3950)
Wdir = 67, 5; // E-NE
else if (windDirection < 4095)
Wdir = 112.5; // E-SE
Wdir = 0; // N
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION, 1); // image number
void RainCalc()
if (( dateTime.day != lastday ) && ( dateTime.valid))
noInterrupts();
lastRainAmount = totalAmount;
totalAmount = 0;
ledntp.on();
lastday = dateTime.day;
interrupts();
noInterrupts();
ledntp.off();
interrupts();
Blynk.virtualWrite(BLYNK_VPIN_RAIN_AMOUNT, totalAmount); // Today's Rainfall
Blynk.virtualWrite(BLYNK_VPIN_LAST_DAY_RAIN, lastRainAmount); // Yesterday's Rainfall
RaincurrMillis = millis();
if (RaincurrMillis >= RainlastMillis + (DEBOUNCE_TIME*2))
totalAmount += RAIN_AMOUNT;
RainlastMillis = RaincurrMillis;
void WindVelocity()
if (windDataReady)
noInterrupts();
RPM = (( currentCount * 12 )/2);
interrupts();
//windSpeedKmPerHr = ((4 * PIxRADIUS * RPM) / 60) / 1000; // Calculate wind speed on m/s
windSpeedMetrePerSec = (RPM * (2*PIxRADIUS)) / 60000;
windSpeedKmPerHr = windSpeedMetrePerSec * 3.6; // Calculate wind speed on km/h
Blynk.virtualWrite(BLYNK_VPIN_WIND_DIRECTION_BIN, RPM);
Blynk.virtualWrite(BLYNK_VPIN_WIND_SPEED, windSpeedKmPerHr); // Wind speed sending
if ( micros() - last_windspeed_interrupt >= 250 )
counter++;
last_windspeed_interrupt = micros();
void CalibrateTimeWithNTP()
// first parameter: Time zone in floating point (for India); second parameter: 1 for European summer time; 2 for US daylight saving time; 0 for no DST adjustment; (contributed by viewwer, not tested by me)
dateTime = NTPch.getNTPtime(1.0, 1);
// check dateTime.valid before using the returned time
// Use "setSendInterval" or "setRecvTimeout" if required
if(dateTime.valid){
NTPch.printDateTime(dateTime);
byte actualHour = dateTime.hour;
byte actualMinute = dateTime.minute;
byte actualsecond = dateTime.second;
int actualyear = dateTime.year;
byte actualMonth = dateTime.month;
byte actualday = dateTime.day;
byte actualdayofWeek = dateTime.dayofWeek;
String currentTime = String(dateTime.hour) + printDigits(dateTime.minute);
String currentDate = String(dateTime.year) + "." + dateTime.month + "." + dateTime.day + " " + MyDayOfWeek[(dateTime.dayofWeek)-1];
Blynk.virtualWrite(BLYNK_VPIN_NTP_TIME, currentTime); //Time
Blynk.virtualWrite(BLYNK_VPIN_NTP_DATE, currentDate); //Date
// ez nincs itt :P
Please use 3 ``` , not 2
