Hi All,
I am new, I would like to make two motor work on the Raspberry PiB+ and control on Blynk app but nothing working. Please someone help me and le me know what wrong with this code?
Thanks, to all your time and input
MinhP
- edited - Mod
Hi All,
MinhP
You need to edt your post(s) to format your code correctly.
Hi Peter,
Please let me know more detail about edit code?
Thanks,
MP
When you created your post, it contained information about the type of information you should include, and how to format your code so that it displays correctly. You appear to have deleted that information without taking the information onboard.
This is how you format your code correctly…
The directions are in the Welcome topic and were in the post text you deleted when entering your own issue ![]()
Oops… duplicate responses again
I need to look up at the screen instead of down at the KB more often
Sorry, I am new. I have not seen as you said about correct format code.
That is why there is a WELCOME topic (try clicking on the link I posted above)
All forums have something similar for new users to learn the ropes.
You still don’t appear to have formatted the code correctly, and you seem to be missing a large piece of code.
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
#include <wiringPi.h>
#include <softPwm.h>
BLYNK_WRITE(V1)
//FOREWORD LEFT SWING TURN
int pinValue = param.asInt(); // assigning incoming value from pin V1 (left button)to a variable
// STOP left motor
softPwmWrite (6, 100); //PWMA on GPIO. 6
digitalWrite (4, LOW); //AIN1 on GPIO. 4
digitalWrite (5, LOW); //AIN2 on GPIO. 5
// TURN ON CW right motor
softPwmWrite (29, 100); //PWMB on GPIO. 29
digitalWrite (27, HIGH); //BIN1 on GPIO. 27
digitalWrite (28, LOW); //BIN2 on GPIO. 28
BLYNK_WRITE(V2)
//FOREWORD RIGHT SWING TURN
int pinValue = param.asInt(); // assigning incoming value from pin V2 (right button) to a variable
//TURN ON CW left motor
digitalWrite (4, HIGH); //AIN1 on GPIO. 4
//STOP right motor
digitalWrite (27, LOW); //BIN1 on GPIO. 27
BLYNK_WRITE(V0)
//FOREWORD
int pinValue = param.asInt(); // assigning incoming value from pin V0 (forward button) to a variable
// TURN ON CW left motor
BLYNK_WRITE(V3)
//BACKWARD
int pinValue = param.asInt(); // assigning incoming value from pin V3 (backward button) to a variable
digitalWrite (5, HIGH); //AIN2 on GPIO. 5
digitalWrite (28, HIGH); //BIN2 on GPIO. 28
softPwmCreate (6, 100, 100);
softPwmCreate (29, 100, 100);
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
Here is the code, please let me know what wrong why not work with control on Blynk?
Thanks,
MP
Hi Peter and Gunner,
Finally, I can post my code correct format. Please review and let me know why not work on Blynk control?
Thanks, for your time
MP
OK, now that you seem to have the code formatting for forum posting done, i cleaned up this topic for a bit of clarity.
Now as for your code…
Is you project connected OK?
What to these commands actually control? (AKA a motor controller of some sort?) and are you sure they work? (AKA tried them without Blynk).
Hi Gunner,
My project is connect now but not working at all
Please advise.
Thanks,
MP
Hi Gunner,
I have this code working without Blynk. Please let me know how to connect to the Blynk to control on the iPhone. If previous code too complicate, please ignore. Please show me how onnect on this code, I test it working without Blynk
Thanks,
MP
cpp
import RPi.GPIO as GPIO
from time import sleep
GPIO.setmode(GPIO.BOARD)
Motor1A = 16
Motor1B = 18
Motor1E = 22
GPIO.setup(Motor1A,GPIO.OUT)
GPIO.setup(Motor1B,GPIO.OUT)
GPIO.setup(Motor1E,GPIO.OUT)
print "Going forwards"
GPIO.output(Motor1A,GPIO.HIGH)
GPIO.output(Motor1B,GPIO.LOW)
GPIO.output(Motor1E,GPIO.HIGH)
sleep(2)
print "Going backwards"
GPIO.output(Motor1A,GPIO.LOW)
GPIO.output(Motor1B,GPIO.HIGH)
sleep(2)
print "Now stop"
GPIO.output(Motor1E,GPIO.LOW)
GPIO.cleanup()
Well Blynk is basically just a user interface… you still use whatever code works without Blynk…
If this works, then use it instead of …
//FOREWORD
Hi Gunner,
The new code work without Blynk. Please let me know how to connect to the Blynk with new code?
print “Going forwards”
change to
digitalWrite(Motor1A,GPIO.HIGH)
digitalWrite(Motor1B,GPIO.LOW)
analogWrite(Motor1E,GPIO.HIGH)
Will this ok?
I can’t tell you how to do it since I do not have the same setup to test… I am saying that it you have a way that works in a normal sketch, then the same commands should work within a BLYNK_WRITE(vPin) function.
Thanks, Gunner. It work well without Blynk. I do not know how to add to Blynk to control on iPhone.
MP
I can’t write your code for you.
The “good” code you show appears to be in Python? So either use Blynk’s Python library or figure out the proper way to control your motors with C++… THEN add in the Blynk interface.
NOTE Blynk Python is still in Alpha
