#define BLYNK_DEVICE_NAME "----"
#define BLYNK_AUTH_TOKEN "----"
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "MAX30100_PulseOximeter.h"
char auth[] = BLYNK_AUTH_TOKEN ; // You should get Auth Token in the Blynk App.
char ssid[] = "---i"; // Your WiFi credentials.
char pass[] = "----";
#define REPORTING_PERIOD_MS 3000
PulseOximeter pox;
uint32_t tsLastReport = 0;
void onBeatDetected()
// for the OLED display
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//Wire.begin(D2, D1);//sda,scl
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
Serial.print("Initializing pulse oximeter..");
// Initialize the PulseOximeter instance
// Failures are generally due to an improper I2C wiring, missing power supply
// or wrong target chip
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
digitalWrite(1,HIGH);
pox.setIRLedCurrent(MAX30100_LED_CURR_24MA);
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
timer.setInterval(3000L, getSendData);
display.clearDisplay();
display.setTextColor(WHITE);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
int a = 0;
Serial.print(".");
display.setCursor(a, 0);
display.print(".");
delay(500);
a++;
Serial.println("");
display.setTextSize(1);
display.setCursor(0, 0);
display.print("WiFi connected");
Serial.print("IP address: ");
display.setCursor(0, 1);
display.print(WiFi.localIP());
delay(500);
//Blynk.begin();
//WiFi.begin(ssid, pass);
//timer.setInterval(2000L, checkBlynkStatus);
float Hr = pox.getHeartRate();
float SpO2 = pox.getSpO2();
//float temp = mlx.readObjectTempC();
// Make sure to call update as fast as possible
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
// to android cell phone application
Serial.print("BPM: ");
Serial.print(pox.getHeartRate());
//blue.println("\n");
Serial.print("SpO2: ");
Serial.print(pox.getSpO2());
Serial.print("%");
Serial.println("\n");
Blynk.virtualWrite(V0,pox.getHeartRate() );
if(Hr <= 50 ){
Blynk.notify("Low Heart Rate Alert");
//bot.sendMessage(CHAT_ID, "Low Heart Rate Alert!!", "");
if(Hr >= 150){
Blynk.notify("High Heart Rate Alert!!");
//bot.sendMessage(CHAT_ID, "High Heart Rate Alert!!", "");
Blynk.virtualWrite(V1,pox.getSpO2());
if(SpO2 <=93){
Blynk.notify("SpO2 Abnormal Alert");
//bot.sendMessage(CHAT_ID, "SpO2 Abnormal Alert", "");
tsLastReport = millis();
void getSendData()
// Oled display
// display R G B Values
display.setTextSize(2);
display.setCursor(0,0); // column row
display.print("BPM:");
display.setCursor(55, 0);
display.print(pox.getHeartRate());
display.setCursor(0,50);
display.print("SpO2:");
display.setCursor(60, 50);
display.print(pox.getSpO2());
display.setCursor(95, 50);
display.print("%");
display.display();
First of all, you should read this
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
Blynk.notify has been replaced with Blynk.logEvent
https://docs.blynk.io/en/getting-started/events-tutorial?q=Event
i already change to Blynk.logEvent but it still didn’t send notification
You need to:
- Use existing or create new event in your template.
- Enable notifications for that event.
- in Blynk.logEvent use appropriate event’s id.
If all above has been done - check Blynk app’s Settings screen in case you have disabled notifications.
Posting your updated code would be a good starting point.
It would also be a good idea to post a screenshot showing how you’ve configured the event you’ve set-up for this, both the General and the Notifications tabs for that event.
Reading this tutorial is probably a good idea too…
