So, to answer my earlier question, you have ESP Core version 2.6.3 installed
I would have expected this to say something like:
Library ArduinoOTA at version 1.x in folder: \ArduinoData\packages\esp8266\hardware\esp8266\2.6.3\libraries\ArduinoOTA
It seems that you’ve installed a different OTA library, rather than the one included in the ESP core.
I don’t think the problem is coming from the ArduinoOTA.
I just removed the includes and code refering to OTA, webserver, DNS and httpupdates :
//#include <ESP8266mDNS.h>
//#include <WiFiUdp.h>
//#include <ArduinoOTA.h>
//#include <ESP8266WebServer.h>
//#include <ESP8266HTTPUpdateServer.h>
But still the same error on the SimpleTimer:
error: redefinition of ‘class BlynkTimer’ #define SimpleTimer BlynkTimer
SimpleTimer and BlynkTimer are two different things.
BlynkTimer is an updated and improved version of SimpleTimer and is included in the Blynk library and available without the need to specifically include it.
This makes no sense to me and I can’t see it in the original code.
Real cool project am getting the components together however as yet I have been unable to compile the code I keep getting the error “‘MAX31855’ does not name a type”
I have tried the Adafruit Library as well as others but to avail.
Could you please let me know which library you used and if possible the link to download it.
Much obliged
The code in post #1 compiles fine for me.
I have the Adafruit libraries installed.
I suspect that you’re missing one of the Adafruit helper libraries, such as “Adafruit_GFX_Library”, or that one or more of the Adafruit libraries is out of date.
When I compile the code (with verbose output turned on) I get this summary at the end…
Multiple libraries were found for "Adafruit_SSD1306.h"
Used: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_SSD1306
Not used: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_SSD1306-esp8266-64x48
Not used: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_SSD1306-1.1.2
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266mDNS
Using library ArduinoOTA at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ArduinoOTA
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\ESP8266HTTPUpdateServer
Using library Blynk at version 0.6.1 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Blynk
Using library SimpleTimer in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\SimpleTimer (legacy)
Using library Wire at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\Wire
Using library MAX31855 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\MAX31855 (legacy)
Using library Adafruit_GFX_Library at version 1.9.0 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.3.1 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\Pete Knight\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.2\libraries\SPI
Using library Time at version 1.6 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Time
Using library RunningMedian at version 0.1.15 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\RunningMedian
Using library Adafruit_BusIO at version 1.3.3 in folder: C:\Users\Pete Knight\Documents\Arduino\libraries\Adafruit_BusIO
"C:\\Users\\Pete Knight\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-size" -A "C:\\Users\\PETEKN~1\\AppData\\Local\\Temp\\arduino_build_648148/sketch_aug02a.ino.elf"
Sketch uses 359212 bytes (34%) of program storage space. Maximum is 1044464 bytes.
Global variables use 32136 bytes (39%) of dynamic memory, leaving 49784 bytes for local variables. Maximum is 81920 bytes.
Thanks for the reply Peter.
I have updated the Adafruit GFX library as well as all others.
I do not find the ESP8266-12F in the board manager so used the NodeMCU 1.0 (ESP-12E Module) to try to compile it however still the same problem.
I updated the board manager the ESP8266 v2.7.3 is installed.
Here is the verbose output.
Used: C:\Users\doart\OneDrive\Arduino\libraries\Time
Not used: C:\Users\doart\OneDrive\Arduino\libraries\Time-master
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\ESP8266mDNS
Using library ArduinoOTA at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\ArduinoOTA
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\ESP8266HTTPUpdateServer
Using library Blynk at version 0.6.1 in folder: C:\Users\doart\OneDrive\Arduino\libraries\Blynk
Using library Wire at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\Wire
Using library MAX31855-master at version 0.0.1 in folder: C:\Users\doart\OneDrive\Arduino\libraries\MAX31855-master
Using library SPI at version 1.0 in folder: C:\Users\doart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3\libraries\SPI
Using library Adafruit-GFX-Library-master at version 1.9.0 in folder: C:\Users\doart\OneDrive\Arduino\libraries\Adafruit-GFX-Library-master
Using library Adafruit_SSD1306-master at version 2.3.1 in folder: C:\Users\doart\OneDrive\Arduino\libraries\Adafruit_SSD1306-master
Using library Time at version 1.5 in folder: C:\Users\doart\OneDrive\Arduino\libraries\Time
Using library RunningMedian at version 0.1.15 in folder: C:\Users\doart\OneDrive\Arduino\libraries\RunningMedian
Using library Adafruit_BusIO at version 1.4.1 in folder: C:\Users\doart\OneDrive\Arduino\libraries\Adafruit_BusIO
exit status 1
Pete thank you so much for your help it is much appreciated indeed.
Yes that was the problem it now compiles OK.
I missed that post #48 it is a blighter when one gets old it is even more so when the eyesight lets you down.
Again thanks now I can proceed.
Hi there BBQ lovers. Dave, thanks for sharing this nice project.
I have a problem using this suggested library: https://github.com/engineertype/MAX31855
“Specified folder/zip file does not contain a valid library”
I have tried with a few other MAX31855 libraries, but no luck.
