Pete, I have tried both Arduino IDE versions. The result is the same.
I am confused about the verbose output you have mentioned. It is turned on in file/preferences to be shown for compilation. This is exactly 20 lines after compile attempt in Arduino IDE 1.8.13
I have also tried to use BlynkTimer timer; instead of SimpleTimer timer; in both versions without success.
C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266mDNS
Using library ArduinoOTA at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ArduinoOTA
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPUpdateServer
Using library Blynk at version 0.6.1 in folder: C:\Users\Bill\Documents\Arduino\libraries\Blynk
Using library SimpleTimer at version 1.0.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\SimpleTimer
Using library Wire at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire
Using library MAX31855 in folder: C:\Users\Bill\Documents\Arduino\libraries\MAX31855 (legacy)
Using library Adafruit_GFX_Library at version 1.10.4 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.4.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\SPI
Using library Time-master at version 1.6 in folder: C:\Users\Bill\Documents\Arduino\libraries\Time-master
Using library RunningMedian at version 0.2.1 in folder: C:\Users\Bill\Documents\Arduino\libraries\RunningMedian
Using library Adafruit_BusIO at version 1.7.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
Interestingly, when I just re-compiled the code just now I received this errorâŚ
Using library Time at version 1.6 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Time
Using library RunningMedian at version 0.1.15 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\RunningMedian
Using library Adafruit_BusIO at version 1.7.1 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
Then I realised that I hadnât copied/pasted all of the code and that I was missing the void loop. When I copied/pasted it again and selected all of the code it compiled successfully.
Is it possible that you didnât copy paste everything from the original sketch?
I was hoping I didnt copied the whole code, but that is not the case. All 587 lines of code is there. Is there a way to have some better error log where we can see what exactly is the problem? I am not a programmer, and have no clue how to troubleshoot this other than what Im advised here. It is a pity, but it seams I`ll do my BBQ Amish style.
Does anyone have a reliable ebay or aliexpress foodtype k probe link? The vijf different that i orderd seem to be ntc types and not K, so de max31855 gives a not connected message.
