After countless banging my head against the wall and running post to pillar to send OTA .bin files over GSM to my device, I have figured out a solution for the same, it has a few prerequisites, this is based on the minimal OTA code that was shared by @Ibrahim_Roshdy over here Blynk.Air OTA minimal code
I am using tinygsm with a sim800l and on an ESP32
edit, added a few missing function calls
there may be a few which aren’t used which i may have added during testing, please feel free to point it out
#include <TinyGsmClient.h>
#include<FS.h>
#include "FS.h"
#include "SPIFFS.h"
// Increase RX buffer
#define TINY_GSM_RX_BUFFER 1023
// other include functions and global variables here
void printProgressBar(int progress) {
Serial.print("\rProgress: [");
for (int i = 0; i < 50; ++i) {
Serial.print(i < (progress / 2) ? "=" : " ");
Serial.print("] ");
Serial.print(progress);
Serial.print("%");
void appendFile(fs::FS &fs, const char *path, const char *message)
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if (!file)
Serial.println("Failed to open file for appending");
return;
if (file.print(message))
Serial.println("APOK");
Serial.println("APX");
void readFile(fs::FS &fs, const char *path)
Serial.printf("Reading file: %s\n", path);
File file = fs.open(path);
if (!file || file.isDirectory())
Serial.println("Failed to open file for reading");
return;
Serial.print("Read from file: ");
while (file.available())
Serial.write(file.read());
delayMicroseconds(100);
void writeFile(fs::FS &fs, const char *path, const char *message)
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if (!file)
Serial.println("Failed to open file for writing");
return;
Serial.println("File written");
Serial.println("Write failed");
void listDir(fs::FS &fs, const char *dirname, uint8_t levels)
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root)
Serial.println("Failed to open directory");
return;
if (!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while (file)
if (file.isDirectory())
Serial.print(" DIR : ");
Serial.println(file.name());
if (levels)
listDir(fs, file.name(), levels - 1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
void deleteFile(fs::FS &fs, const char *path)
Serial.printf("Deleting file: %s\n", path);
if (fs.remove(path))
Serial.println("File deleted");
Serial.println("Delete failed");
void performUpdate(Stream &updateSource, size_t updateSize)
if (Update.begin(updateSize))
size_t written = Update.writeStream(updateSource);
if (written == updateSize)
Serial.println("Writes : " + String(written) + " successfully");
Serial.println("Written only : " + String(written) + "/" + String(updateSize) + ". Retry?");
if (Update.end())
Serial.println("OTA finished!");
if (Update.isFinished())
Serial.println("Restart ESP device!");
ESP.restart();
Serial.println("OTA not fiished");
Serial.println("Error occured #: " + String(Update.getError()));
Serial.println("Cannot beggin update");
void updateFromFS()
File updateBin = SPIFFS.open("/update.bin");
if (updateBin)
if (updateBin.isDirectory())
Serial.println("Directory error");
updateBin.close();
return;
size_t updateSize = updateBin.size();
if (updateSize > 0)
Serial.println("Starting update");
performUpdate(updateBin, updateSize);
Serial.println("Error, archivo vacío");
updateBin.close();
// whe finished remove the binary from sd card to indicate end of the process
//fs.remove("/update.bin");
Serial.println("no such binary");
void printPercent(uint32_t readLength, uint32_t contentLength)
// If we know the total length
if (contentLength != -1)
Serial.print("\r ");
Serial.print((100.0 * readLength) / contentLength);
Serial.print('%');
Serial.println(readLength);
bool parseURL(const String& url, String& server, String& resource, int& port) {
// Check if the URL starts with "http://"
if (!url.startsWith("http://")) {
Serial.println("Invalid URL format");
return false;
// Remove the "http://" part
String urlWithoutProtocol = url.substring(7);