Thanks Pete. I have tried that too but still can`t compile. Here is my verbose…
"C:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" "C:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/signing.py" --mode header --publickey "C:\\Users\\Bill\\Documents\\Arduino\\double k probe bbq temp monitor blynk\\double_k_probe_bbq_temp_monitor_blynk/public.key" --out "C:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699/core/Updater_Signing.h"
"C:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/include" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/lwip2/include" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10814 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\cores\\esp8266" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\variants\\generic" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ArduinoOTA" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266WebServer\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266HTTPUpdateServer\\src" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Blynk\\src" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\Wire" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\MAX31855" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\SPI" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\RunningMedian" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699\\sketch\\double_k_probe_bbq_temp_monitor_blynk.ino.cpp" -o "C:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699\\sketch\\double_k_probe_bbq_temp_monitor_blynk.ino.cpp.o"
In file included from C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:17:0,
from C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:24,
from C:\Users\Bill\Documents\Arduino\double k probe bbq temp monitor blynk\double_k_probe_bbq_temp_monitor_blynk\double_k_probe_bbq_temp_monitor_blynk.ino:15:
C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
C:\Users\Bill\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: previous definition of 'class BlynkTimer'
C:\Users\Bill\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266mDNS
Using library ArduinoOTA at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ArduinoOTA
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPUpdateServer
Using library Blynk at version 0.6.1 in folder: C:\Users\Bill\Documents\Arduino\libraries\Blynk
Using library SimpleTimer at version 1.0.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\SimpleTimer
Using library Wire at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\Wire
Using library MAX31855 in folder: C:\Users\Bill\Documents\Arduino\libraries\MAX31855 (legacy)
Using library Adafruit_GFX_Library at version 1.10.4 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.4.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\Bill\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\SPI
Using library Time-master at version 1.6 in folder: C:\Users\Bill\Documents\Arduino\libraries\Time-master
Using library RunningMedian at version 0.2.1 in folder: C:\Users\Bill\Documents\Arduino\libraries\RunningMedian
Using library Adafruit_BusIO at version 1.7.0 in folder: C:\Users\Bill\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
Error compiling for board Generic ESP8266 Module.
True. I have updated. I have comparing mine to yours. They are mostly the same except I have some libraries with the newer version. I have also tried to compile it for various boards, but does not help.
I have reinstalled both SimpleTimer and Time libraries. I changed to ESP8266 to see if it helps. My board is with ESP8266MOD chip. I have tried to compile it for NodeMCU 0.9 (ESP12 module) too with no luck.
Compiling sketch...
"C:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-4-b40a506/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/include" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/lwip2/include" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++11 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10814 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU\"" -DFLASHMODE_QIO -DESP8266 "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\cores\\esp8266" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\variants\\nodemcu" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266mDNS\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ArduinoOTA" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266WebServer\\src" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\ESP8266HTTPUpdateServer\\src" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Blynk\\src" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\Wire" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\MAX31855" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\Bill\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.7.4\\libraries\\SPI" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\RunningMedian" "-IC:\\Users\\Bill\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699\\sketch\\double_k_probe_bbq_temp_monitor_blynk.ino.cpp" -o "C:\\Users\\Bill\\AppData\\Local\\Temp\\arduino_build_104699\\sketch\\double_k_probe_bbq_temp_monitor_blynk.ino.cpp.o"
class SimpleTimer {
class SimpleTimer {
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
Tried all. Did not help. I have never had much problem with compiling the code for any project. Pretty discouraging as I know it works for other people, but not to me.
try clearing your cache, or restarting your computer?
FWIW this is my library list from the complier output when verifying my latest BBQ code (i.e. not the original code!):
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WiFi
Using library ESP8266mDNS at version 1.2 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266mDNS
Using library ArduinoOTA at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ArduinoOTA
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ESP8266HTTPUpdateServer
Using library Blynk at version 0.6.1 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\Blynk
Using library Wire at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\Wire
Using library MAX31855-master in folder: C:\Users\Portegei5\Documents\Arduino\libraries\MAX31855-master (legacy)
Using library Adafruit_GFX_Library at version 1.2.2 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 1.1.2 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\Adafruit_SSD1306
Using library SPI at version 1.0 in folder: C:\Users\Portegei5\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\SPI
Using library Time at version 1.6 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\Time
Using library RunningMedian in folder: C:\Users\Portegei5\Documents\Arduino\libraries\RunningMedian (legacy)
Using library OneWire at version 2.3.4 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.8.0 in folder: C:\Users\Portegei5\Documents\Arduino\libraries\DallasTemperature
"C:\\Users\\Portegei5\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-size" -A "C:\\Users\\PORTEG~1\\AppData\\Local\\Temp\\arduino_build_216237/_201129_KPROBE_monitoring_dual_MAX31855_DS18B_OLED.ino.elf"
Sketch uses 361116 bytes (34%) of program storage space. Maximum is 1044464 bytes.
Global variables use 33628 bytes (41%) of dynamic memory, leaving 48292 bytes for local variables. Maximum is 81920 bytes.
(yes, i don’t seem to update my libraries very often! ooops…)
I’ve just re-compiled the code on my machine and compared the results…
You appear to be running version 1.8.14 of the Arduino IDE.
As of today, the current stable release is 1.8.13 (which is what I’m running), so I assume that you are running one of the ‘nightly build’ preview versions.
What you’ve posted isn’t actually the output that you’d get if you turned-on verbose output during compilation in File/Preferences.
Can I suggest that you turn this on, and post the last 20 lines of output that this produces?