// Find the position of the first "/" after "http://"
int slashPos = urlWithoutProtocol.indexOf('/');
// Extract the server part
server = urlWithoutProtocol.substring(0, slashPos);
// Extract the resource part
resource = urlWithoutProtocol.substring(slashPos);
// Find the position of ":" to check for a custom port
int colonPos = server.indexOf(':');
if (colonPos != -1) {
// Custom port specified
port = server.substring(colonPos + 1).toInt();
server = server.substring(0, colonPos);
// Use default port 80
port = 80;
return true;
String overTheAirURL;
BLYNK_WRITE(InternalPinOTA) {
overTheAirURL = param.asString();
String serverOTABlynk;
String resourceOTABlynk;
int portOTABlynk;
Blynk.disconnect();
if (!parseURL(overTheAirURL, serverOTABlynk, resourceOTABlynk, portOTABlynk)) {
Serial.println("Failed to parse URL");
return;
TinyGsmClient client(modem);
Serial.print(serverOTABlynk);
Serial.print(" on port ");
Serial.println(portOTABlynk);
if (!client.connect(serverOTABlynk.c_str(), portOTABlynk)) {
Serial.println("Connection failed");
Blynk.connect();
return;
// Make a HTTP GET request
client.print(String("GET ") + resourceOTABlynk + " HTTP/1.1\r\n" +
"Host: " + serverOTABlynk + "\r\n" + // Use only the server part
"Cache-Control: no-cache\r\n" +
"Connection: close\r\n\r\n");
long timeout = millis();
// Wait for the server to respond
while (!client.available()) {
if (millis() - timeout > 25000L) {
Serial.println(">>> Client Timeout !");
client.stop();
Blynk.connect();
return;
// Reading response header
uint32_t contentLength = 0;
while (client.available()) {
String line = client.readStringUntil('\n');
line.trim();
Serial.println(line); // Print the response header (uncomment for debugging)
if (line.startsWith("Content-Length: ")) {
contentLength = line.substring(line.lastIndexOf(':') + 1).toInt();
} else if (line.length() == 0) {
break;
Serial.print("Content-Length: ");
Serial.println(contentLength);
// Open the firmware file in SPIFFS for writing
File firmwareFile = SPIFFS.open("/update.bin", "w");
if (!firmwareFile) {
Serial.println("Failed to open firmware file for writing");
client.stop();
Blynk.connect();
return;
// Reading and handling the response
uint32_t readLength = 0;
Serial.println("Downloading firmware...");
uint8_t c = client.read();
readLength++;
// Write firmware data to SPIFFS
if (firmwareFile.write(c) != 1) {
Serial.println("Error writing firmware data to SPIFFS");
firmwareFile.close();
client.stop();
Blynk.connect();
return;
// Your update logic here, similar to the previous example
if (contentLength != 0 && readLength % (contentLength / 13) == 0) {
// Print progress if needed
Serial.print("\r");
Serial.println((100.0 * readLength) / contentLength);
Serial.print('%');
Serial.println(); // New line after progress
// Close the firmware file
// Close the client connection
client.stop();
// Check CRC and update completion
if (readLength == contentLength) {
Serial.println("Update successful!");
updateFromFS();
// Reboot or perform other necessary actions
ESP.restart();
Serial.println("Update failed!");
Blynk.connect();
return;
//setup serial monitor, configure tinygsm, blynk setup, other functions etc
if (!SPIFFS.begin(true))
Serial.println("SPIFFS Mount Failed");
return;
SPIFFS.format();
listDir(SPIFFS, "/", 0);
//Format the spiffs to accept updates
The disconnects you see in the image is me purposefully messing with the power supply of the sim800 to check whether Blynk manages to ship the firmware if there is a signal quality drop and/or total disconnection via GSM
a 1MB .bin file took about 2:30 minutes to download, so about 6.8 KBPS, an acceptable speed for a 2g connection ![]()
this is a drop-in replacement for all Blynk sketches that run Blynk 2.0 but are not operating via edgent due to a lack of support
thank you @PeteKnight for pointing me in the right direction earlier when i was stuck with this
Happy Blynking to everyone
